mxaxai
NASA’s Lucy Asteroid Mission News and Discussion Thread
Sat Oct 16, 2021 1:50 pm
NASA's space probe 'Lucy' launched today aboard an Atlas V rocket in Cape Canaveral.
https://spacenews.com/atlas-5-launches- ... d-mission/
Lucy is designed to visit several of the Trojan asteroids, which orbit the sun in Jupiter's L4 and L5 lagrange points. The propulsion system is chemical using Hydrazine and LOX (? - probably actually MON) in a single Nammo LEROS 1c engine, similar to Juno, with monopropellant hydrazine attitude thrusters.
Source and more images: https://www.nasa.gov/mission_pages/lucy/images/index
Reason: Title updated
bajs11
Re: Lucy on its way to the Trojans
Sat Oct 16, 2021 4:12 pm
It got some impressive looking solar panels.
https://www.space.com/nasa-lucy-asteroi ... ch-success
The design is based on the same design that currently powers the InSight Mars lander, only much larger. The solar panels will provide about 500 watts of power while the spacecraft is flying past the Trojan asteroids, Katie Oakman, Lucy structures and mechanisms lead at Lockheed Martin Space, which built the spacecraft, said during a news conference held on Thursday (Oct. 14).
I assume that the solar panels on Lucy is more efficient than those on Juno.
the panels on Juno generated about 486W at Jupiter while being quite a bit larger 3x 2.7m x 8.9m vs Lucy's 2x 6m diameter panels.
https://www.solarquotes.com.au/blog/nas ... ace-probe/
While Juno’s panels are highly efficient and extremely reliable, they are not cutting edge technology. This is because Jupiter is what we scientists call ‘a very long way away’ and so it took just under 5 years for the probe to get there. In addition, it takes a long time to design and build a probe and NASA, quite sensibly, values proven reliable technology over stuff that is fancy and new. So really, this was cutting edge technology back in 2005. We can do even better now.
Next decade space probes could be launched with solar panels that provide twice as much energy per kilogram as Juno’s and this may be sufficient to send solar powered probes all the way to Saturn where sunlight is only 1.1% as strong as in earth orbit. But that is in the future. For now we’ll just have to wait and see what NASA and other space programs can achieve.
mxaxai
Sat Oct 16, 2021 6:44 pm
State-of-the-art solar cells in space have an efficiency of ~ 30 to 33%. Not that much better than Juno's at 28%, certainly not enough to explain how Lucy can generate slightly more power with 22% less area. This is the supplier of Lucy's solar panels: https://solaerotech.com/space-solar-cells-cics/
GDB
Sat Oct 16, 2021 7:01 pm
Also LUCY uses images adapted from previous programs to Pluto and others, it was put together in 14 months during a pandemic, this is why I bristle when space exploration missions, particularly in this class, are called profligate, inefficient. To go and explore 8 bodies over a dozen years, bodies in an unexplored part of the Solar System, Asteroids but unlike ones previously explored.
Our assumptions about the formation of the Solar System has fundamentally changed in recent years, a factor in this mission being approved.
flyingturtle
Sat Oct 16, 2021 9:35 pm
Lucy in the sky with her diamond...
Yes, one of her optical instruments contains a diamond beam splitter. Fascinating mission!
JayinKitsap
Sat Oct 16, 2021 10:13 pm
This is a really great program, amazed I had not heard of it before now. Back in the 60's and 70's there was so much science spin off from the space program really accelerated the US tech sector. Should be doing more of this kind of project.
Tugger
Wed Oct 26, 2022 3:55 pm
So, Lucy recently slingshotted (is that a proper word? :scratchchin: ) past Earth to get a gravity boost on its journey out to the Trojan asteroids. Some people could actually see it with binocs (good ones) as it approached.
Now another pretty awesome thing from the encounter, Lucy sent back calibration images from its T2CAM. One capturing our earth-moon system which I think is awesome.
For your viewing pleasure:
On October 13, 2022, NASA’s Lucy spacecraft captured this image of the Earth and the Moon from a distance of 890,000 miles (1.4 million km). The image was taken as part of an instrument calibration sequence as the spacecraft approached Earth for its first of three Earth gravity assists.
https://www.nasa.gov/image-feature/godd ... ity-assist
Tugg
Users browsing this forum: No registered users and 36 guests
