Max Q
The C141 Starlifter
Mon Aug 03, 2020 9:21 am
This seems to be one aircraft that’s rarely discussed here
Not the most exotic in Av history but it was in AF service for many years
Curious to know peoples opinions on this machine, particularly those who have worked on or flown it
GGg
flyingturtle
Re: The C141 Starlifter
Mon Aug 03, 2020 9:53 am
The most remarkable thing, IMO, is that this plane was lengthened - because it often hit the max payload in terms of weight, but rarely the maximum in volume.
I wonder how this hasn't been spotted during development...
Reading accident reports is what calms me down
747classic
Mon Aug 03, 2020 11:11 am
C-141 History :
The Starlifter (C-141A) was the result of a USAF Specific Operational Requitrement (SOR182), issued in May 1960, for an aircraft capable of carrying a max payload of over 60.000 lbs over 3500 Nm.
At March 13th 1962 the design of Lockheed was declared the winner.
The basic lay-out was the high wing lay out of it's C-130 Hercules, also inhertited from the Hercules were the basic fuselage cross-section and the twin wheel nose undercarriage.
The definitive contract was signed in May 1962
F/F December 17th 1963
First USAF delivery October 1964
Declared operational : April 23th 1965.
Total built : 284 Military and 1 (civil )
The standard C-141A has played a major role in the airlift of personnel, equipment and supplies to, from and wihin Southeast Asia during the Vietnam war.
However, during the US airlift operation during the 1973 Yom Kippur war, when C-141A's flew 421 missions , despite the fact that most European staging points were denied to MAC transports, the need was clearly demonstrated for providing these aircraft with air refuelling capacity and an increase in airlift volume. Budgetairy limitations, parcullary stiff in the post-Vietnam era, precluded the acquisition of a new aircraft.
Lockheed and the USAF were able to devise a scheme to fulfil at minimum costs these two requirements.
By inserting a 13 ft 4 inch fuselage plug fwd of the wing and a 10 ft plug aft of the wing, usable volume was by nearly 75% to 11399 cu ft + addition of an air refuelling boom receptacle, the C-141B was created.
The contract was awarded in 1976.
F/F C-141B at March 24th 1977
First production C-141B accepted in December 04 1979.
Operating a twin over the ocean, you're always one engine failure from a total emergency.
hk144
Mon Aug 03, 2020 11:16 am
I think you mean that the aircraft often maxed out in volume before weight, hence the extension.
VSMUT
Mon Aug 03, 2020 12:49 pm
You mean they were extended after they had been built ;) Not too many types can boast of that achievement. I know some Tu-204s were shortened.
flyingturtle
Mon Aug 03, 2020 1:49 pm
I know they were lengthened after production. But I can't understand why the designers didn't think of cargo volume during the design... as in "aluminum is cheap, air is free..."
The lengthening didn't require an engine upgrade, did it?
N328KF
The lengthening was done for a use case that didn't exist at design: transporting Minuteman missiles.
“In the age of information, ignorance is a choice.”
-Donny Miller
GalaxyFlyer
Mon Aug 03, 2020 2:04 pm
Lengthening it also added AAR capability. Nickel Grass was a significant driver in the program.
VSMUT
Mon Aug 03, 2020 2:26 pm
Likely because the payload it was designed for was different from the payload it ended up carrying. One good bet (among many other factors) is that heavy military vehicles grew in size. So while a C-141A was a good platform for hauling heavy vehicles when it entered service, by 1977 the vehicles didn't fit any more, and as a consequence the aircraft didn't match the typical payload of pallets and paratroopers.
Probably also worth pointing out that the C-5 entered service 5 years after the C-141A, which would also explain where the more dense cargo went.
Ozair
Mon Aug 03, 2020 9:42 pm
The C-141 was a jet and the sole reason it came into existence was to replace/supplement a turbo prop fleet of transports with jet speed. It had less range and payload than the C-133 but was a hell of a lot faster than the C-124.
The C-141 was never really a heavy vehicle transporter. It was sized for M113 but that was about it. Troops and pallets were its bread and butter role.
