GDB
RAF Typhoon Shoots Down Drone
Thu Dec 16, 2021 5:24 pm
As part of Operation Shader, against IS.
Not much on what sort of drone so far, it is only a drone granted, who was operating it, whether it's intentions were for recce or as a weapon too, are the more pertinent ones perhaps.
But first real world Typhoon air to air.
https://www.forces.net/news/first-air-a ... -out-syria
art
Re: RAF Typhoon Shoots Down Drone
Thu Dec 16, 2021 6:24 pm
What does a drone cost? What does an A2A missile cost? Sending drones in is a good way to drain your adversary's budget. Isn't there a more cost effective way of downing drones? An anti-drone drone comes to mind for short range defence against drones.
bikerthai
Thu Dec 16, 2021 6:34 pm
I started to dig in to this but found no easy answer.
What is the price placed a coalition soldier killed if the drone happened to be ladden with explosive?
You would wonder if they could have done a gun pass, but maybe they either did not have enough time or concerned that secondary explosion would take down the aircraft.
It is a dilemma, but until there is an effective system developed, you'll just have to eat the cost. Similar to how Israel use their expensive Iron dome to shoot down cheap rockets
bt
mxaxai
Thu Dec 16, 2021 7:26 pm
bt
Or similar to how western air forces use precision guided bombs and missiles worth $200,000 to punch holes in tents worth $3. It's how asymmetric warfare works.
GDB
Thu Dec 16, 2021 8:08 pm
I would guess that the recent history of drones, cheap as you say, at least ones from non state actors, have already demonstrated they have a disruption, sometimes lethal effect, out of all proportion to their cost.
In any case, without such dedicated ways of countering them, at least in operation - no shortage of R & D on this subject including in the UK - as is usually the case in any conflict, you use what you have. In this case a Typhoon already available almost certainly for their usual mission on Shader as on demand support against IS.
I know expensive missiles against often single high value targets, such as identfied terrorists, is at first sight disproportionate with a real risk of collateral damage.
It is also true that the two longest range confirmed sniper kills have been against these HVT’s, the longest by a Canadian sniper, the second British, however to get the sniper in the area, covertly presumably, requires SF support, their usually rotary wing transport, overwatch with airborne surveillance and ELINT assets most likey, maybe more conventional ground and air forces if a rapid and violent extraction is required in a worst case.
The point I’m making is that even the much less costly and proportionate action at first glance, isn’t quite that.
Back to this incident, we will have to see if the MoD releases more info on what sort of drone it was, it would have been visually I’d before engagement, when the pilot assesed the most appropriate weapon system, perhaps based how urgent it’s destruction was.
bikerthai
Thu Dec 16, 2021 8:22 pm
LOL. Even if they do develop a drone seaking drone, the killer drone would be more expensive than the target after you add on all the target acquisition and tracking sensors.
Will just have to wait for the air portable modular high powered laser.
bt
LTEN11
Fri Dec 17, 2021 11:18 am
I'd have a quiet chuckle to myself if it turned out to be a Russian drone.
Spacepope
Fri Dec 17, 2021 6:17 pm
bt
And there's half of the equation. The other thing is the missile's cost is also already mostly spent, they have shelf-lives, and must be reworked or scrapped after a certain amount of flights when not fired, so there is an added cost to keeping them around.
Truth be told, firing the missile is the cheapest option.
GDB
The quoted price of a ASRAAM round is reportedly £200,000.
ssteve
Fri Dec 17, 2021 6:57 pm
Right, the missile on wing rests atop a huge pyramid of money that was all invested in getting that shoot-down capability to that location. The missile itself might be $200k but represents like a $200m investment in getting it there.
GDB
Fri Dec 17, 2021 7:05 pm
....while doing a tasking the type has been undertaking for several years. It wasn't sent there to go after the odd drone.
