superbizzy73
Boeing MQ-25 News and Discussion Thread
Fri Sep 20, 2019 1:15 am
https://www.defensenews.com/naval/2019/ ... st-flight/
Congratulations to Boeing and the US Navy for this milestone. Here’s hoping the project goes forward without any major hiccups. Boeing really needs this one to go smoothly.
Reason: Title updated
Ozair
Re: Boeing MQ-25 flies for the first time
Fri Sep 20, 2019 2:24 am
superbizzy73 wrote:
https://www.defensenews.com/naval/2019/09/19/the-us-navys-new-autonomous-refueling-drone-takes-historic-first-flight/
Congratulations, this is a good achievement and while it isn't an actual prototype aircraft to be delivered under the contract it is great to see this one fly. It must certainly up the confidence the USN has that this program will move forward as planned.
Image for those who won't click the link.
JayinKitsap
Fri Sep 20, 2019 2:58 am
This is good. I wonder how far from being a prototype this is.
Reddevil556
Fri Sep 20, 2019 12:53 pm
Haven’t been able to find a definitive answer, but what exactly is the task and purpose of a refueling drone? Is it for other drones or for refueling manned aircraft? Seems a bit on the small side to refuel aircraft such as the F-35 and F/A-18
bikerthai
Fri Sep 20, 2019 1:29 pm
There are various artist concept images out there showing the drones (both LM and Boeing) refueling fighters.
The size of the drone in the photos are deceiving as there are no crew standing next to it.
This article has photos and video of the frame with perspective.
https://defence-blog.com/news/boeing-re ... sting.html
If you look at real photos, you can see that it is a good size aircraft. It eliminates the need for fighter to fighter refueling for strike packages.
bikerthai
Fri Sep 20, 2019 1:51 pm
And first flight video can be found here:
https://www.youtube.com/watch?v=lLV8eQWxVNo
At 12 seconds, you can see the proportion of the plane with respect to the escort truck.
bt
Oroka
Fri Sep 20, 2019 2:08 pm
It is not a big tanker, it is more of a replacement for sending out another fighter like a Rhino to do buddy refueling. Its about the size of a big fighter.
LightningZ71
Fri Sep 20, 2019 5:38 pm
On the size and capacity...
Keep in mind that the contract also stipulates that the drone use the existing hose/drogue refueling pods that the F/A-18's use on buddy fueling missions. This means that there is no internal storage space taken up with the refueling hose/drogue and reel. This gives a greater volume fraction for fuel storage.
meecrob
Fri Sep 20, 2019 7:32 pm
In addition to what has been said above with regards to size, this drone has to be integrated into a carrier environment. Deck/hangar space is at a premium. I recall reading an article written by a member of a C-2 COD crew in which he said that it was rare that they and the C-2 actually stayed aboard the carrier after delivery. Instead, they usually flew ashore and stayed in hotels simply because it was too much hassle to maneuver and park a plane even the size of a C-2 on the carrier if not necessary.
Reddevil556
Fri Sep 20, 2019 9:27 pm
Thanks for simple explanation, that makes sense then.
JayinKitsap
Fri Sep 20, 2019 9:28 pm
It is proposed for the MQ-25 to do the refueling for all carrier aircraft if Air Force tankers are not available. The RFP required each MQ-25 to deliver 15,000 lb of fuel 500 miles from the carrier with some hover time also. This is basically the full fuel load of a Super Hornet, and about 80% of a F-35.
The FA-18 has a MTOW of 66,000 lb, it looks like the MQ-25 is reusing the FA-18's gear. So it may be capable of delivering more fuel at 500 miles, I have not found any specifications of what the MQ-25 can actually do for empty weight, payload, range, or MTOW. I suspect it will have similar to the FA-18 MTOW. That is a very workable size on the carrier as well as using the same inventory of consumables and spare parts.
mham001
Sat Sep 21, 2019 3:14 am
Which Boeing tanker will enter service first? They seem to be slightly ahead of schedule on this one.
itchief
Sun Sep 22, 2019 3:48 pm
For many of the questions in the previous post. Go to the link below for answers.
http://www.boeing.com/defense/mq25/
estorilm
Mon Sep 23, 2019 2:37 pm
Didn't Northrop have something FAR FAR FAR more advanced than this flying years ago? Including carrier landings and takeoffs?