SheikhDjibouti
Tue Aug 04, 2020 12:04 am
That is the first I've heard of that.
The original C-141A was designed from the outset to carry a complete LGM-30 Minuteman intercontinental ballistic missile (ICBM) in its container.
Maybe we are somehow at cross-purposes here?
Another example were the RAF Hercules C.3 (IIRC extended by Marshall's of Cambridge)
VSMUT
Tue Aug 04, 2020 5:55 am
When the C-141 was developed, the US military was flirting with the concept of air mobile warfare. The M50 Ontos, M56 Scorpion and M551 Sheridan, possibly some of the self-propelled guns of the time. Those all fit onto the C-141 and C-130, the Sheridan was designed specifically for it. Airborne forces, including their tanks and APCs, were supposed to be airlifted quickly across the Atlantic on C-141s (among others) in case the Soviet Union ever declared war. The Vietnam war proved how useless those light vehicles were, so they quickly got replaced with more traditional equipment.
GDB
Tue Aug 04, 2020 7:20 am
Yes, Lockheed did the first one, the next 29 were done at Marshalls.
747classic
Tue Aug 04, 2020 9:40 am
A few C-141A's were completed with strengthened airframes to enable them to carry the Minuteman ICBM.
However the weight of the missile in its special container (86.207 lb) exceeded by more than a third the payload of the standard C-141A (62.717 lbs) and the modified Starlifters were restricted to a manoeuvering load factor of 2.25 g instead of the 2.5 load standard for MAC aircraft.
Length difference between C-141A and C-141B
Original uploaded by William G. Holder, USAF - U.S. Defenseimagery.mil photo no. DF-SC-83-00094
Max Q
Tue Aug 04, 2020 10:03 am
Iirc one airframe in the overall fleet was not stretched and was retained by NASA operationally for some time after the AF ended their use
GGg
zanl188
Tue Aug 04, 2020 10:43 am
IIRC there were 4 that never got stretched: 12775, 12776, 12777, and the commercial demonstrator that went to NASA.
SheikhDjibouti
Tue Aug 04, 2020 11:41 am
Just to state the screamingly obvious; lengthening the fuselage to create the C-141B did nothing to help in this respect.
In fact.. unless Lockheed sprinkled some angel dust on the whole project, the C-141B must have had a higher OEW, and therefore a lower payload max. Could it be that SAC "lost" the ability to transport Minutemans with the extended C-141B? (aside from using C-5s instead). :scratchchin:
GDB
Tue Aug 04, 2020 11:45 am
The BAC 1-11 at the Brooklands Museum was built as a series 400, then being a company demonstrator/prototype was stretched to be a -500. Then back to the original -400 fuselage length for a -475 (-400 fuselage, with -500 wings and engines.
https://www.planespotters.net/airframe/ ... bac/ro1voz
aviatorcraig
Tue Aug 04, 2020 5:44 pm
I remember seeing the NASA example at Moffett Field in the early eighties. It operated as an airborne observatory.
According to NASA historical summary, the aircraft operated with them until 1995. Does anyone know of it's eventual fate, i.e. where it was broken up?
707 727 Caravelle Comet Concorde Dash-7 DC-9 DC-10 One-Eleven Trident Tristar Tu-134 VC-10 Viscount plus boring stuff!
Moose135
Tue Aug 04, 2020 6:09 pm
They tried to sell it about just two years ago, but didn't get any takers:
https://www.avgeekery.com/nasa-put-thei ... bought-it/
Here's a cached look at the GSA auction page:
https://webcache.googleusercontent.com/ ... clnk&gl=us
From this screen shot of Google Maps, it looks like it is still at Moffett.
Raptormodeller
Thu Aug 06, 2020 1:10 pm
Yeah they looked (and still do) really good.
A380 A330 A318 A319 A320 A321 B737 B757 B767 B747 MD80 E185 E195 Q400 EF2000
AF BA QF SQ HOP LT AA BE
Max Q
Thu Aug 06, 2020 3:45 pm
What’s puzzling to me is the KC135 and its variants entered service in 1957 and is still going strong
The C141’s service entry was eight years later in 1965 yet it was retired much sooner
Why such a relatively short life for the Starlifter ?
