Longhornmaniac
48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:15 pm
Here's a (simple) math problem for you guys. This should spur some heated discussion, if the responses in here are like other places I've seen it.
Cameron
Cameron
Cadet985
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:18 pm
The answer is 288.
Braniff747SP
RE: 48 ÷ 2(9+3)=?
288, is it not?
FIller.
The 747 will always be the TRUE queen of the skies!
aa61hvy
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:19 pm
I came up with .5
2(9+3)/48
(18+6)/48
24/48
.5
Go easy on me if I screwed this up. I haven't taken a math course in 8 years.
Edit: or is it 2?
same equation but 48/24 instead.....
[Edited 2011-04-13 12:20:55]
Go big or go home
canoecarrier
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:20 pm
You do division before multiplication right? I'm going to say 288
Basically:
48/2 * (12)
24 * 12
288
[Edited 2011-04-13 12:24:03]
The beatings will continue until morale improves
Cadet985
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:21 pm
You do the work in the parenthesis first.
9+3=12
48/2=24
24*12=288
AR385
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:23 pm
It is 288
Filller, Filller, Filller
aa61hvy
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:25 pm
Quoting Cadet985 (Reply 5):
9+3=12
48/2=24
24*12=288
Ah makes sense to me now.
I was always better in sciences anyhow.
Go big or go home
Cadet985
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:27 pm
Quoting aa61hvy (Reply 8):
Just be glad there weren't variables in this problem...Lord knows I suck at algebra.
Longhornmaniac
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:28 pm
[Devil's Advocate]
Could you not interpret it as:
48 ÷ 2(9+3)
48 ÷ 2(12)
48 ÷ 24 =
2?
[/Devil's Advocate]
For the record, I also got 288, but there are a lot of people, including some very smart ones, who believe the answer is 2.
Cameron
Cameron
casinterest
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:33 pm
Please Excuse My Dear Aunt Sally.
Parenthesis, Exponents, Multiply, Divide, add , then suptract.
The answer is 2.
Where ever you go, there you are.
Ken777
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:34 pm
Quick look for me is 48 ÷ (2(9+3)) because of the spaces on both sides of the ÷ sign.
That leaves you with an answer of 2.
Unless, of course, you are trying to calculate a tax deduction before Tax Day, in which case it is acceptable to come up with an answer of 288.
auntie
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:35 pm
This ..................
Quoting Longhornmaniac (Reply 10):
48 ÷ 2(9+3)
48 ÷ 2(12)
48 ÷ 24 =
2?
............is exactly how I would have done it!!!!
Although I too, haven't done maths in a loooong time!
Longhornmaniac
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:37 pm
Quoting Ken777 (Reply 12):
I wasn't implying anything by the spaces, just spacing it out to make it look prettier.
Now we're starting to get some competing answers! Hehe.
Cameron
Cameron
Moose135
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:39 pm
I came up with 2 as well.
atrude777
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:41 pm
I got 288.
You always go from Left to Right in order of what comes up first.
Quoting canoecarrier (Reply 4):
Only if it shows up first.
In this case it did so yes 288 is correct.
A lot of people used that PEMDAS formula which is right...but it ignored the fact you still must work from left to right. Since divide came up before multiply in this problem, the PEMDAS formula does not apply.
Alex
[Edited 2011-04-13 12:43:05]
[Edited 2011-04-13 12:43:29]
DocLightning
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:46 pm
48/2(9+3) is expressed as:
48 48
------ = ----- = 2
2(9+3) 24
Order of operations. Learned it in 6th grade.
First do what's in parentheses (following order of ops within the parenthesis if applicable).
48
2x12
Then do exponents. (N/A)
Then multiply.
48
25
Then divide.
=2
Then add. Then subtract. (N/A)
Quoting casinterest (Reply 11):
Why, did she fart?
-Doc Lightning-
-Carl Sagan
einsteinboricua
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:54 pm
The answer is 288. Order of operation: parenthesis, exponents, and from left to right multiplication and division, and then from left to right again addition and subtraction.
For the answer to be 2, the equation would have to read: 48 ÷ (2*(9+3)), so that in better terms is 48/(2*(9+3)).
