Aussiemite
What Sort Of Life Do You Get From Your Raz0r?
Wed Jan 02, 2002 10:28 pm
Ive used a number of shicks and I am continually unimpressed they seem to last 7-10 uses and after about 3 they turn to shit.
I've used a braun electric for ages which is great but I prefer good old dangerous blades.
DC10Tony
RE: What Sort Of Life Do You Get From Your Raz0r?
Wed Jan 02, 2002 10:41 pm
I use a Sensor and I throw the blade away each week.
I tried the Mach3 when it first came out, but I didn't like how it missed spots in order to conform to your face.
I was thinking about trying an electric razor, but I think I'll stay with a razor, it gives a closer shave.
174thfwff
Thu Jan 03, 2002 1:43 am
I use mach 3, it's pretty nice.
-=PEace In=-
174thfwff
Brooklyn, Queens, Manhattan, Staten, Uptown, what now? Lets make it happen.
iflycoach
Thu Jan 03, 2002 1:55 am
I got Norelco Quadra Action Razor for Christmas, but before that when I was shaving with blades I could get about 10 days out of a razor before the thing wouldn't cut hair anymore.
Also if you enjoy the razors, a cheap way to do it is go to Costco and get a 50 pack of the disposables. Teen you can then just throw them away when they slightly go bad!
Turbolet
Thu Jan 03, 2002 3:19 am
Atm I'm using Sensor Excel, but I can't tell the difference between a shave with the Sensor Excel and a disposable razor. The disposables usually last me around five uses, Sensor Excel lasts longer, that's the only difference.
-turbolet
KROC
Fri Jan 04, 2002 6:46 am
Depends. I am such a cheap bastard, I don't toss the razor away until I take at least 5 plus layers of skin off in a shave. I liked the Mach 3, but then started using the Schick Triple blade deal. I think it works better, and is cheaper.
Aerialpingpong
Fri Jan 04, 2002 10:28 pm
I have very thick facial hair and shaving with anything less than a fresh blade is an excruciating experience (razor cuts halfway through hairs, then proceeds to try to pull them out...Grrrrrr.....). I usualy buy the cheap Gilette disposables (fixed, non-pivoting blade) and throw hem away after a maximum of two shaves, usually one.
Users browsing this forum: ArchGuy1, FGITD, skyservice_330, stl07, WarRI1 and 1 guest
