bikerthai
Re: USAF looking for an E-4B replacement
Thu Jan 09, 2020 7:29 pm
It's not the Computing Equipment that will take up the room. It's the number of operators that will determine the size of plane as. Typical mission console size have not changed that much. So if they want to maintain the same number of console operator, then they would need similar floor space.
As for computing PC on a military aircraft, even if the chips or cards are "off the shelf" the EMI shielding is obtained at different levels: The aircraft, the cabinets and the LRU chassis themselves. This is where a 747 or 767 or an A330 works as shielding design as it is already done. Shielding a 777 would require new engineering work.
bt
strfyr51
Thu Jan 09, 2020 10:35 pm
bikerthai wrote:
JayinKitsap wrote:
The search begins for used 747-8i planes.
Why 747-8i? I mean the seat tracks may make it easy to design the interiors, but if push comes to shove, wouldn't a 747-8F works just as well?
747-8, 767-46 and A330 are good candidates as EMI shielding designs are already done.
bt
It will more than likely have to be a 747-8F to install and accommodate all the gear and crew though I could for see the 777 200 or 300 based approach as well.
They have the range and endurance as well. While the A330 or A350 might be useful I doubt that the USAF would turn over any modification specs to Airbus as a prime contractor. And NO doubt the USAF will have their OWN modifications in mind !!
ZaphodHarkonnen
Thu Jan 09, 2020 11:07 pm
Raptormodeller wrote:
E4B takes what? 100 people, they'll probably go for commonality with 747-8, probably the freighter or a ULR 777 or A350. A350 is unlikely because it's not American. So maybe the choice is 747-8 freighter, 777-8 or maybe a 787 on steroids. I don't see the 767 happening. Sure most of the computing power needed today could be done a couple, ok a few large PC's but the E4 needs to work in a nuclear exchange and digital electronics have a habit and not a practically fixable one of going awry under increased radiation levels etc... even more so on top of the line modern PC's whose brains work at or close to the atomic level, which is a bit shit when you're going to be bombarded by a lot of alpha particles in your mission... survive and control during a nuclear holocaust. the USAF will need the size of a 777/747 for the semi digital/analogue computers currently in use which WORK and probably very well (otherwise they wouldn't use them on their last ditch effort to command their armies), sure they'll be updated and better blah blah but you get what I mean. I don't see USAF using a 767 or even a 737 for that matter. That's my opinion on this E4 replacement....
You mention worries about computing in a bad environment like that. What do you think would happen to all the electronics on the B77X or B787 in such a situation? You'd have to add tons of equipment and shielding to deal with such things. And it'd be interesting to find out how easy it would be to make a B787 a faraday cage with the composite fuselage. Finally alpha particles are stopped by a thin sheet of paper and even beta particles are stopped by a thin sheet of aluminium. It's gamma you'll be worried about. And anything capable of taking out electronics with enough energy to destroy them will likely be a pretty quick kill for anyone in the aircraft.
The B767-2C is the front runner as it's in active production and it's big. Not 747 big, but it'll be big enough. And it already has had all the military requirement tweaks done. Anything specific to an E4 replacement is the only mods to be made.
If the USN can make do with the https://en.wikipedia.org/wiki/Boeing_E-6_Mercury then the US Sec Def can make do with something bigger but maybe not quite 747 sized.
Raptormodeller
Thu Jan 09, 2020 11:36 pm
Valid points.
A380 A330 A318 A319 A320 A321 B737 B757 B767 B747 MD80 E185 E195
AF BA QF SQ HOP LT AA
Users browsing this forum: moo and 11 guests
