aumaverick wrote:Why by the Abidas when you can buy an actual pair of Adidas? Same principle applies here: why by the knock-off F-16
aumaverick wrote:Why by the Abidas when you can buy an actual pair of Adidas? Same principle applies here: why by the knock-off F-16, which has no support outside of China, when you can buy an F-16? You answered your own question, no one wants it. The JF-17 is simply a smaller fighter that does not compete outside of a very niche order from Myanmar, Pakistan and Nigeria.
Pakistan, operates the Viper, so too does pretty much every other potential nation with a budget capable of acquiring a comparable single-engine, lightweight multirole fighter capable of all-weather operation. Any other potential export country either operates something of a Russian design or does not have the need or budget to support an aircraft without support outside of China.
VSMUT wrote:I believe that he was referring to role, not physical appearance.aumaverick wrote:Why by the Abidas when you can buy an actual pair of Adidas? Same principle applies here: why by the knock-off F-16
Huh? Since when did the F-16 grow canards? The J-10 and F-16 aren't even remotely related. Have you even seen a picture of a J-10 before?
