Couple of tips whether or not you follow the suggestion below:
-Once you start using a backlit keyboard, especially in a plane, you won't want to go back;
-Laptop manufacturers still charge a premium for SSD. After choosing your laptop, look up the hardware maintenance manual to see whether the HDD bay is easily accessible. If it is, get your laptop with the cheapest HDD available, buy a SSD at retail and install it yourself.
Quoting wilco737 (Reply 3): I have my home PC which I use mostly. Laptop is only for my trips. |
If you also have a home
PC, may I make a suggestion? Buy a very good laptop and ditch the desktop!
Late last year, after having to reset Google Sync again to sync my bookmarks between the laptop and the desktop, and using Evernote and Bitcasa to do the same with files and other materials, I decided there had to be a better way.
I kept my external speakers and my 29" display, bought an
AMS Venus enclosure to "recycle" the two high-capacity HDDs I had in my desktop and bought a Toshiba Dynadock to connect all that to (and keyboard/mouse). Then a single USB cable from the Dynadock to a new laptop, and I have a perfect desktop setup at home.
For the laptop, since it is truly a desktop replacement, I have an Intel i7 CPU, one 24GB SDD and one 180GB SDD (*), 16GB of DDR3 RAM, a built-in graphics controller on the CPU and a NVIDIA GeForce graphics controller (software control switching back and force as needed, but you can customize it).
All in all, some serious firepower on the road, and everything I'd need out of my desktop at home and then some. It is the quietest desktop I have ever had, but not the lightest.
(*) Having two SSDs isn't my idea, it's the manufacturer's. The 24GB SDD comes by default and is swapable with a second NVIDIA card, or a bigger fan. I bought the 180GB SDD at retail to replace the HDD the laptop came with.