What a ridiculous waste of $$$. :(
JayinKitsap
Mon Sep 23, 2019 4:57 pm
Northrop did have a drone that went thru carrier landings and takeoffs, but they decided to not submit for the MQ-25 RFP.
Boeing's MQ-25 has a lot in common with their submission for that earlier RFP, but they were not selected.
The previous project was for a drone fighter, they went simpler and removed stealth from the requirements. A tanker is the right stepping stone
as it is relatively simple task compared to the fighter. Besides we need manned bombers and fighters, for the pilot's glory.
estorilm
Mon Sep 23, 2019 7:27 pm
Well, I generally agree - however from what I had read and discussed with people in the program, the Northrop X-47B was extremely far along in development (largely on Northrops own $$$) and was routinely taxiing and performing other carrier ops remotely - YEARS ahead of this project, with a more capable (and more stealthy) platform.
I understand the Boeing design doesn't have the same requirements, but damn... what a waste of money. Now we need to sit around and watch the Boeing sponge soak up as much govt $$$$$ as possible to get the most basic platform into the air again.
bikerthai
Tue Sep 24, 2019 1:32 pm
estorilm wrote:
Well, I generally agree - however from what I had read and discussed with people in the program, the Northrop X-47B was extremely far along in development (largely on Northrops own $$$) and was routinely taxiing and performing other carrier ops remotely - YEARS ahead of this project, with a more capable (and more stealthy) platform. I understand the Boeing design doesn't have the same requirements, but damn... what a waste of money. Now we need to sit around and watch the Boeing sponge soak up as much govt $$$$$ as possible to get the most basic platform into the air again.
You have to get into the details to see if the argument is valid. It may be true that the X-47B development may be ahead of the curve, but you have to consider the detail design aspect of the plane and how it was put together. If it was designed in the same vein as the B-2 then it would have been expensive to built and operate. If you do not need stealth in a tanker, then why carry along the extra cost of such a platform. And who to say that the money spent on the X-47 was wasted. The development could have gone to the B-3 project. Remember that the Air Force is developing the B-3 as both manned and future un-manned platform.
Boeing, which did have some work on the B-2 have the benefit of commercial manufacturing infrastructure (tanker fiasco not withstanding) to build cheaper frames (in the long run). Their experience in small UAV (scan eagle etc.) also mean that they are not that far behind in that field. Add to that, Boeing has the carrier experience with the F-18. The only other manufacturer with carrier experience would have been LM.
bt
Tugger
Tue Sep 24, 2019 2:31 pm
Well modern carrier experience. The Grumman Tomcat was THE plane for awhile there. It was produced thru 1991. So NG has that heritage if not current experience (which I agree is 99% of the issue).
(Sorry I just to point that out, carry on! :profile: )
Tugg
bikerthai
Tue Sep 24, 2019 6:50 pm
Yeah, even at Boeing much of the tanker experienced retired leaving the new crop to work the KC-46. Heck, there are probably few B-2 engineers left in the company was well. It will be interesting to see how the B-3 fares as I suspect many of their designers may have come over from their UAV organization.
bt
estorilm
Tue Sep 24, 2019 9:07 pm
Tugg
Thanks for saving me the post haha - Grumman was probably the king in this field back in the day, and I figure it's carried along in their heritage (both technically and within their staff / knowledge base). I just flew back from an air show in our CAF wing's Grumman Avenger Sunday and still think about the size of the gear struts, the wing fold mechanisms, etc..
JayinKitsap
Fri Oct 11, 2019 5:02 pm
Ozair
Sun Jan 12, 2020 10:38 pm
While this is NAVAIR driven it is really interesting to see what they are working on to make drone refueling safer and more effective.
