JayinKitsap wrote:This E-4B would be a good time to introduce the 764F with the GEnX engines.
747classic wrote:Does somebody know what the present flight hours / cycles count is for each of the four E-4B aircraft ?
And what is the average usage /year, or is this secret (confidential) info ?
With the KC-10's still operational there is no shortage of engine(parts) in the near future, both aircraft are powered by the same basic engine (GE-CF6-50E2 and GE CF6-50C2).
Only the accessory gearbox is specially adapted (2 generators for E-4B and double hydraulic pumps- for KC-10)
texl1649 wrote:747classic wrote:Does somebody know what the present flight hours / cycles count is for each of the four E-4B aircraft ?
KC-10’s are being retired starting this month. CF6 will have a home at USAF for quite some time though thanks to C-5M’s, and VC-25B...
The E-4B’s are pretty tired/worn out (and outdated), regardless.
747classic wrote:texl1649 wrote:747classic wrote:Does somebody know what the present flight hours / cycles count is for each of the four E-4B aircraft ?
To be correct :
C-5M's are powered by CF6-80C2L1F engines.
VC-25B are powered by GEnx-2B67/P engines
Both have (very) remote family ties with the GE CF6-50 series installed at the E-4B aircraft, but hardly any identical parts.
Tired and worn (and outdated) is your perception, not based on facts, IMHO these aircraft are well maintained legacy aircraft
texl1649 wrote:The USAF doesn’t seem particularly serious about replacing the E-3/E-8, etc.
https://warontherocks.com/2019/06/is-th ... naissance/
“ The so-called iron triad of big-wing, manned ISR platforms (E-3 Sentry, E-8 Joint Stars, and various OC/RC/WC-135s, totaling about 80 aircraft) use airframes first developed in the 1950s that are rapidly approaching flight hour limits. Less visible, but vitally important, are the airmen and networks that receive, process, exploit, and disseminate the intelligence information collected by the aircraft. Air Force ISR investments increased dramatically since 2001, but can or should these investment levels be sustained as the new National Security Strategy refocuses on peer competitors? What are the current Air Force plans for its ISR enterprise?”
I don’t know what transitioning to “Publicly Available Information” really means, are they just going to scour the internet for intelligence?
Stitch wrote:JayinKitsap wrote:This E-4B would be a good time to introduce the 764F with the GEnX engines.
In the early 2000s, the USAF tried to replace the E-3, E-4, E-8 and RC-135 with the Northrop Grumman E-10 MC2A, which was based on the 767-400ER airframe. One airframe was built, but the program was cancelled before outfitting ever began so it was resold as a 767BBJ.
I don't see the USAF going back to that well.
bikerthai wrote:Definitely most cost effective in-production aircraft as all the EMI hardening and provision for defensive countermeasures comes with the new aircraft.
bt
bikerthai wrote:The article is not conclusive. Hardening for EMI occurs at different levels. The chip can be hardened, but other systems, such as wiring must be protected as well.
Remember the wiring fiasco? They had to re-design it to Mil spec? I would guess that the MIL spec may include additional EMI protection.
New systems may be able to use the hardened chip, but any commercial flight system may not neccesarily use the new chip.
And even if you harden the air frame, it only provide part of the EMI protection requirement, which includes the equipment chassis, and any rack or cabinet the equipment is enclosed.
Finally, air frame hardening is also meant to protect the humans as well.
bt
texl1649 wrote:Why is it so hard for this board to accept the fact that modern electronics don’t have anywhere near the same computational power requirements, and that Boeing has bought the last set of 748 fuselage assemblies from triumph already. Any E-4 replacement, if there is one, will not be a quad.
Phosphorus wrote:texl1649 wrote:Why is it so hard for this board to accept the fact that modern electronics don’t have anywhere near the same computational power requirements, and that Boeing has bought the last set of 748 fuselage assemblies from triumph already. Any E-4 replacement, if there is one, will not be a quad.
