889091 wrote:Hot and sandy desert operations in Kuwait to hot and humid conditions in Malaysia. Will premature corrosion be a potential problem?
GCT64 wrote:Malaysia already has 8 X F-18Ds, the article talks about procurement of another 33 F-18C/Ds from Kuwait but they have 31 F-18Cs and 8 F-18Ds I believe (1 less than supplied (that one crashed) and from which total a number of Cs and Ds are withdrawn (are these in storage or scrapped or stripped for parts?)).
N328KF wrote:How did they wind up with a a fleet of just 8 D models? And what happened to all of the MiG-29s that they still had as of 2017?
GCT64 wrote:N328KF wrote:How did they wind up with a a fleet of just 8 D models? And what happened to all of the MiG-29s that they still had as of 2017?
8 x F-18Ds is all they ever bought directly
The Mig-29s are withdrawn from use, believed to be stored at Kuantan
GCT64 wrote:889091 wrote:Hot and sandy desert operations in Kuwait to hot and humid conditions in Malaysia. Will premature corrosion be a potential problem?
About a year ago The Drive said "Of all the ‘legacy’ Hornets, the surviving Kuwaiti F/A-18C/Ds are among those in the best condition, and in the past, both Canada and Malaysia have expressed interest in buying them."
N328KF wrote:GCT64 wrote:N328KF wrote:How did they wind up with a a fleet of just 8 D models? And what happened to all of the MiG-29s that they still had as of 2017?
Understood, but why the small fleet?
ThePointblank wrote:GCT64 wrote:889091 wrote:Hot and sandy desert operations in Kuwait to hot and humid conditions in Malaysia. Will premature corrosion be a potential problem?
I once chatted with someone who once looked over the Kuwaiti Hornets for Canada, and they were not impressed with the condition of the Kuwaiti jets. Something about their jets being in worse shape than their age in years actually implies.
N328KF wrote:GCT64 wrote:Malaysia already has 8 X F-18Ds, the article talks about procurement of another 33 F-18C/Ds from Kuwait but they have 31 F-18Cs and 8 F-18Ds I believe (1 less than supplied (that one crashed) and from which total a number of Cs and Ds are withdrawn (are these in storage or scrapped or stripped for parts?)).
The Kuwaiti jets were kept outside for the majority of the time they've had them. I'd be shocked if anyone actually wanted them...
texl1649 wrote:checksixx wrote:ThePointblank wrote:I once chatted with someone who once looked over the Kuwaiti Hornets for Canada, and they were not impressed with the condition of the Kuwaiti jets. Something about their jets being in worse shape than their age in years actually implies.
Amazing that the Kuwaiti’s wouldn’t shell out the dough for some AC’d shelters for their fleet(s) of $70+ million aircraft. Wow.
That’s not common for Qatar/Saudi/UAE, is it?
The desire to boost Malaysia’s air defenses have added impetus with the widely publicized flight of 16 Chinese transport aircraft over a disputed South China Sea shoal in late May. The Chinese jets approached to within 60 miles of Malaysia’s coast and prompted the RMAF to scramble Hawks in response.
They are operated from Ahmad al-Jaber Air Base where, if you look at satellite imagery, you can that the few HAS's are still damaged from GW I bombing in 1990. There are, however, plenty of sun shelters on the ramp for all the F-18s as well as large, presumably environmentally controlled, hangars. The hangars look to be able to house all the F-18s if required.
Not to mention the sand that happens to get everywhere, including the engines, and the fact that the Kuwaiti birds have not gone through a structural life extension.
Do they need a SLEP... I doubt the Kuwaitis have flown them as much as comparable little bugs in other places, or to as much consistent G.
This is Malaysian Air Force we are taking about, they are used to equipment that doesn't work all the time and in need of repair. If they got 33 bugs from Kuwait and had 16 additional flyable aircraft plus spares I'd call that a win for them.
ThePointblank wrote:SeamanBeaumont wrote:ThePointblank wrote:Not to mention the sand that happens to get everywhere, including the engines, and the fact that the Kuwaiti birds have not gone through a structural life extension.
The Hornet has a structural life limit of 6,000 hours, which relatively low for a fighter jet. The main issue is the centre barrel; while the rest of the airframe can fly longer, the centre barrel tends to delaminate and show stress fractures fairly early in life because it is a high stress component where the wings, tail, main landing gear and front fuselage all meet up.
With a centre barrel replacement, the Hornet can add an additional 2,000 hours of life, and with inspections, you can push a Hornet out to 10,000 hours of life. However, the centre barrel replacement isn't cheap; the US Navy says to do a centre barrel replacement at one of their fleet readiness depots is about $2-3 million dollars per aircraft.
SeamanBeaumont wrote:ThePointblank wrote:SeamanBeaumont wrote:Do they need a SLEP... I doubt the Kuwaitis have flown them as much as comparable little bugs in other places, or to as much consistent G.
I know that dude, question again... Do they need a SLEP...?
How many hours do the jets have on average? The Aussies only centre barrelled 15 out of their 70+ fleet so not every one has to have it and the Malays don't exactly rack up the hours.
889091 wrote:Apparently RMAF is out, USMC is in.
Considering what has been discussed so far (tired frames for its age), it's a little surprising.
https://theaviationgeekclub.com/usmc-al ... -fighters/
N328KF wrote:889091 wrote:Apparently RMAF is out, USMC is in.
What exactly does the USMC want with these tired old birds?
SeamanBeaumont wrote:N328KF wrote:889091 wrote:Apparently RMAF is out, USMC is in.
USMC are still flying little bug until about 2030 so more spares for their fleet same way they grabbed the UK harriers.
