bearnard123
Can we remake plastic waste into rocket fuel?
Mon Apr 12, 2021 11:57 am
Have you heard about the new special type of rocket fuel that is made from plastic waste? One company uses particular kinds of plastic to remake them in rocket fuel. The new kind of fuel has already been tested and the result is pretty good
Nomadd
Re: Can we remake plastic waste into rocket fuel?
Mon Apr 12, 2021 3:17 pm
You can make anything into anything. That doesn't mean it makes sense. Until none of your electricity comes from fossil fuel, none of these schemes are going to pay out.
flyingturtle
Mon Apr 12, 2021 7:44 pm
I don't think it will ever pay off. A Falcon 9 launch uses as much fuel as a fully tanked Boeing 777. The kind of kerosene used for fireworks and rocketry is not that expensive, and not such a scarce resource. If we wanted to save fossil fuels, there are more sensible avenues.
I think the intention behind such research is not making space launches more environmentally friendly. It's about developing new processes that could be quite sensible in other areas, for example turning plastic waste into chemicals that are actually difficult to produce from crude oil.
Reading accident reports is what calms me down
prebennorholm
Tue Apr 13, 2021 12:48 am
No, haven't heard that. Would be useful if you provide type(s) of rocket fuel involved. There are a few of them, for instance:
Liquid hydrogen
Kerosene
Hydrazine
Unsymmetrical dimethylhydrazine
Dinitrogen tetroxide
Monomethyl hydrazine
Hydrogen peroxide
Hydroxylterminated polybutadiene
Fluorine
Aerozine 50
Red fuming nitric acid
Ethanol
Pentaborane
Chlorine pentafluoride
...and maybe a dozen more exotic fuels not used so much. Plus there are solid fuels which are mixtures of a lot of exotic chemicals.
It would be relevant to know what type of fuel can be made from plastic waste.
tommy1808
Tue Apr 13, 2021 7:49 am
Overly simplified all plastics are pretty much still just oil. If you want to use plastic waste thermally, better burn it in a place with exhaust treatment instead of rockets.
best regards
Thomas
bearnard123
Tue Apr 13, 2021 8:07 am
The new type of fuel ( remade from plastic has already been tested. The result of the test was pretty successfull, and has shown that the new type of rocket fuel is 1% - 3% better than kerosene by its energy characteristics. Frankly to say, I am not sure if this kind of fuel can be used for long space journeys.
bearnard123
Tue Apr 13, 2021 8:13 am
Also, I wanna add that the type of the rocket fuel I`ve mentioned can be remade only from particular types of plastic.The following types of plastic can be converted into ecosene fuel: Polypropylene (PP).
Polyester (PE).
Polystyrene (PS) and their mixtures and analogs
tommy1808
Tue Apr 13, 2021 8:18 am
reminds me of https://en.m.wikipedia.org/wiki/Syntin
best regards
Thomas
bearnard123
Tue Apr 13, 2021 1:44 pm
Also, I wanna add that there is an alternative kind of rocket that has a term ``hybrid rocket`` The term ``hybrid`` was given to it because it combines solid Hydroxyl Terminated Polybutadiene (HTPB) fuel and 90% Hydrogen Peroxide (H202) liquid oxidiser.
VSMUT
Tue Apr 13, 2021 2:10 pm
It would be easier to transport into space and refine into rocket fuel at a later point. Like at a remote base on the moon or mars.
MadAstronaut
Tue Apr 27, 2021 3:46 pm
Wow, rocket fuel made from plastic waste is something really new for me. I don't understand why people negatively perceive everything. Our aerospace industry develops, and it's amazing. It's too early for me to make any conclusions about the effectiveness of this fuel, I need to spend time finding more information about it, but I think it's a rather good replacement for traditional solid fuel.
WIederling
Tue Apr 27, 2021 5:56 pm
"hybrid" rocket is any design that combines a solid and a fluid as propellant.
not even a given that the oxidizer is the fluid part. "reverse hybrid".
Murphy is an optimist
texl1649
Tue Apr 27, 2021 6:40 pm
Sure, we ‘could.’ But with the solar minimum and global cooling approaching, it would be pretty wasteful/expensive/silly to do so. A much better use of resources would be transitioning further to Hydrogen/methane for fuel a la starship. Water vapor isn’t a bad emission, and then using that to go mine asteroids. The D4 heavy for instance burns methane and oxygen, but also emits/goes thru a bunch of carbon as it ascends from the nozzle.
Kerosene will wind up fading as a propellant as it is not as clean as the other options.
bearnard123
Wed Apr 28, 2021 3:21 pm
I consider this kind of fuel a good invention, however as I have already said it is only useful for some small launches and it is not good for some long space journeys. Also, according to the words of scientists who worked on ecosence fuel, this fuel is eco friendly, so this fact makes it even better
WIederling
Wed Apr 28, 2021 4:12 pm
it has more "oompf", for sure.
But I do wonder how much energy is spent on creating that stuff?
Users browsing this forum: GCT64, jking629 and 12 guests