Well, because:
a) EMP-hardened electronics are expected to be somewhat less "up-to-date"? Like presumably "ancient" radar of MiG-25, that turned out to be EMP-grade material. Plus these kind of systems (and platforms) are expected to contain a lot of redundancy?
b) Boeing has apparently bought the last set of 747-8 fuselage assemblies indeed. The questions remain: how many of those shipsets? just enough to deliver the backlog, as it was on Jan 1, 2020, or with some spares? And yes, the backlog of Jan 1, 2020, still contained 4 orders from Volga-Dnepr. One of those is officially canceled, and the other three don't look too promising.
Enough material for this board to be kept guessing.
The four jets also ensure the Defense Secretary stays connected to forces during international travel. E-4s are based at Offutt AFB, Neb., home to US Strategic Command.
They will be replaced by a “new, cost-effective, commercial derivative aircraft” with modern communications, networking, and C2 equipment, according to the notice. Program officials want to get a head start on advanced manufacturing work to ensure that phase of the acquisition process goes smoothly.
texl1649 wrote:As mentioned, militarizing the 787 might be an option, but after the billions in losses Boeing took on the KC-46, I pretty heavily discount that is likely to happen.
texl1649 wrote:Phosphorus wrote:texl1649 wrote:Why is it so hard for this board to accept the fact that modern electronics don’t have anywhere near the same computational power requirements, and that Boeing has bought the last set of 748 fuselage assemblies from triumph already. Any E-4 replacement, if there is one, will not be a quad.
Well, because:
A. There's no indication that a future C4I platform shouldn't be 'up to date.' I fail to see the corollary to the Mig-25 radar, as certainly the USAF is not going to be buying anything remotely similar for a replacement platform, nor does the fact that it is resistant to EMP's mean the Russians are procuring anything remotely based on it moving forward.
B. Boeing has had no trouble re-selling the Volga aircraft order, to Volga's disappointment, obviously, with cargo spiking dramatically post-covid. There's also very little to zero reason to think they are trying to sell more frames or bought excess fuselage sections to sell more 747's; it's a money loser for them at the current rate and will just be wound down. They just can't afford to sustain it now as a 'prestige' VLA cargo plane.
https://www.flightglobal.com/airframers ... 80.article
Finally, there's been evidence/reporting for years that the USAF is looking for a common basic replacement type for the E-4, C-32, and E-6.
https://www.thedrive.com/the-war-zone/1 ... e-new-type
As mentioned, militarizing the 787 might be an option, but after the billions in losses Boeing took on the KC-46, I pretty heavily discount that is likely to happen. Sure, AF1 will remain as a 748 now obviously, but the other 3 look to a common type, which all but completely eliminates the 747/quads from the picture, as does this description from 7 months ago;The four jets also ensure the Defense Secretary stays connected to forces during international travel. E-4s are based at Offutt AFB, Neb., home to US Strategic Command.
https://www.airforcemag.com/e-4b-replac ... try-input/
texl1649 wrote:The electronics are just outdated. The frame is outdated, and used for hours for AF1 pilots. The engines are outdated/not in use much on the civilian side. Almost no part of a 747-200 is common in the world today. What other C3I radios/electronics from the early 70's are still current elsewhere today? What other aircraft, beside the 737 (LOL) are being produced today, similarly?
I stand by my assertion that it is a costly, worn small fleet that needs to be retired and there is no similar need for a VLA replacement.
txjim wrote:I think you would be surprised at some of the electronics updates that have occured
744SPX wrote:Aside from the 748 which if available should be the first choice, the 777-200LR would be the best replacement IMO. Its been flying long enough to be considered reliable by the AF and it can satisfy any possible power and space requirements, plus its got endurance to spare and room for OEW growth that the 767 or 787 may not have.
aristoenigma wrote:744SPX wrote:Aside from the 748 which if available should be the first choice, the 777-200LR would be the best replacement IMO. Its been flying long enough to be considered reliable by the AF and it can satisfy any possible power and space requirements, plus its got endurance to spare and room for OEW growth that the 767 or 787 may not have.
In the hypothetical (even if unlikely) event the USAF elects to go with the 748 would they likely target acquisitions: from newer freighters or newer pax aircraft currently out there? eg Saudia selling two fairly young 748Fs and one of the pax operators reportedly selling a 2016 pax airliner with only test miles on it.Are the costs to build an E-4B from a 748i substantially higher than from a 748F?
