lehpron
Does Hot Water Rise Like Air?
Thu Nov 29, 2007 1:12 am
If I had a column of water with a heat source at the base, will the warmer water rise and allow the lesser warmer water recirculate without a pump, or will the water near the heat source simply get hot?
ArmitageShanks
RE: Does Hot Water Rise Like Air?
Thu Nov 29, 2007 1:21 am
It will work just like air, just maybe a bit slower.
http://en.wikipedia.org/wiki/Convection
Zkpilot
Thu Nov 29, 2007 1:28 am
hot water rises.. Happens in the ocean all the time.
64 types. 45 countries. 24 airlines.
Queso
Thu Nov 29, 2007 1:29 am
Easy enough to prove. Get an aquarium filled with normal tap water, fill a coke bottle with hot water that has food coloring in it, submerge it in the aquarium and open the lid.
Not exactly Mythbusters material, but you'll get your answer.
ronglimeng
Thu Nov 29, 2007 1:52 am
So hot water rises.... then cold water falls.
Would someone like to explain why lakes and rivers don't freeze from their bottoms up to the surface? I think it happens the other way around.
Fly2HMO
Thu Nov 29, 2007 2:03 am
Quoting Ronglimeng (Reply 4):
It's not so much a top to bottom, it's more like outside-inside. That's why sometimes you'll get ice cubes in the freezer that haven't been in there long enough with bubbles of water in between the ice.
NeilYYZ
Thu Nov 29, 2007 2:09 am
I would think that is because it needs to be below 0 centigrade for water to freeze, and what makes the water freeze is the cold outside air, which hits the water at the surface.
For the water to freeze from the bottom up wouldn't the temperature of the ground at the bottom of the body of water have to be colder than the outside air?
It may be too early to drink scotch... But it is NEVER too early to think about it...
ArmitageShanks
Thu Nov 29, 2007 2:20 am
Quoting NeilYYZ (Reply 6):
Also, doesnt water pressure have to do with it as wee? Even though its below freezing at the bottom of the ocean its still liquid.
Queso
Thu Nov 29, 2007 2:33 am
Quoting ArmitageShanks (Reply 7):
Wee is at body temperature when it is released but it cannot be used to judge whether or not hot liquid rises because it has a different specific gravity than water. You could measure some cold wee and then put warm wee in it to see if it rises, but water would probably be easier to work with.
AverageUser
Thu Nov 29, 2007 2:58 am
When water cools down to 4 C it has reached its maximun density and sinks to the bottom, thereafter the natural convection is limited to the layers closer to the surface only, the top of which which may then freeze as ice when the temperature drops further. A cover of ice will then act as thermal insulation to the water, but will also self-limit its own growth because of this capability.
PlymSpotter
Thu Nov 29, 2007 3:00 am
Quoting Lehpron (Thread starter):
I'm about 99.9% sure that you already have one of these. It's called a kettle.  Smile
Toast
Thu Nov 29, 2007 3:09 am
Quoting Queso (Reply 8):
 rotfl  rotfl  rotfl  rotfl  rotfl
Good one Mr. Cheese!  bigthumbsup
Shit Piss Fuck Cunt Cocksucker Motherfucker Tits
vikkyvik
Thu Nov 29, 2007 3:19 am
Believe so, yes. If I remember correctly, you can find super-cooled water at high water pressures (water that is below 0 C, but is still liquid).
Klaus
Thu Nov 29, 2007 3:21 am
Frozen water is less dense than liquid water ("ice swims"). If it was th other way around, the oceans would be a solid block of ice down to the ground with possibly a thin layer of liquid water on top.
Toast
Thu Nov 29, 2007 3:24 am
Quoting Klaus (Reply 13):
Quoting PlymSpotter (Reply 10):
Quoting Toast (Reply 11):
Guys, we're in Europe and it's 4:20 in the morning. It's nice to know I'm not the only insomniac here, but I think going to bed is preferable to discussing physics. Good night!  zzz
PlymSpotter
Thu Nov 29, 2007 3:29 am
Quoting Toast (Reply 14):
3:30 actually, I'm in the UK  Wink But yes, with lectures commencing in six and a half hours, its time to hit the hay as well!