GDB
Fri Dec 17, 2021 11:00 pm
More on the apparent intended target, which backs bikerthai's point it seems;
https://www.stripes.com/theaters/middle ... 03412.html
tomcat
Sat Dec 18, 2021 11:46 pm
It's actually good to know a fighter jet can track such a small drone and that an asraam is able to engage it. But it only takes a few more drones to exhaust the asraam loadout of a pair of Typhoons or even their entire missiles compliment.
GDB
Sun Dec 19, 2021 1:23 am
They do have cannon, many think otherwise as for a time in the 2000’s it was planned to delete it, however some Operation Shader stats released a couple of years ago, for Typhoon’s use of munitions, included not only Paveway IV, Brimstone and also occasional use of the 27mm cannon.
JetBuddy
Sun Dec 19, 2021 11:06 pm
The cost of missile argument is kind of strange. Just having a Typhoon patrol the airspace costs insane amount of money per hour. And the support structure and staff even more. The cost of the missile itself is peanuts in the big scope of things. Especially when you consider the fact that it has limited shelf life. You could also argue that it's better to spend a missile in a "real" theatre of war on a genuine target than during a training exercise on a dummy target.
tomcat
Wed Dec 22, 2021 11:28 am
Real question here: is it that easy to hit a small slow flying drone with the cannon? What's the precision of a cannon shot?
Plus someone else mentioned above the potential risks involved with using the cannon for shooting down a drone loaded with explosive (although the risks with shooting with the cannon at a fighter jet loaded with fuel, missiles and bombs must be similar though). I guess the potential risk would be to get too close from the drone due to its low speed.
canyonblue17
Sat Dec 25, 2021 4:16 pm
Wouldn't a close fly-by at high speed by a Typhoon be enough to take a drone out at little cost? I saw an F-14 take out another F-14 by flying in front of it at close range in a movie once.
bikerthai
Sat Dec 25, 2021 4:30 pm
:fever: If you go supersonic, you would not need to be too close. The shock should be able to disable any drone without worry about secondary explosions coming back at you.
bt
Spacepope
Sat Dec 25, 2021 8:34 pm
Yeah but that topless volleyball documentary had some fairly outdated tactics especially WRT MiG-28s.
When it comes down to risks between using a missile and using your airplane as a missile, I think we see the clear least worst choice in play here.
SeamanBeaumont
Sat Dec 25, 2021 10:17 pm
Folks are already complaining about the cost of the missile, imagine if he'd ingested the drone down his intake and lost the aircraft...
Spacepope
Sun Dec 26, 2021 4:32 am
SeamanBeaumont wrote:
When it comes down to risks between using a missile and using your airplane as a missile, I think kwe see the clear least worst choice in play here.
Even just trashing the engine would be way more expensive.
Fire it, don’t fire it. It makes little difference cost wise, it’s not like the missile can be returned for a refund later.
bikerthai
Sun Dec 26, 2021 6:32 am
I think we are beyond the missile cost argument. The scenerio with the gun is when they face multiple drones and the missiles are spent.
bt
johns624
Sun Dec 26, 2021 9:00 pm
Weren't the French and British running out of some ordnance back when they intervened in Libya? It might not be the cost but the number in inventory that's important.
Spacepope
Sun Dec 26, 2021 10:26 pm
Partly by design. The French used it as an opportunity to expend all its HOT stocks.
GDB
Mon Dec 27, 2021 7:35 am
No, some smaller NATO AF’s ran low on certain munitions, not the RAF or the French, either AF or navy, though some older ones like the as mentioned, their Army Aviation HOT’s ring true.
For the smaller AF’s, which IIRC included Norway and maybe the Netherlands, running low on munitions is easily fixed, by being in NATO, it possible the larger ones might do too, though worth pointing out in 2011 the RAF had been in constant operations since the first Gulf War, after the end of that they with the US monitored Iraq with regular use of ARMs and PGM’s, then the Balkans in 1995 and 1999, after 2001......
France was just about as busy in the same timeframe.
