futuresdpdcop
How Often Do You Clean Your Ears Out With A Q-tip?
Sun Jul 09, 2006 9:06 am
Useless weekend thread...
How often do you bust out the Qtip and clean the ears???
halls120
RE: How Often Do You Clean Your Ears Out With A Q-tip?
Sun Jul 09, 2006 9:13 am
About every third day. Should do it more often.....
"Suppose you were an idiot. And suppose you were a member of Congress. But I repeat myself." Mark Twain, a Biography
Shawn Patrick
Sun Jul 09, 2006 9:14 am
I don't use q-tips, I use the screw-in end of my cellphone antenna, it works really well. I do it whenever I can't hear very well.
Curtisman
Sun Jul 09, 2006 9:17 am
Absolutely never!
I used to be a daily Q-Tip type of guy. Then one day I was chatting it up with some nurses and we were talking about this very topic. After a bit of education from them I decided not to use Q-Tips ever again.
Cheers!
Len
Citizen of the World
bill142
Sun Jul 09, 2006 9:19 am
What the hell is a Q-tip?
Curtisman
Sun Jul 09, 2006 9:23 am
Quoting Bill142 (Reply 4):
Hehehehe
For those of you down under, a Q-tip is known as a Cotton Bud.
Cheers!
Len
Klaus
Sun Jul 09, 2006 9:26 am
Washing you ears also works very well...!  mischievous
ABfemme
Daily even though I know it's bad........Whoops
Women do not have hot flushes, they have power surges
BMIFlyer
Sun Jul 09, 2006 9:28 am
Ear drops can work wonders.........
Lee
luv2fly
Sun Jul 09, 2006 10:08 am
Every other day with a q-tip and never had a problem with that schedule.
KFLLCFII
Sun Jul 09, 2006 10:09 am
Everytime I shower, so every morning + any subsequent occasions thereafter during the course of a day.
When I'm done, it's the standard dry-off, comb the hair back, and clean out the ears...
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
SP90
Sun Jul 09, 2006 10:46 am
Quoting CurtisMan (Reply 3):
Care to share this bit of knowledge?
IAH777
Sun Jul 09, 2006 10:49 am
Quoting KFLLCFII (Reply 10):
ANCflyer does the same, but he actually has to comb the hair in his ears.  old
I have to clean-out my ear canal every other day, at the latest, as I wear an in-the-canal hearing aid that tends to plug-up if I don't.
WhyWhyZed
Sun Jul 09, 2006 11:04 am
I use a Q-tip daily. Cleaning out my ears is usually one of the first things I do, after a nice refreshing shower. The feeling of liquid (water from shower) in my ear drives me insane.
Please do share this information with us, Len.
- Jason DePodesta
AC773
Sun Jul 09, 2006 11:25 am
If I feel there's an excess of wax, I'll get at it with a rolled up kleenex after I've had my daily shower. The wax is diluted with water at this point, so it goes easily.
I must have been slacking off lately, because last week when I went to the doctor for my annual check-up she recommended an ear cleaning. The nurse wheeled in a fearsome-looking 1940's apparatus. It was basically a vacuum pump hooked up to a water tank with a hose and a long, thin needle-like attachment at the end. That was a nightmare, to say the least. I felt queasy for about an hour afterwards, and my ears are only now starting to feel normal again. Suffice to say I won't be doing that again anytime soon!
Better to be nouveau than never to have been riche at all.
joness0154
Sun Jul 09, 2006 11:32 am
Well my mom is an audiologist, so I never use a Q-tip to clean my ear. If you have even a slight buildup of wax, putting a Q-tip in your ear will jam it further down your ear canal rather than getting rid of it. Old wax can make you more prone to ear infections, etc. Your hearing will also start to degrade some. You're also more at risk of poking a nice hole in your eardrum if you go down too far...
I don't have an attitude problem. You have a perception problem
IFEMaster
Sun Jul 09, 2006 12:16 pm
Never, but I do direct the shower-head to stream in to my ears every couple of days and wash things out. Believe it or not, ear wax is there for a reason.
Delivering Anecdotes of Dubious Relevance Since 1978
Curtisman
Sun Jul 09, 2006 12:29 pm
Quoting SP90 (Reply 11):
Well Reply #15 pretty much sums it up.
