889091
German Tornado IDS - Afterburner fails to light. Gets going after 3rd attempt
Fri Apr 10, 2020 2:46 pm
Haven't seen this posted before but here is the video:
https://www.youtube.com/watch?v=mamVCnfxjHI
Fast forward to 3:30. Pilot seems to try and light the afterburner on the starboard engine a few times, but only gets it going after the 3rd try.
What could have caused this? In addition, shouldn't the takeoff have been aborted?
wingman
Re: German Tornado IDS - Afterburner fails to light. Gets going after 3rd attempt
Fri Apr 10, 2020 3:27 pm
By the time the Luftwaffe got on station the Russians were already clubbing in Munich. Bad things happen when you're tardy.
steman
Sat Apr 11, 2020 9:32 am
Those engines are really old. It´s high time that the Luftwaffe fields in a replacement.
VSMUT
Sat Apr 11, 2020 10:51 am
I suppose it's a worn out igniter that needs to be replaced. Nothing special, it also happens on commercial aircraft with the igniters in the combustion chamber.
889091
Sat Apr 11, 2020 12:00 pm
Wouldn't it cause asymmetric thrust problems in flight if the afterburners are engaged and you have a worn igniter in one of the engines? Granted the engines are located close to each other, so it wouldn't be much of an issue, but still......
VSMUT
Sat Apr 11, 2020 12:21 pm
It would, but not more than an engine failure, which it would presumably be able to handle.
scbriml
Sat Apr 11, 2020 1:21 pm
Tornado afterburner departures are amongst my favourite...
889091
Sat Apr 11, 2020 3:02 pm
I didn't realise how smoky they are until I watched the video. Right up there with the Mig-29...
meecrob
Sat Apr 11, 2020 6:53 pm
I imagine that this maintenance has been deferred due to the plane being a demonstration aircraft. The routine has been practiced, the igniter failure known, and was deemed by the manufacturer/air force to be adequate for a certain amount of hours for demonstrations, or immediate replacement if placed into a combat situation.
...Or maybe the pilot was trying to be "fashionably late" to his own demo...
EDIT: My mistake! I assumed this was a demonstration flight. While not exactly the same scenario, I could see training flights flying with similar deferred maintenance as long as all the paperwork is in order. Basically what I am getting at is I think that everyone already knew this igniter was defective, it was not discovered to be faulty the moment it failed to light in this video.
LyleLanley
Sat Apr 11, 2020 7:48 pm
I think you're thinking way too far into this. These things happen sometimes, that's why the word 'surprise' is in the dictionary.
It didn't light, pilot re-attempted a few times, and 3rd time lucky it worked. I can't say definitively, but the other engine is pretty good evidence: if the pilot knew his right can was on the fritz he/she would probably try lighting that one first instead of parking the left engine in AB whilst attempting a burner light. Fighter pilots hate wasting gas.
"I've sold monorails to Brockway, Ogdenville, and North Haverbrook, and, by gum, it put them on the map!"
angad84
Sat Apr 11, 2020 8:36 pm
I'm just impressed the Tonka's brakes can hold it with one engine at max wet and the other at (presumably) max dry!
But this also reminded me of a joke I heard in the UK a few years ago...
Q: "What's a Tornado four-ship?"
A: "Four brief, three start, two taxi, one takes off!"
meecrob
Sat Apr 11, 2020 10:24 pm
Haha thanks for that reality check...I suddenly realized I am applying emergency virus measures to absolutely everything. Seriously I was thinking of it in terms of reducing maintenance to minimum levels. Well I'm laughing at me, hope you all are too!
LyleLanley
Sat Apr 11, 2020 11:19 pm
Ha! That sounds about right. Re: the brakes, I don't know if it's because the brakes are so good or because the motors are so anemic. All my experiences tell me Tornado engines are not the epitome of power. At least when >FL180...
No worries. Funny how we get into a mindset and have to step back on occasion. Strange times we're living in!
GDB
Sun Apr 12, 2020 10:04 am
That's because they and the IDS were designed for low level strike.
With the ADV, they were improved but even then the role of that version to loiter in the UK Air Defence area, which covered a lot more than the airspace around the UK.
In 2019, when the RAF retired the Tornado, some did ask if it's been modernised, can carry modern weapons, why retire it? The answer at least those given by crews, ground and air, was the increasing burden of keeping 30+ year old aircraft going, the RAF fleet having been constantly deployed operationally since 1990, first in Gulf War 1, was being used from Cyprus to attack ISIS, right up until weeks before retirement. Nearly 30 years of operational deployment and combat.
texl1649
Sun Apr 12, 2020 1:13 pm
Are the Saudi’s to be the final operator of Tornados? I think theirs are all, ball parking, around 30 years old?
https://www.defenseindustrydaily.com/sa ... dos-06201/
angad84
Sun Apr 12, 2020 2:38 pm
This is a good point, and reminds me that I've seen it before with our IAF Jaguars. They are the only other fast jets I've seen that can stand on the brakes with the burners at max (gets you some incredible night photos if you can time it right!)
Other jets, like Floggers and Fulcrums, actually drag the wheels a bit if the pilot is still hanging on the brakes as he pushes past max dry -- they're right on the limit for military power, and that's about it!
GDB
Sun Apr 12, 2020 3:19 pm
Yes, though a comparison of RAF and RSAF fleets I suspect would show a marked disparity in real 'age', hours and cycles as opposed to years. The Saudi's got their first ones in the mid/late 80's, a few years after the RAF, the last off the line in the late 90's were for the Saudis. So that has to be factored in.
GDB
Sun Apr 12, 2020 3:21 pm
Double post.
LyleLanley
Sun Apr 12, 2020 8:47 pm
The Jaguar is a cool jet. I had the pleasure of seeing one at Thumrait awhile back and was impressed. You're lucky to still enjoy them!
Users browsing this forum: DarkKnight5, dcchipper, transswede and 12 guests