PMA-201 demonstrates SBIR technology to advance aerial refueling
In August, successful wind tunnel testing and demonstration combining two Small Business Innovation Research (SBIR) projects in simulated flight took place at the AEDC National Full-Scale Aerodynamics Complex (NFAC) 40 by 80 wind tunnel at NASA Ames, California.
Research under SBIR topic N07-172 lead to the development of Actively Stabilized Refueling Drogue System (ASDRS) by Analytical Mechanical Associated (AMA); a system that is able to counteract disturbances on the aerial refueling drogue in flight. Integrated with the N15A-T014 effort developed by Coherent Technical Services, Inc. (CTI), the Innovative Instrumentation Package: Optical Reference System (ORS), an image processing system that can determine drogue position with Hi-Resolution video has resulted in a more stable aerial refueling platform. These began as two separate Science and Technology efforts in response to two independent needs.
The first was the need to provide a more stable aerial refueling platform so that our receiver aircraft could engage the drogue and receive fuel more safely and efficiently. The ASDRS consists of a pair of aluminium shrouds that can rotate mounted onto the exiting hose end-refueling coupling. On these shrouds are pairs of lift and roll strakes that produce the lift force to counteract the disturbance and the roll torque needed to generate power that will stored in a system of onboard super-capacitors. A pair of DC motors controlled by an onboard control law system drives the drogue control system. When the system is not in active mode, the DC motors recharge the super-capacitors.
The original Phase I effort for N07-172 was awarded to Nielsen Engineering & Research, a branch of AMA, back in 2008 to research an innovative controllable drogue refueling system. This research led to a Phase II award in 2012 followed by a PHII.5 in 2016 totaling over $2 million in SBIR funding to continue refining the technology to deliver innovative concepts for stabilization and control.
Separately, to support future readiness and reliability of the Aerial Refueling Store (ARS), an innovative instrumentation package is being developed to better monitor system performance. Part of this package is the ORS, which provides real time hose, drogue and receiver position. The ORS consists of a pair of high-resolution cameras, image processing algorithms, and data storage. The ORS is housed in the tanker system, in this case, the USN Aerial Refueling Store (ARS). ORS can provide real time drogue and receiver position relative to the tanker aircraft at up to 20 Hz. It is also serves as the perfect drogue position feedback sensor for the ASDRS.
https://www.dcmilitary.com/tester/news/ ... f357f.html
This video shows the impact of one of the initiatives. Certainly a significant change in the movement of the basket and should make connection a whole lot easier, quicker and result in less shredded baskets which improves on station time and fewer dropped missions due to equipment failure.
https://www.youtube.com/embed/Dli5c27Bv9g
Ozair
Tue Mar 31, 2020 3:44 am
Boeing are trying to stay focused on the primary air refuelling mission of the MQ-25 and avoid trying to tie other mission sets into the platform. Clearly doing that will help them deliver on time and it appears the USN is also very focused on getting the platform to the fleet as soon as possible.
Boeing stays focused on basics to keep unmanned tanker on track
The Boeing MQ-25A Stingray in-flight refuelling tanker is on track to achieve initial operational capability (IOC) by 2024. That is thanks to a narrow set of development goals, close integration with Naval Air Systems Command personnel and the early test use of a flyable prototype, says Boeing.
The manufacturer adds that the core of its MQ-25A development strategy is waving off distractions in order to deliver on just two goals: building an aircraft that can fly from an aircraft carrier deck and can refuel fighters. “If we focus on what’s in front of us and do it well, we are sure it opens doors,” says Dave Bujold, director of the MQ-25A programme. “If we don’t focus on what is in front of us and don’t do it well, we are sure it closes doors.”
The MQ-25A has also been floated by the USN and others as having multiple future roles, including as an intelligence, surveillance and reconnaissance (ISR) platform, but Boeing says it doesn’t plan to expand the UAV’s capabilities, noting the service’s tanking priority.
In June 2019, the National Geospatial-Intelligence Agency announced its intention to award a sole-source contract to Boeing Phantom Works to study the capabilities of the company’s Multi-Mission Pod on the MQ-25A. Bujold reiterates the USN focus is on aerial refuelling, but points out the aircraft has some limited ISR capabilities now.