If in doubt, Excel can always help us. Excel says it's 288.
Well...unless you're studying basic sciences where it's only theory with no equations, you SHOULD be better in math.
Quoting atrude777 (Reply 16):
Actually you go from left to right regardless of whether a division or a multiplication appeared first. So if you had, for instance, 1/3*3, it would give the same answer as 1*3/3. One will give you a decimal which is then multiplied by an integer and the other gives you an integer in all steps.
As long as parenthesis and exponents are all done, you sweep from left to right doing both mult. and div. in the order they appear.
"You haven't seen a tree until you've seen its shadow from the sky."
KingFriday013
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:56 pm
Quoting aa61hvy (Reply 3):
48 ÷ 2(9+3)
48 ÷ 2(12)
48 ÷ 24 =
2?
Quoting auntie (Reply 13):
That's what I got as well.
Do the stuff in parentheses first: 9+3 = 12
2(9+3) = 24
48 ÷ 24 = 2.
I looked at it as a fraction, with 48 as the numerator and 2(9+3) as the denominator.
Quoting Longhornmaniac (Reply 14):
Even without the spaces, I would have separated the two parts anyway. Unless the 48 ÷ 2 portion was in parentheses on its own, I would consider the 2 as a multiplier of the (9+3) before dividing.
-J.
Tho' I've belted you an' flayed you, By the livin' Gawd that made you, You're a better man than I am, Gunga Din!
Severnaya
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:57 pm
Quoting Longhornmaniac (Thread starter):
48 ÷ 2(9+3)=?
48 ÷ 2(9+3)=?
48 ÷ 2 * (9+3)=?
48 ÷ 2 * 12=?
is either 288 or 2, depending on your view whether you use the ltr rule or the multiplication over dividing.
Oh and for this reason equations with a ÷ in it should be banned. In science papers i've read the last few years I've not often seen the ÷ sign.
How difficult can it be?
[Edited 2011-04-13 13:02:39]
Всяк глядит, да не всяк видит.
FlyDeltaJets87
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 7:59 pm
This is true but I also remember a catch to this as well - if the functions in the equations are opposites (multiple & divide or add & subtract) then you work from left to right. I honestly forgot how it's carried out if there are more functions though.
"Let's Roll"- Todd Beamer, United Airlines Flight 93, Sept. 11, 2001
UAL747
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:00 pm
I got two as well. Always do stuff in parentheses first, then multiply, divide.
Please
Excuse
My
Dear
Aunt
Sally
Jetsgo
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:02 pm
I'm honestly shocked at the amount of people who are getting this wrong. 288?
48 / 2(9+3)
48 / 2(12)
48 / 24
= 2
Edit... I guess I was wrong Big grin
[Edited 2011-04-13 13:35:40]
Marine Corps Aviation, The Last To Let You Down!
Longhornmaniac
RE: 48 ÷ 2(9+3)=?
Some common misconceptions:
Multiplication does not receive a higher priority than division. They are equal priority, and are read from left to right.
Same goes for addition and subtraction.
Cameron
Cameron
GAIsweetGAI
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:05 pm
It's funny, I just "stumbled" across the following picture yesterday - it's always better with a picture:
Or am I just spoiling the fun?
"There is an art, or rather a knack to flying. The knack lies in learning how to throw yourself at the ground and miss."
UAL747
RE: 48 ÷ 2(9+3)=?
Quoting Longhornmaniac (Reply 24):
Correct, however division and multiplication are > addition and subtraction
aa61hvy
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:09 pm
Quoting JetsGo (Reply 23):
48 / 2(9+3)
48 / 2(12)
48 / 24
= 2
Alright, my second guess was correct!
Go big or go home
unattendedbag
RE: 48 ÷ 2(9+3)=?
48 ÷ 2(9+3)=?
48 ÷ 2(9+3)=?
first step
(9+3) = 12
second step
2(12) = 24
third step
48 / 24 = 2
the answer is 2
Quoting einsteinboricua (Reply 18):
the 2(9+3) implies 2 * (9+3) ie. 2 * 12 . any number outside and attached to the () is multiplied by the sum inside the (). The /*-+ inside the () is always completed first. Then you move away from the ().