GGg
GalaxyFlyer
Thu Aug 06, 2020 3:52 pm
The 135 flew little (SIOP alert) while the 141 flew a lot. Different missions. It also had loads of corrosion and structural problems. The tanker was also re-engined and had avionics mods which kept it up to date. Once the Buddha came along, it was obsolete, mostly because of its limited cargo box limitations. The last few years it mostly flew medevac missions.
Max Q
Thu Aug 06, 2020 4:08 pm
Ok I’ll bite, Buddha ?
GGg
GalaxyFlyer
Thu Aug 06, 2020 4:20 pm
C-17, short, fat, everybody bows down before it. It was the new, shiny object that promised to solve all mobility problems.
Max Q
Thu Aug 06, 2020 4:53 pm
Understood now
The C17 seems like a pretty good aircraft but the C141 had quite a bit more range didn’t it ?
GGg
aumaverick
Thu Aug 06, 2020 5:34 pm
Max Q wrote:
Understood now
A bit irrelevant given the AAR capabilities of both. Un-refueled distance was 500 mi +/- in favor of the Starlifter, but with a smaller payload.
I'm just here so I won't get fined. - Marshawn Lynch
GalaxyFlyer
Thu Aug 06, 2020 6:34 pm
Lockheed pushed a deal one “free” C-130 with each new build C-5M, new, not re-engined. At about the same time, a HQ AMC engineer produced a PPT briefing showing a C-5 could haul C-17 loads over C-5 distances or hail twice the load over C-17 distances. Neither were well received—Lockheed was told no more money to store C-5 tooling and the engineer was encouraged to retire.
Back to topic, the windscreen post cracking got serious and lots of C-141s were crossing the ocean at F250. Pretty expensive even for the military. Then, it would have cost $300 million to upgrade the avionics. Retirement was the easy answer. 40 years was pretty time for it.
The -17 was mod’d with a center wing tank that gave it C-141 loads with more dimensional capability over near C-5 ranges. The wing box in the -17 is loading problem for tall loads-helicopters especially but the fuel is good.
SheikhDjibouti
Fri Aug 07, 2020 12:23 pm
Notwithstanding GFs most excellent responses... you should be comparing the C-141 against other transport aircraft of that era (Boeing 707s and DC-8s). Where are they now? :scratchchin:
Meanwhile the KC-135 is still going strong thanks in no small part to the CFM-56 re-engine programme, and the complexities of out-fitting a newer design with re-fuelling capabilities (cough, KC-46, cough).
texl1649
Fri Aug 07, 2020 1:59 pm
The C model with “glass” cockpits served until the bitter end in 2004. They were good planes, but largely exhausted after Desert Storm/Iraqi Freedom etc.
http://www.amarcexperience.com/ui/index ... Itemid=101
None of them remain even at AMARG.
checksixx
Fri Aug 07, 2020 9:47 pm
The ride inside the starlifter was crap. You'd freeze at altitude and bake when you landed (in hot areas). Hated it...thank God their gone.
GalaxyFlyer
Fri Aug 07, 2020 10:05 pm
Sometimes you could freeze and bake at the same time—frozen milk on the floor and sweating at your head.
bhill
Mon Aug 10, 2020 7:18 pm
Damn straight...I STILL remember the 2 rides from Ft. Benning to Ft. Irwin back in the day.."digital HVAC" either frozen clouds coming out of the roof ductwork...or waves of heat. Field jacket on...field jacket off. And of course leaving from Benning they just HAD to bring along some troopers that needed some entries in their jump books for the pay. As soon at the blast door came out....so did the barf bags.....
Carpe Pices
Nomadd
Mon Aug 10, 2020 10:37 pm
The last 141 I was on at McCord aborted takeoff three times for three different reasons. We finally got off when an engine started burning. I was fortunate enough to be a driver most of the times I flew, so I'd just get out of those interrogation devices they called seats and sit in the Jeep.
Users browsing this forum: GDB and 8 guests
