Quoting alberchico (Thread starter): So if an ambulance blows through a red light with its lights and sirens on and a car collides with it who is at fault ? |
Quoting LittleFokker (Reply 2): I take it that in Russia, ambulances do not have a remote control device that switches the traffic lights into their favor like most American ambulances do? |
Quoting LittleFokker (Reply 2): I rarely see an ambulance going over the speed limit and not hesitate when approaching an intersection. |
Quoting ElanusNotatus (Reply 8): So an ambulance driver would not normally proceed through a red traffic light without first checking that it is safe to do so, particularly in a built-up area where visibilty at intersections may be restricted. |
Quoting AeroWesty (Reply 5): It's the responsibility of the non-emergency vehicle driver to be able to hear an approaching siren while driving, and give the right of way. Always. |
Quoting AeroWesty (Reply 5): Quoting alberchico (Thread starter): So if an ambulance blows through a red light with its lights and sirens on and a car collides with it who is at fault ? It's the responsibility of the non-emergency vehicle driver to be able to hear an approaching siren while driving, and give the right of way. Always. |
Quoting AR385 (Reply 3): The first driver´s license I got in the US was in Virginia. We had to study a booklet, take a test etc. But, the rules in the booklet clearly stated that the ambulance (and other emergency vehicles) has the right of way and that you as a driver are supposed to stop and let it pass. I suppose that applies to intersections if the ambulance is coming at speed with lights and sirens. I would say it´s the driver´s fault. |
Quoting Ken777 (Reply 6): I think all emergency personnel understand that they have the right of way and "should" be able to go through a red light without slowing down. |
Quoting AeroWesty (Reply 5): As more fire depts. in the US become fire and rescue, a big red truck could be the first emergency vehicle on the scene, oddly enough. Ambulances are usually late comers, and I wouldn't think need to speed unless they have a patient who can only be saved in hospital. |
Quoting AR385 (Reply 15): |
Quoting wingman (Reply 17): The best part is the reaction of other drivers and nearby pedestrians, they just don't give two craparonies. |
Quoting fr8mech (Reply 16): Your conclusion. You are correct, that VA, along with other, if not all other states, require a driver to yield the right-of-way to an emergency vehicle operating on a run, the pertinent law also stipulates that the EVO will exercise due regard for safety. In fact, VA specifically says: This provision shall not relieve the driver of any such vehicle to which the right-of-way is to be yielded of the duty to drive with due regard for the safety of all persons using the highway, nor shall it protect the driver of any such vehicle from the consequences of an arbitrary exercise of such right-of-way. |
Quoting AR385 (Reply 19): Understood. Thank you for explaining. I get the impression though, from what I´ve read in the thread and the regulations, that lawyers would have a field day in court if this happened in the US. |
Quoting BMI727 (Reply 1): The ambulance. Emergency vehicles bear the responsibility of ensuring it is safe to run red lights, etc. |
Quoting flyingturtle (Reply 23): It would be even your fault if the ambulance came sliding backwards, on the roof, on the wrong lane... |
Quoting fr8mech (Reply 15): This provision shall not relieve the driver of any such vehicle to which the right-of-way is to be yielded of the duty to drive with due regard for the safety of all persons using the highway, nor shall it protect the driver of any such vehicle from the consequences of an arbitrary exercise of such right-of-way. |
Quoting zckls04 (Reply 24): Can you cite the relevant law? |
Quoting fr8mech (Reply 12): The emergency services in this area do not have these devices. I think the closest municipality that uses them in Cincinnati. They are not universally used in the US. |
Quoting BMI727 (Reply 17): Also at airports the emergency vehicles are required to have clearance from ground control. |
Quoting flyingturtle (Reply 25): *How* they are driving does not matter. They have the right of way as long as they use the horn and the flashing light. |
Quoting flyingturtle (Reply 25): |
Quote: 2. Der Vortrittsberechtigte hat auf Strassenbenützer Rücksicht zu nehmen, welche die Strassenverzweigungen erreichten, bevor sie ihn erblicken konnten. |
Quoting flyingturtle (Reply 23): Emergency vehicles with flashing lights and horn always have the right of way. No matter how fast they are. If you run into them, it's your fault. |
Quoting fr8mech (Reply 27): I suspect that if you look deeper into the Verkehrsregelnverordnung (there's a mouthful), you will find that it says that emergency vehicle operators must drive with due regard for the safety of others. |
Quoting ElanusNotatus (Reply 28): This Article does not indicate an exception for drivers of emergency vehicles despite the provisions of Art 16. |
Quoting flyingturtle (Reply 30): Alas, the question is pretty moot anyway because I've never seen any emergency vehicle speeding over a crossroads. |
Quoting flyingturtle (Reply 30): But then the ambulances must use their signals when they cannot adhere to the traffic rules, which entails said due regard and |