Slower traffic, keep right
Longhornmaniac
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:10 pm
Quoting UAL747 (Reply 26):
Correct.
Quoting GAIsweetGAI (Reply 25):
Haha. You're the second person that's posted that when I raised this question.
Carry on!
Cameron
Cameron
ArmitageShanks
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:11 pm
This same thread has about 200 views on another forum I frequent.
Any NN fans here?
dragon6172
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:15 pm
I see the "Friday Stupid Thread" has arrived early this week.
Phrogs Phorever
dragon6172
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:17 pm
By the way... when in doubt put it into the ol' TI-89 exactly as it is written in the thread starter... answer is 288.
Phrogs Phorever
Longhornmaniac
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:25 pm
Look at the first reply on this thread:
http://www.shaggybevo.com/board/show...hread.php/87280-48%C3%B72%289-3%29
You'll see not all calculators give the same result.
Cameron
Edit: there's plenty of offensive language on that site!
[Edited 2011-04-13 13:26:19]
Cameron
DeltaMD90
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:34 pm
It is 288. I made the same mistake and got 2.
Please Excuse My Dear Aunt Sally, so:
48 / 2 (9+3) IS REALLY 48 / 2 * (9+3)... so you do the parenthesis first so its 48 / 2 * (12) aka 48 / 2 * 12 which, going from left to right, is 48 / 2 = 24 times 12 equals 288.
Edit: Also, if you want to distribute, you don't only distribute the 2 into the (3+9), you also distribute the 48. In other words, you distribute 48/2 into (3+9) equaling (72+216) = 288
[Edited 2011-04-13 13:36:59]
Derico
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:37 pm
The key is to always remember that when a parenthesis has operations inside, you do them first with any multiplying or dividing FIRST from left to right, once you are out of those, addition and subtraction from left to right.
Once there is only ONE number inside the parenthesis, it becomes just another simbol for multiplication.
Step by step:
1. Parenthesis first: You first do any multiplication / division left to right, and then any addition / substraction left to right INSIDE parenthesis BEFORE ANYHING OUTSIDE. ALWAYS!!!!
48 / 2(9 + 3) ... lets imagine the 9 in the parenthesis was expressed as 3*3, thus
48 / 2( 3*3 + 3).
Parenthesis first = (3*3 + 3)
multiplication or division left to right inside parenthesis first = 3 times 3? = 9 .... (9 + 3)
addition or subraction inside parenthesis first = 9 plus 3? = (12)
Now, there are no more OPERATIONS inside the parenthesis.
Now you have 48 / 2(12)
The only trick here is that the parenthesis now becomes equal to a multiplication problem and NOT a symbol to do it first!! Remember that:
2 x 12 is the same as 2*12 is the same as 2(12)
So you do not do 2(12) first just because it is a parenthesis. There are no more operations inside, thus the parenthesis is now just another way of showing multiplication relationship. Since that is the case, you simply now multiply or divide left to right:
48 / 2 = 24 ... 24 (12) or 24*12 = 288
My internet was not shut down, the internet has shut me down
UAL747
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:39 pm
For people getting 288, you are forgetting that ANY number touching a parenthesis by multiplication or division, whether it's on the inside or out should be part of the first step of any operation. The calculator pictures show a calculator that needs to be taken to the store and returned.
1. Any operation involving a Parenthesis (a. inside, b. outside)
2. Multiply/Divide
3. Add/Subtract
UAL
Longhornmaniac
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:42 pm
Quoting UAL747 (Reply 36):
Tell that to a linear algebra professor at my school who says 288 is the right answer.
Can you provide a source that says any number touching a parenthesis is included in part of the "Parenthesis" category in the order of operations?
Cameron
Cameron
Longhornmaniac
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:43 pm
And just to make sure you're aware, those are 4 different calculators.
Cameron
Cameron
unattendedbag
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:44 pm
Quoting Longhornmaniac (Reply 33):
If you choose to use a calculator to solve the math problem, your calculator must be in scientific notation. Only a calculator in scientific notation will follow PEMDAS and the order of operations. A non-scientific calculator will yield an incorrect answer.