Klaus
Okay, now we know what a "cyber-nanny" really is.
Stay crispy!
PPVRA
Thu Nov 29, 2007 3:37 am
Yup, it's how these work:
"If goods do not cross borders, soldiers will" - Frederic Bastiat
CastleIsland
Thu Nov 29, 2007 3:39 am
Actually, it's entirely possible that if it were the other way around, the water body might never freeze. Here's why: Since the surface of the water body is closest to the cold air, ice would sink and then melt on its way down, since the heat capacity of water is so high, much of a water body remains well above freezing even when it's well below freezing air temperature. Thus, the only way to get the water body to freeze would be an extremely rapid cold snap that would inundate the water body floor with ice that could cool the lower strata of the water body to near freezing before the ice melts.
This is particularly true of oceans, which have a significantly depressed freezing point due to high salinity.
"People don't do what they believe in, they just do what's most convenient, then they repent." - Dylan
L-188
Thu Nov 29, 2007 3:54 am
Yup, many of the laws that govern air movements are equally applicable to liquids.
The ice forms at the surface because it is less dense then the water under it. It is less dense because unlike everything else in the known universe it expands as it freezes. This traps oxygen and also make ice a halfway decent insulator.
Actually you can credit this little property for permiting life to exist on this planet, because the water stays fluid under the ice.
Yup, the same Volume/Pressure/Temperture law that covers everything from airfoils to steam engines.
Klaus
Thu Nov 29, 2007 4:16 am
Quoting CastleIsland (Reply 18):
But that is exactly just because of the special property water possesses - if ice was heavier than liquid water, the convection would continue to transport heat to the surface and increasingly cold water to the bottom, until the entire water column was frozen (if at least partially the air temperature was cold enough for ice to form).
nighthawk
Thu Nov 29, 2007 12:00 pm
Ahhh all those chemistry lectures are flooding back. The reason ice floats is due to Hydrogen Bonding. If you take any othe rliquid, (say alcohol) and freeze it, the molecules lose energy, and start to contract together, producing a solid which is much denser than the liquid form, as such the solid of a substance will always sink when placed in its liquid form.
Water is different. Hydrogen has a special property: hydrogen bonding. Two molecules of hydrogen will attract to each other and form a very weak bond. When water is frozen, the molecules lose energy and stop moving, and start to contract. Once energy is lost beyond a certain point, the hydrogen bonding comes into play, and the hydrogen molecules will attract towards each other, and at the same time repelling the oxygen molecules. this causes the density to start to decrease, as the molecules once more spread out. The ice is therefore less dense than the water, and the ice floats.
ALexeu
Thu Nov 29, 2007 12:05 pm
Could Bernoulli's princip work in water?
As the air gets faster, the pressure is lower (that's the basic Bernoulli's equation). p+1/2rho*vo^2=const.
ronglimeng
Thu Nov 29, 2007 4:37 pm
Quoting AverageUser (Reply 9):
AverageUser:
I think you get the prize.
Thanks to all.
Ronglimeng
D L X
Thu Nov 29, 2007 4:51 pm
Gross.
(And I think he meant "well", not "wee")
Quoting AlexEU (Reply 22):
Absolutely! That's how a hydrofoil works (an airfoil for water). You can also experience this with a water hose. Place your index finger and thumb opposed to each other, like you're trying to grasp the water coming out of the hose. If you turn the water up higher, it will feel like it's pulling your finger and thumb together.
David L
Thu Nov 29, 2007 6:08 pm
Quoting FLY2HMO (Reply 5):
It might have something to do with it but it's not the main reason.  Smile
Ditto.  Smile
Quoting L-188 (Reply 19):
Bingo! Though it's below 4oC that water (and ice) is less dense.