Quoting Joness0154 (Reply 15):
Q-Tips can push the wax into the ear. I used to use a Q-Tip daily - it was part of my morning routine - I just had to do it. I went cold turkey when I stopped. I used to have a lot of trouble hearing out of my left ear and since I've stopped, my hearing has imporved over the years.
I now clean my ears each day when in the shower - just use shampoo and wash. I was afraid wax would show in my ears - but it doesn't!
There you have it kids!
Cheers!
Len
JAGflyer
Sun Jul 09, 2006 12:44 pm
I can't figure out how to remove wax. I don't want to go too deep for fear of hitting the eardrum. Usually I let it become a problem (muffled sound) before I go to the doctor to have him do the syringe thing. My hearing is perfect after. Everything sounds so loud and clear. The procedure isn't painful but it's not the most pleasent thing.
[Edited 2006-07-09 05:46:43]
If you flew today, thank a Flight Dispatcher!
kmh1956
Sun Jul 09, 2006 1:08 pm
Quoting JAGflyer (Reply 18):
Use a dropper filled with warm water and drop a bit of warm water in there. leave it long enough to loosen things and then tilt your head to the side with a tissue underneath. It should all run out quite happily. Repeat with other ear.
Q-Tips should only be used for the outer ear, inside the edge and what-have-you where you may get soap or shampoo left after a shower.
'Somebody tell me why I'm on my own if there's a soulmate for everyone' :Natasha Bedingfield
Garri767
Sun Jul 09, 2006 1:14 pm
Q-tips go in your ear?
signed,
Jap
Two wrongs may not make a right, but three lefts do!
Bobster2
Sun Jul 09, 2006 1:22 pm
I use ear drops to loosen the was and a WaterPik to blast it out.
DISCLAIMER: Don't use WaterPik without professional guidance.
"I tell you this, no eternal reward will forgive us now for wasting the dawn." Jim Morrison
Duff44
Sun Jul 09, 2006 1:43 pm
Quoting IFEMaster (Reply 16):
Same reason you have mucus in your nose.... catches dirt/dust/foreign matter and keeps it from getting where it shouldn't
I'd say I do the Q-tip once a month, and a regular tissue maybe once every 10 days or so...
I'll rassle ya for a bowl of bacon!
andz
Sun Jul 09, 2006 2:37 pm
Never. My mother taught me you should never put anything in your ear that is smaller than your elbow!
deltagator
Sun Jul 09, 2006 3:04 pm
Everyday despite the warnings as a kid. I had an ear infection a couple of years back and the doctor at first thought I had lost my hearing because of wax buildup but after looking in them she remarked at how clean and wax free they were. I'm very careful and know how deep I can go without touching the eardrum.
aa61hvy
Sun Jul 09, 2006 3:06 pm
Twice a day...I hate ear wax
Go big or go home
jcs17
Sun Jul 09, 2006 3:26 pm
I don't have bad ear-wax at all, so I'll clean my ears out every few weeks. The sad thing is that I have this Costco-sized thing of Q-tips and over a couple years I've barely made a dent in the thing.
America's chickens are coming home to rooooost!
baylorairbear
Sun Jul 09, 2006 3:41 pm
I never use Q-tips. I prefer something more slender that allows a scraping action so I can dig the wax out. That prevents the pushing of wax farther into the ear canal.
BAB
I'm just skipping stones...
KevinL1011
Sun Jul 09, 2006 3:52 pm
I use a cordless Black and Decker 3/4" drill and chuck up a 1" paint roller cover into it. Saves time and does a helluva job.
474218, Carl, You will be missed.
baylorairbear
Sun Jul 09, 2006 3:54 pm
Quoting KevinL1011 (Reply 28):
 rotfl
I never considered that! Of course, I'm a Dewalt man, myself. I'd probably opt for a tapered 1/2'' grinding stone.
BAB
misbeehavin
Sun Jul 09, 2006 4:49 pm
Quoting FutureSDPDcop (Thread starter):
Every morning after a shower and (almost) every evening after a swim... Not so much to clean the ears but to dry them.
Aeroflot777
Sun Jul 09, 2006 5:27 pm
Everyday after my morning shower. I don't know where most of you are getting this weird info about it being bad. I have used a Q-tip everyday of my life, and yet have perfect hearing and have not had the need to go to the docs to have him use some apparatus. But most importantly my ears are clean. It's a part of regular hygiene. Why would you want to go around with yellow wax in your ear....
