Quoting PITingres (Reply 6): I expected this question to come from an 18-year-old, |
Quoting ajd1992 (Reply 10): I had a dual-boot PC a long time ago - XP and Ubuntu. I could never really get into it though, I couldn't get my head around using it. I eventually uninstalled it after I corrupted both partitions and made a mess of everything. |
Quoting PITingres (Reply 6): DEC again: TOPS-10 (not only used it, but did a lot of development for it), |
Quoting ajd1992 (Reply 10): I had a dual-boot PC a long time ago - XP and Ubuntu. |
Quoting Revelation (Reply 14): DEC's educational OS for PDP-8 |
Quoting PITingres (Reply 24): I forgot to put that one down. EDUsystem-50, also known (at least at CMU) as TSS/8. That was a remarkable little setup, and I've met very few people who have even heard of it, much less used it. |
Quoting Revelation (Reply 26): Once every two months or so the DEC field service guy would come by and vaccum the dust from the core memory. Yes, real cores with real wires wrapped around them, I saw it up close and personal. Not sure how much of it there was, but IIRC the 8 could only natively address 4096 12-bit words I'd say 'not much'.. |
Quoting connies4ever (Reply 29): When I retire I'm going to an ashram to get deprogrammed. |
Quoting PITingres (Reply 28): The higher end EDUsystem-50 boxes had 24K; I think there were other variations with less. The PDP-8 had a tricked-out instruction set with a 7 bit memory offset which addressed either the "current" bank of 128 words, or bank 0. You could also use the 7-plus-bank offset to indirectly address through a full 12-bit address. To get past the basic 4K address space, it used bank switching, but I don't know the details. (Probably a bank-switch register addressed as an I/O device.) |
Quoting PITingres (Reply 28): That PDP-8 got me into computing as well. Inside of a couple weeks of discovering it, I was pissing around with assembly programming. About a year after I was there, its disk drive crashed, and they decided not to replace it. A shame. I think the CPU vanished into the bowels of Hamerschlag (the EE building), probably ended up running a coke machine or something. |
Quoting sprout5199 (Reply 33): I used an AN/UYK-20 in the navy but have no clue what OS it used--had to enter stuff in octal, oh fun. 64K of non-volatile magnetic core memory. You could actually see the little ferrite beads on the memory board. |
Quoting Airstud (Reply 38): Quoting falstaff (Reply 37): I used to work with a Commodore Amiga for a job I had back in 1995-97. I don't know what the operating system was called Probably....AmigaOS!!! |
Quoting Revelation (Reply 39): Did the ones you used have any other I/O devices? |