“It’s not doing anything crazy or exotic that would capture anybody’s imagination,” he says. “But it certainly is going out of line-of-sight communications with the carrier. So therefore it’s an interesting player in the carrier air wing for potential ISR use.”
https://www.flightglobal.com/flight-int ... 78.article
Tugger
Tue Mar 31, 2020 2:27 pm
"Focused to stay on track" yes, that is one absolute element. And a smart and critical one.
The other equally important thing is that if the government wants any other capability it will have to pay for it. Period. (And Boeing needs the future money flows to be there.) Ain't nothing gonna be given for free. (And is it ever in military contracts?)
Tugg
bikerthai
Tue Mar 31, 2020 2:35 pm
This is no different than what the Navy did with the P-8A program. They established a basic configuration for the early lots and implement increment improvements as the program matures.
bt
JayinKitsap
Wed Apr 01, 2020 4:34 am
Tugg
Also, so important to get the basics done right. Critical to have a reliable, safe, and efficient landing, movement, on deck fueling, and launch system that the crew and command like (hopefully love). Just as critical is the aerial refueling set up. There will already be secure data to it, for now just ensure enough available bandwidth for some future and assign some spaces and power requirements of possible sensor packages.
If they do it right they might just own the carrier drone market. If they do it wrong - likely gone.
Ozair
Mon Apr 06, 2020 9:36 pm
A ray of sunshine for Boeing right now... The USN orders an additional three aircraft for the test phase, perhaps a good sign that the USN is happy with the progression of the build and test phase. Depending on how soon Boeing can deliver them it may also be an opportunity to accelerate the test phase.
US Navy awards Boeing $84.7m for three more MQ-25A unmanned refuelling tankers
The US Navy (USN) has awarded Boeing $84.7 million for three additional MQ-25A Stingray unmanned in-flight refuelling tankers.
The unmanned air vehicles (UAV) are expected to be complete by August 2024, says the Department of Defense in a notice online on 2 April.
The three additional “demonstration test articles” bring the total number of aircraft Boeing is manufacturing in the MQ-25A programme to seven. The award was an option on the original four-aircraft contract, worth $805 million, which was awarded to Boeing in August 2018.
https://www.flightglobal.com/fixed-wing ... 17.article
Ozair
Thu Jun 11, 2020 12:29 am
The availability of US Carriers to have the required hardware installed and conduct testing of the MQ-25 could seriously impact the schedule for the aircraft and force the program to remain in the dev phase for far longer. It is one of those critical dependencies defence projects have to deal with and in this case may end up costing the USN given the fixed price nature of the contract.
If the US Navy isn’t careful, its new unmanned tanker drone could face a 3-year delay
The US Navy could face a three-year delay in testing of the MQ-25 Stingray carrier-based tanking drone if it doesn’t get its designated test ships through the required modernizations on time, a possibility the Navy said was “remote.”
Two carriers — Carl Vinson and George H.W. Bush — have limited windows to complete the installation of unmanned aircraft control stations, and if operational commitments intervene it could create significant issues for the program, according to Navy officials and a government watchdog report.
“Program officials stated that, among other things, the Navy’s potential inability to maintain its schedule commitments could require modifications to the contract that would impact the fixed-price terms,” the Government Accountability Office reported. “Specifically, the Navy faces limited flexibility to install MQ-25 control centers on aircraft carriers.
“If the Navy misses any of its planned installation windows, the program would have to extend MQ-25 development testing by up to 3 years. According to officials, such a delay could necessitate a delay to initial capability and result in a cost increase.”
https://www.defensenews.com/naval/2020/ ... ear-delay/
Installing anything new on an in service naval vessel is never an easy procedural task so I can see why there would be issues with this, especially given the current commitments the carrier fleet has.