Read more: How to Solve a Math Problem Using PEMDAS | eHow.com http://www.ehow.com/how_4449191_solv...em-using-pemdas.html#ixzz1JRDlkKut
Derico
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:49 pm
2. Multiply/Divide
3. Add/Subtract
No, that is not so. You are confusing the distributive property which you assign as ''b. outside''
if the problem was 48 + 2(9 +3) THEN YES, you would do the following:
48 + 2(12)
48 + 24 = 72
Because again, parenthesis once it has only one number in it, is just another symbol to multiply. So in my example you do the parenthesis first because there is a PLUS after 48, and you do mutiplication or division left to right FIRST before the plus sign.
But it is 48 DIVIDIED by 2(12) or in other words 48 / 2 x 12. Since multiplication and division are equal, by convention it is done left to right.
[Edited 2011-04-13 13:51:10]
canoecarrier
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:53 pm
Quoting dragon6172 (Reply 31):
I think that's a little harsh. Out of curiosity I googled the equation and found this thread on a physics forum where it's getting just as much attention and discussion as we have here.
http://www.physicsforums.com/showthread.php?t=488334
I also haven't seen the division symbol used like it is in this equation in ages.
UAL747
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:58 pm
Also, the division sign is simply the line in a written fraction. 1/2 is 1 divided by 2. Thus, wouldn't this just be read like a fraction, with 2(9+3) on the bottom? After all, 48/2(9+3) is the same thing as written above.
UAL
dragon6172
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 8:59 pm
Quoting canoecarrier (Reply 41):
Maybe so... I actually have never checked out the Friday Stupid Thread so I do not really know what they are all about. Maybe I should have said:
"I wonder if the number of posts on this thread will match that of the famous aircraft taking off from a treadmill thread"
Phrogs Phorever
JBirdAV8r
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 9:05 pm
       Epic thread!!
For the record, I'm not a math-oriented person and I got 288. I'm reading explanations with interest...
Longhornmaniac
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 9:06 pm
Quoting UAL747 (Reply 42):
Indeed, but then, is it read as:
48/(2(9+3))
OR
48/2(9+3)
The top answer gives 2, the bottom answer gives 288.
Cameron
Cameron
canoecarrier
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 9:09 pm
Quoting Longhornmaniac (Reply 45):
48/(2(9+3))
And, the equation he posted is not written like that.
48/2(9+3)
I'm in the camp that this is how it should correctly be calculated. 48/2(12) to (24)(12) = 288
BAKJet
RE: 48 ÷ 2(9+3)=?
48 / 2(9+3)
48 / 2(12)
48 / 24
= 2
Me Too! And you're one of them! In order of operations, multiplication and division are "equal" therefore you go from left to right.
So 48/2 *(9+3)
48/2 *(12)
24 *(12)
answer is 288. definitely.
Put it into a calculator or Google, you'll get 288.
http://lmgtfy.com/?q=48%2F2(9%2B3)
[Edited 2011-04-13 14:12:43]
Derico
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 9:12 pm
This is the same confusion people get with the following kinds of problems:
7 + -( -4 x 3)
This equals 19 and not -5
The minus outside the parenthesis kills even differencial equation people, that's what a professor I had says, so it's no wonder the ''physicists'' are flummoxed by these problems. This is my way to solve these, though most people will get a headache:
The easiest way for me is to make everything an addition problem, even if I add negatives, and place negatives in parenthesis to remember the minus is part of the number.
So 7 + - (-12)
We should know a negative times a positive is a negative thus:
7 + (-1) x ( -12)
7 + 12 = 19
Edit: I butchered the signs, now it's right. I just made up this problem, sorry...
[Edited 2011-04-13 14:35:27]
[Edited 2011-04-13 14:45:59]
dragon6172
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 9:14 pm
Interesting that using my TI 89 when I put:
48/2(9+3)
the answer is 288
When I put:
48/y(9+3)
the answer is 48/(y(12))
And finally, when I put:
48/y*(9+3)
the answer is 576/y
Phrogs Phorever
Jetsgo
RE: 48 ÷ 2(9+3)=?
Wed Apr 13, 2011 9:16 pm
Quoting BAKJet (Reply 47):
Hmmm... a little late there!
Users browsing this forum: Aaron747, hoons90 and 85 guests