Quoting Nighthawk (Reply 21):
 thumbsup
Funny stuff, water.  Smile
bagpiper
Thu Nov 29, 2007 6:18 pm
Quoting D L X (Reply 24):
Gross.
Oh come on dude, where's your sense of humor? Of course he meant "well".
Queso - I laughed long and hard at that  Silly
lehpron
Fri Nov 30, 2007 12:16 am
Thanks everyone for the replies, I suppose I knew it but then I been having these weird experiences with heating things up in our microwave (stuff gets hot in one corner while the rest of cold), it must have threw me off.
But then when I boil water for pasta, initially before it starts to boil, the bottom will be hotter than the top. Having said that, I always use the hottest water from the tap, reduces boil time.
When then I guess you 99.9% wrong, I don't have a kettle.  Smile
redngold
Fri Nov 30, 2007 12:31 am
Quoting PPVRA (Reply 17):
Actually, no. It's the hot wax which is less dense than the water that rises, and then cools and sinks.
Up, up and away!
Nancy
Fri Nov 30, 2007 12:33 am
Water has the greatest density at about 4 c. It gets slightly less so as it cools to 0. Don't ask me why.
AverageUser
Fri Nov 30, 2007 12:43 am
Quoting Ronglimeng (Reply 23):
AverageUser:
Thank you!  Smile I'll definitely have this one framed on the wall as it's my first one ever!
baroque
Fri Nov 30, 2007 6:36 am
Also, doesnt water pressure have to do with it as well? Even though its below freezing at the bottom of the ocean its still liquid.
The influence of pressure is complex because water expands as it freezes. Whatever, deep ocean temperatures are very close to the theoretical 4 degrees C. Basically, the whole water mass below about 1 km from the sea surface is within about 0.1 degrees of 4 C. Or that is what the sea bottom temperatures are reported as for deep water oil wells.
Ed to ruin Queso's day.  Big grin  Big grin
britjap
Fri Nov 30, 2007 7:45 am
Quoting Lehpron (Reply 27):
Surely then that would make him 100% wrong!  Smile
Klaus
Fri Nov 30, 2007 12:41 pm
In solid or very viscous foods (such as a thick sauce) the heat can't spread through convection, so the water content and the radiation exposure would determine how well the components are heated in a microwave oven.
When the liquid content is more fat and oil than water or when the food is relatively dry, the microwaves won't find as much resonance in the food and it can remain relatively cool. And the short exposure time prevents the heat to spread conventionally.
I'm just speaking from theory here - I just don't like to expose my food to intense radar emissions.
Yes. And when you're looking closely you can see convection columns emerge. If you put some herbs into the clear water, for instance, the convective motion is easy to observe.
It is also one reason why soups or thinner sauces normally won't burn: Thermal convection has the heated liquid rise from the bottom and the cooler liquid sink down from the top, so a mostly even heat distribution is automatically achieved.
Thicker stews don't allow convection to equalize the energy distribution. That's why those need help by stirring to prevent the substance at the bottom from getting "cooked out" (water evaporating and the solid remaining in place) and burning up.
I generally wouldn't recommend that. House boilers are good enough for a shower, but I wouldn't normally eat anything made with water having gone through them.  yuck
Exceptions apply, of course, but the warm water pipes (including those in the boiler) are often more corroded than the cold water ones because heat accelerates corrosion. I don't know about your house, but often you can taste the difference (a rusty or otherwise metallic taste, for instance, or a chemical plastic taste, depending on your tubes).
AverageUser
Fri Nov 30, 2007 6:23 pm
Quoting Klaus (Reply 33):
And a warmish shower may be a splendid place to catch Legionella pneumophila... link Luckily you don't usually get sick unless you have a weak immunity system.
Users browsing this forum: 1337Delta764, Bing [Bot], Ken777, Narfish641, Snuffaluffagus and 36 guests