SteelChair
Sun Jun 14, 2020 2:16 pm
Based upon past experience, its not hard to envisage a protracted development and a final product that falls short of requirements. If Boeing couldn't deliver the far less ambitious KC-46 and MAX, what is the probability of success for this program?
bikerthai
Sun Jun 14, 2020 2:33 pm
Boeing is not a monolith. And while the KC-46 is a military derivative, the initial delays were a result of decisions from the commercial side. The vision problem is one that the military side owns of which it seems they were lacking in experience.
With the drone, Boeing is much more experienced. While not as versed as NG, they do have the highly successful Scan Eagle line, along with the new autonomous sub.
Just hope that with fewer cooks in this kitchen, they will be better at putting out a better dish.
bt
JayinKitsap
Wed Jul 22, 2020 12:50 am
An update on the MQ-25, it appears that it is starting testing with the Cobham refueling pod. This program seems to get very little media attention.
https://www.thedrive.com/the-war-zone/3 ... ueling-pod
JayinKitsap
Wed Jul 22, 2020 4:43 am
So a bit of news gets some other writers going, a recent MQ-25 article.
https://www.forbes.com/sites/davidaxe/2 ... d2bc64f765
Ozair
Sun Sep 13, 2020 11:00 pm
The USN is emphasising the advantages the MQ-25 will provide them in pushing the range of their strike assets further and, combined with new weapons, past what they consider the range envelope of future threats.
The future US Navy carrier air wing will be effective at extended ranges, admiral says
Rear Adm. Greg Harris told a virtual audience that a recent force structure study of the carrier air wing – the aircraft and associated personnel assigned to aircraft carriers – and that a combinations of new systems and new weapons coming online make the carrier relevant even as potential adversaries invest in long-range weapons to keep the Navy’s powerful strike arm at bay.
The addition of the MQ-25 Stingray, which an unmanned tanker drone for refueling aircraft being developed by Boeing, helps in that endeavor, as will a next-generation fighter Harris said.
“The MQ-25 adds range which adds lethality to the carrier strike group,” he said. “When you add that additional range to 4th and 5th Gen[eration] fighters; when you add that range to the range we’re looking at for F/A-XX or next-generation air dominance family of systems; if you add that to the long-range weapons that we are currently procuring and look to procure in the future: we have an ability to strike at range and with volume and tempo.”
https://www.defensenews.com/naval/2020/ ... iral-says/
Ozair
Fri Oct 30, 2020 3:05 am
USN aviators are conducting some very early testing of the MQ-25 by simulating flights in the MQ-25 using the GCS. Things continue to point towards this program being able to meet its delivery timeframes, although ship installation of the GCS to allow flight test remains a risk.
Navy aviators learn to “fly” the MQ-25 unmanned aerial refueler
U.S. Navy aviators are already learning how to “fly” the MQ-25 unmanned aerial refueler before the first air vehicle comes off the production line.
Four Navy air vehicle operators (AVOs) from VX-23, the Navy’s developmental test squadron, and VX-1, the operational test squadron, recently traveled to Boeing’s St. Louis facility for an immersive three-day simulation designed to train them to operate a flight from start-up to shut-down from the ground control station (GCS) – the MQ-25’s terrestrial or CVN-based “cockpit.”
This course was possible due to the experience gained by flying T1, the Boeing-owned MQ-25 test asset developed prior to the Navy awarding Boeing the MQ-25 Engineering, Manufacturing and Development contract in August 2018. T1 first flew in September 2019 and to date has accumulated nearly 30 flight hours during its initial phase of testing. T1 recently underwent a planned modification to integrate an aerial refueling store (ARS) and is currently in ground testing prior to resuming flight testing. Navy AVOs will have the opportunity to serve in the co-pilot role, AVO No. 2, when flights resume.
Lt. Venus Savage, the VX-1 MQ-25 assistant operational test director, said the training was a unique opportunity to learn about the command and control processes used to interface with and operate the MQ-25 long before the first aircraft is delivered to the Navy.
“Especially for operational test, we’re lucky to be involved this early in the program,” Savage said. “It helps when you get that side information from an experienced AVO that adds to what’s in the documentation. We were able to ask detailed questions and get clarification on what the checklists and commands are and they let us know what to expect from the air vehicle. It helps ingrain it in your memory because it’s more than just book learning.”