JetBuddy
Mon Dec 27, 2021 9:45 am
Norwegian and Danish F-16s flew a large amount of the sorties due to less restrictive rules of engagement.
Norway alone flew 2820 sorties over Libya and dropped 588 bombs. Denmark's numbers were very similar, if not slightly higher.
The Danes were starting to run out of munitions after dropping 487 bombs and got resupplied by the Dutch.
JetBuddy
Mon Dec 27, 2021 10:52 am
delete
johns624
Mon Dec 27, 2021 1:41 pm
What if it were a near-peer opponent?
GDB
Tue Dec 28, 2021 5:06 pm
Sounds more like how I recall it.
To the question of what if a near peer or full peer opponent? What difference would it make, still a potentially dangerous drone was headed for a US SF base.
The Typhoon was a NATO asset if this opponent wants to get pissy, as stated the RAF, closely followed by France, has been active for many years in this region.
Much commentary on this news about how this was the first UK forces shootdown since 1982, that opponent was near peer, if you add their logistics, distance and numbers advantage they were peer. The then US Secretary Of The Navy thought the RN would lose, as did the USSR.
Four decades is a long time, same distance as that conflict to the depths of WW2, still no other NATO member has gone against a peer opponent or near to that.
Not that any of this would have been on the mind of the RAF pilot nor any of the command structure they may have been communicating with.
johns624
Tue Dec 28, 2021 5:25 pm
My point was that if some of the NATO air forces were running short of munitions during this limited engagement, if the balloon ever went up, they'd be in real trouble.
bikerthai
Tue Dec 28, 2021 7:01 pm
Wot? Even I did not believe the Argentinian had a chance. The only question I had was the casualty rate.
bt
GDB
Tue Dec 28, 2021 9:22 pm
bt
Aside from the large advantage in aircraft numbers, they had weeks to prepare, the UK forces supply line was long and potentially vunerable, over the previous 15 years the UK forces had gone from an East Of Suez and NATO posture, with the costs and strain of doing both increasing, to a NATO one, with some residual ‘out of area’ ability from the NATO flanks commitment. The RN were heavily ASW orientated. Which as it turned out meant the RN were not short of SSN’s, for this operation and NATO, one of which put the enemy navy out of the conflict and probably impacted on sealift for them too.
Which brings us to the issue of munitions, in the ‘82 war it is just as well that they surrendered when they did, as ammo was getting very low despite the massive logistics operation, it was the sheer distance and illustrates that by no means all of the enemy ran or surrendered, it was the basics for the troops not expensive munitions running low.
To come back to now, I think since 2014 Putin’s actions have created, perhaps forced even, a step change in NATO’s thinking. The commitment to have a 2% minimum defence spend in 2015, now some may deride it, say some are fudging it, even so the trend is upwards and some of that inevitably will be in munitions. NATO have joint AWACS, a transport/tanker unit, maybe one for munitions stocks, jointly funded too.
Using chemical weapons on the streets of a NATO member too. Here allow a caveat, I go easy on the European NATO members often cited as not doing enough, since the UK isn’t much better, the current bunch are total bullshitters on this as with everything else. After the 2018 attack on our soil yes they responded, but for context look up ‘Operation Foot’ for a more approriate response.
Though in reality, back to munitions stocks, as we have seen, NATO members help each other in this way. Going back to that unexpected conflict, those 103 AIM-9L’s were from NATO stocks, in the form of the USN in Europe, RAF Germany then being some months away from being the first UK recipient.
fsnuffer
Wed Dec 29, 2021 3:55 pm
art wrote:
These weapons all have a shelve life. If they didn't use it to shoot down the drone, at some point it would have been used for training. Two birds with one stone.
GDB
Wed Dec 29, 2021 8:35 pm
fsnuffer wrote:
Indeed. Plus there is an upgrade round coming;
https://ukdefencejournal.org.uk/asraam- ... n-by-2024/
Users browsing this forum: 4l4R1, bennett123 and 37 guests
