flyingturtle
Stirling engines in space
Tue Jan 04, 2022 4:35 pm
On JWST web site, you see that the hot side of that thing is about +60 °C, but the cold one is about -190 °C.
All a Stirling engine does is converting a temperature difference into motion, which in turn could drive a generator.
Apart from introducing more movable parts (and thus more failure modes) into the spacecraft, would a Stirling engine make any sense?
Or would it fail because the vacuum does not conduct heat very well - the Stirling engine would equalize the temperature difference between the hot and the cold side of the spacecraft too fast, with no coolant that keeps the dark side of JWST cool?
bikerthai
Re: Stirling engines in space
Tue Jan 04, 2022 4:43 pm
How about comparing efficiency of stirling engine with thermalelectric metals?
The thing is, even though you do have high temperature difference, is there enough power density to make it work?
bt
Nomadd
Tue Jan 04, 2022 5:22 pm
It would make as much sense as a perpetual motion engine. They're cooling that thing for a reason, and pumping heat back into the cold side to power a Sterling wouldn't make a lot of sense.
ssteve
Tue Jan 04, 2022 9:00 pm
There are some links here which might lead to other NASA research efforts with Stirling in the name:
https://en.wikipedia.org/wiki/Advanced_ ... _generator
I didn't actually realize that the ASRG effort had been mothballed.
flyingturtle
Wed Jan 05, 2022 7:13 pm
Oooof. Nooooo! There goes my idea...
Users browsing this forum: No registered users and 42 guests