The ongoing dialogue between Navy and Boeing AVOs helps shape the final system delivered to the Fleet, which is a win for the Navy, Boeing and ultimately the warfighters that will use the system.
Savage explained that the combined experience of the Navy and Boeing team differentiates MQ-25 from other programs. “While there are still changes to be made, like with all developmental programs, we’re working together to create a better finished product,” Savage said. “The collaboration is awesome. It’s a great team to work with.”
https://www.navair.navy.mil/news/Navy-a ... 92020-1541
Ozair
Mon Dec 14, 2020 9:57 pm
First test of the MQ-25 with the refuelling pod on the aircraft. The pod looks very big compared to the airframe itself. This is just the Boeing test aircraft and not a pre-production airframe although not sure how many changes there will be, at least externally, between the two. Some graphics have also shown an external fuel tank on the other wing which would likely assist with loading and balance.
Boeing flies MQ-25 with aerial refuelling pod for first time
Boeing has flown its MQ-25A test asset (T1) with an aerial refuelling store under its wing for the first time.
The initial flight lasted 2.5h and was conducted by Boeing test pilots operating the unmanned air vehicle from a ground control station at MidAmerica St. Louis Airport in Mascoutah, Illinois. The flight tested the unmanned in-flight refuelling tanker’s aerodynamics with the refuelling pod mounted under the wing, the company says.
https://www.flightglobal.com/military-u ... 66.article
889091
Mon Dec 14, 2020 11:17 pm
Can the entire pod be jettisoned in case the basket and hose cannot be reeled back in? It would make a carrier landing slightly tricky, with a flailing hose and basket behind you.
Ozair
Mon Dec 14, 2020 11:29 pm
I believe the pod is the standard Cobham pod used on the SH for A2A refuelling and the pylon would also be fleet standard so should be very easy to eject the pod should that be deemed necessary. This is the pod used on the SH, https://www.cobhammissionsystems.com/ai ... t/docview/ which can be jettisoned.
JayinKitsap
Tue Dec 15, 2020 11:14 am
A great picture of the landing gear of the MQ-25, I have long suspected the landing gear came from another program, can anyone tell if it is the Hornet's or the SH's.
I recall from back during the RFP stage that both the Cobham SH pod and the external tank were to be the SH's
LyleLanley
Tue Dec 15, 2020 11:12 pm
That's why you have a hose jettison capability. Pretty sure ditching a 50 foot piece of rubber in the drink is a lot more economical than dumping a million dollar pod.
889091
Wed Dec 16, 2020 4:22 pm
Thanks Ozair.
Most of the buddy refueling pics that I have seen - the pod is slung under the central hardpoint of the donor aircraft.
https://world-defense.com/threads/buddy ... ling.4639/
I do not believe the MQ-25 has a central hardpoint, nor does it seem to have enough clearance. As the MQ-25 had been identified as a dedicated refueling drone early on in its development, why would they just slap it under one wing? The drag alone would probably cause asymmetric yaw and also affect loiter time. Could they not have integrated the pod into the body of the drone to make it more streamlined? And should be a complete pod jettison be required (Thanks LyleLanley for pointing out that the pod has a hose guillotine capability) - it will just pop off, ala the MD-80 tailcone.
bikerthai
Re: Boeing MQ-25 News and Discussion Thread
Wed Dec 16, 2020 6:32 pm
Not saying that this is the case, but if you look at possible location for the refueling hose, you would have to place it in front of the engine and drop the hose from some place near the wing center body. Having the mechanism near the back would put it too close proximity to he engine and the heat.
Maybe they would ultimately add an internal reel for the hose, but that would require additional development. The pod is a quick and easy first step to get the capability fielded.
bt
texl1649
Wed Dec 16, 2020 7:56 pm
I still don't know how the USAF intends to approach the boom system in a stealthy platform. One would think some sort of plan would be in place heading into 2021 but I've never seen even a rough sketch.