747classic wrote:However four identical 747-8F aircraft are not easy to purchase and will be no bargain (if available).
bikerthai wrote:747classic wrote:However four identical 747-8F aircraft are not easy to purchase and will be no bargain (if available).
-8F would not be a bargain, true. But would you need an F? If you are installing mission consoles, operator seats and equipment racks, then the I's with the seat tracks would be a better option.
From the aircraft variability stand point, since the -8 production run is small, have there been that much changes to the configuration? Even if there were changes, the -8 being a digital aircraft would be easier for the enginers the do the design with the digital pre assembly already available.
bt
Buckeyetech wrote:Airbus submitted a design?
bikerthai wrote:Buckeyetech wrote:Airbus submitted a design?
Technically Airbus wouldn't submit the design. It would be NG or another US company submitting a design with an Airbus aircraft.
If they do decide to get something larger than 767, what will they use to replace the current 757?
The 767 is the smallest aircraft to fit the compromise. While an A320 Neo may approach the performance of the 757, its too small to perform the other functions. If the Air Force wan one frame to do all those functions, there's not much of a choice.
bt
texl1649 wrote:I don’t think Nancy Pelosi needs an A380 for her weekend return trips to California.
In response to a series of requests for military aircraft, one Defense Department official wrote, “Any chance of politely querying [Pelosi’s team] if they really intend to do all of these or are they just picking every weekend?… [T]here’s no need to block every weekend ‘just in case’…” The email also notes that Pelosi’s office had, “a history of canceling many of their past requests.”
One DOD official complained about the “hidden costs” associated with the speaker’s last-minute changes and cancellations. “We have … folks prepping the jets and crews driving in (not a short drive for some), cooking meals and preflighting the jets etc.”
The documents include a discussion of House Ethics rules and Defense Department policies as they apply to the speaker’s requests for staff, spouses and extended family to accompany her on military aircraft. In May 2008, for example, Pelosi requested that her husband join her on a CODEL into Iraq. The DOD explained to Pelosi that the agency has a written policy prohibiting spouses from joining CODEL’s into combat zones.
We reported in 2010 that Pelosi’s jet travel cost the Air Force $2,100,744.59 over a two-year period — $101,429.14 of which was for in-flight expenses, including food and alcohol. Some details:
The average cost of an international CODEL was $228,563.33. Of the 103 Pelosi-led CODELs, 31 trips included members of the House Speaker’s family.
bikerthai wrote:The P-8 may be good for sigint, but is is based on the 737 NG platform which will be fazed out in under 5 years.
Boeing will only pitch the (formerly) MAX configuration for future military derivative platform. Having the NG configuration in their production line screws up their work flow and efficiency. Even though the P-8 is saving their bacon during the current crisis, BCA will be happy when that line finally shut down.
Stitch wrote:The P-8 is on it's own line in a separate building (4-20/21)
bikerthai wrote:The P-8 is on one line at Renton. However, at about one every three weeks, they can not afford to dedicate to the whole line to the P-8. Unless things changed since the program began, they would run the MAX through the same line. Because of the P-8, that line runs a little slower than the others.
Stitch wrote:bikerthai wrote:The P-8 is on one line at Renton. However, at about one every three weeks, they can not afford to dedicate to the whole line to the P-8. Unless things changed since the program began, they would run the MAX through the same line. Because of the P-8, that line runs a little slower than the others.
The last I heard the plan was to remodel Renton to support a total of three MAX lines in Building 4-80/81:
The pre-existing Assembly Line #1 (with seven positions?)
The pre-existing Assembly Line #2 (which was being extended to add an additional position at a right-angle to the main line for a total of seven positions?).
A new Assembly Line #3 placed between #2 and #1 (with seven positions?). This required the Fuselage Systems Installation fixture to be relocated
Boeing also added a second full MAX wing assembly line to allow six wings to be assembled at a time. Both wing lines are in 4-40/41 adjacent to the P-8 Assembly Line.
texl1649 wrote:The P-8, for various reasons (including security), really has to be a separate line.
Even with the most optimistic estimate however, they expect the P-8A line will shut down in 5-6 years. The Air Force need a frame with a production life far longer than that.
texl1649 wrote:It’s a small set of product to choose from, is all I’m asserting.
