No, he just starts a weekly garbage threads about Democrats, or allies he doesn't like, or something like that-most of which turn out to be from dubious sources, and then he doesnt have the balls to admit he was wrong.
Interesting how you have the nerve to cry only about B757300's threads about Democrats, when for each thread he posts, you have 20 others about Bush and conservatives, usually from shitty sources or just composed of opinionated bullshit.
Just bitching and crying about one side of the issue -- the one which is opposite of your side which does the same very thing that you cry about.
Typical.
And, of course, NWA742 can always be found covering the asses of fellow conservatives
I see no problem defending those whom I share many views with. As if you wouldn't do the same, hypocrite?
Also, I'd rather defend those I see fit rather than behave in a manner like you which would be making an ass out of myself time and time again.
You are consistent, NWA742. You'll damn a "liberal" for the same things you defend a conservative for. Well done.
Oh the irony!
That seriously made me laugh hard, because you sit here and damn a conservative for posting threads about Democrats, but you seem to have no problem at all when it happens 20 times more from your own side.
Losing credibility by the post, Alpha.
Oh one more thing, before you try to say that I do the same thing just in vice-versa again, I don't have a problem with B757300's threads, and it's not because he's a conservative, it's because he doesn't do it near as often as a lot of others do, and it also helps to balance the equation of politically slanted posts on the website. Fine by me, no matter what side he's on.
NWA742