Ozair
Wed Dec 16, 2020 9:51 pm
Of the three MQ-25 final contenders the LM option had the pod closest to the centreline, but still not on it, but with enough room to hold a second pod/tank. The GA bid also had the two pod load which I expect will be standard on the MQ-25.
LM bid
GA bid
The USN specified the requirement to use the existing SH buddy pod which I expect was to reduce overall risk. For this first iteration better to get the capability out as quickly as possible with existing hardware against a potentially longer development program for a more optimal solution.
LyleLanley
Wed Dec 16, 2020 11:32 pm
889091 wrote:
Thanks Ozair.
Being off-center isn't as big a deal as you might think: that's why you have rudder trim. The S-3 had no problems for many, many years of off-center tanking. It seems a bigger deal than it really is. For reference, F-super hornets often carry a wing fuel tank along with their centerline (with a bomb or two on the opposite wing). If asymmetry was actually a problem they wouldn't be able to drop a bomb for fear of yaw. Long story short: asymmetry isn't a big deal.
Why did they insist on using a super hornet pod instead of something more efficient like an integral store? Easy: if the MQ-25 is grounded or otherwise unable to accomplish its tanking mission, you can then slap that very same pod onto any one of the 4 super hornet squadron's jets and you'd have a tanker right then and there! Comms problems precluding launching the UAV but you have a recovery cycle in 45 minutes? No problem: slap the refueling pods on a super hornet and the air wing is good! Even when carriers had the dedicated KA-6 tanker, you'd still see A-7s or A-4s with refueling pods hawking dudes on recovery. Versatility is the biggest strength of the carrier strike group!
JayinKitsap
Thu Dec 17, 2020 4:11 am
Ozair's post has a broken link to the LM version. This article has some good pictures of the 3 contenders.
https://news.usni.org/2018/04/09/navy-p ... ay-program
It seems the RFP identified for the Cobham unit on one side and an external tank on the other, balancing it out.
bikerthai
Thu Dec 17, 2020 1:07 pm
That explains it. Does the RFP mention anything about the internal hose? Looking at the MQ-25A, with the high exhaust, there might be room beneath aft for a reel.
bt
889091
Thu Dec 17, 2020 3:54 pm
Thanks for the interesting replies folks - learn something new everyday.
bt
So I did a little more digging and I found this video on the Boeing website (surprise!)
https://players.brightcove.net/80000061 ... 3787866001
Already occupied. Looks like they have a retractable arrestor hook at the end (00:23 in the video).
JayinKitsap
Thu Dec 17, 2020 8:12 pm
bt
I've only seen articles about the RFP, never the actual RFP. There is lots that is secret about the specifications in the RFP and in the proposal. For example, what is the actual payload of fuel the MQ-25 carries. I'm pretty sure it exceeds the 15,000 lb refueling out at range, but does it have 18,000 lb say now.
As 889091 noted the tail hook is on centerline, that needs to be on centerline for sure.
For future use of this frame, when not tanking the MQ-25 now has two pretty good hard points. I am sure we will see recon and surveillance models in the future. This would allow the carrier radar to basically be off, as two or 3 drones would have the radars on instead and have A2A missiles out 250 miles from the ship.
I'm quite curious how all the unmanned planes and ships evolve into the system. I do like how the Navy is approaching doing the most mundane tasks first. For strike fighters, the loyal wingman is a great idea. For deep penetration it seems we are basically making a better cruise missile.
889091
Fri Dec 18, 2020 1:54 pm
Do these things have a proximity self destruct trigger in case the data up/downlink is lost during short final, preventing the operators from landing it on the flight deck?
Predator or Reaper drones slamming onto an asphalt runway - asphalt runway will always win.
MQ-25 with empty tanks full of vapour (I do not believe it has OBIGGS?) slamming onto a Nimitz/Ford class flight deck may cause some substantial damage however...
mxaxai
Fri Dec 18, 2020 2:40 pm
Don't they have some form of autoland / autopilot? I expect the MQ-25 to require relatively little manual guidance throughout the flight.
Users browsing this forum: Kiwirob and 7 guests