Aeroflot777
ME AVN FAN
I do the Qtip cleaning daily, somewhere during the day.
raffik
Sun Jul 09, 2006 6:04 pm
Daily for me, too. It's important to remember that you shouldn't use the cotton tip to penetrate the ear- seek help from your doctor if you have issues with wax.
- Alec
nitrohelper
Sun Jul 09, 2006 9:31 pm
Every day after a shower , I got a nasty case of "swimmers ear" many years ago from a shower. After that I dry my ears with a Q-tip, not going too deep,and no problems since, no wax build up ever. I believe the hot shower helps soften the wax so it is absorbed on the Q-tip rather than being pushed in the ear ?
duke
Mon Jul 10, 2006 12:16 am
Eww, never. I hate seeing people do it, too. My mother/grandmother cleaned my ears like that when I was a kid, and it wasn't very pleasant. Plus, the ends of the Q-tips looked gross. I clean my ears with water and my fingers, as far as the fingers will go. No I don't have any problems with my ears. If anything, by pushing things up your ears, you risk injury.
I was told of a guy who had that "ear cleaning" done by a doctor and went deaf! He was actually gullible enough to let the doctor clean the other ear after he had gone deaf in the first ear...had the same result in both ears. Auuugh.
jap
Mon Jul 10, 2006 12:28 am
Quoting Garri767 (Reply 20):
signed,
Jap
 rotf  Wtf?!
I mean...  grumpy
Scandinavian chick with a scandinavian horse- oh yeah! :D
ME AVN FAN
Mon Jul 10, 2006 4:52 pm
Quoting Duke (Reply 35):
you neither should PUSH nor should you go too far into the ears !
ba757
Mon Jul 10, 2006 5:03 pm
Quoting CurtisMan (Reply 5):
Hehehehe
I must admit I wondered what the hell a Q-tip was and i'm not down under... just the other side of the pond  Wink
Adam
BigOrange
Wed Jul 12, 2006 1:59 am
Usually every couple of weeks.
I dip the Q-Tip in peroxide first then stick that in my ear to loosen the wax. Then I use the other end of the Q-Tip to clean out the wax.
legoguy
Wed Jul 12, 2006 7:34 am
If you don't clean out your ears often with Q tips, you might end up like Father Jack from father Ted! Made candles out of his ear wax  Silly
I swim, so I find that my ears don't need cleaned as they seem to be clean when I come out of the pool.lol.
Can you say 'Beer Can' without sounding like a Jamaican saying 'Bacon'?
jumpseatflyer
Wed Jul 12, 2006 2:54 pm
I do it a lot. Not just to get the wax out. But because it feels great. An inner ear massage. In fact, I'm going to do it right now.
Wed Jul 12, 2006 4:14 pm
Why the Name.
regds
MEL
milan320
Wed Jul 12, 2006 4:21 pm
Exactly how I got my ear infection.
And when I went to my doctor, he said to remember one good piece of advice when it came to cleaning your ears: "The only thing that you should stick inside your ear is your elbow." - meaning of course, don't put anything in your ears.
-Milan320
I accept bribes ... :-)
malmoaviation
Wed Jul 12, 2006 4:35 pm
I clean them once a week. Not too often, not to rarely. That's my three ( ! ) cents. (I'm a rich bastard!! Big grin )
SWA TPA
Thu Jul 13, 2006 7:23 am
I do it every day after my shower. Not so much to clean them out but because it feels so darn goooooood!!!!!  Smile
SWA TPA
I believe I can fly.....
baylorairbear
Thu Jul 13, 2006 7:34 am
Quoting HAWK21M (Reply 42):
Why the Name.
Q-tips is just the brand name.
BAB
SmithAir747
Thu Jul 13, 2006 7:37 am
I have no need to clean my ears out at all with Q-Tips or anything else.
Why?
Because I have no ears!  Big grin
SmithAir747
I will praise thee; for I am fearfully and wonderfully made... (Psalm 139:14)
SWA TPA
Thu Jul 13, 2006 7:43 am
Hi SmithAir747! Your bird at the LHR perimeter is called a Starling  Smile
SWA TPA
Users browsing this forum: Airontario, Bing [Bot], flyguy89, Number6 and 111 guests
