Airstud
97% of you will get this wrong...
Mon Mar 13, 2017 2:19 pm
...is the claim made on Facebook above the following logic problem:
1 + 4 = 5
2 + 5 = 12
3 + 6 = 21
5 + 8 = ??
I get 37.
Pancakes are delicious.
casinterest
Re: 97% of you will get this wrong...
Mon Mar 13, 2017 2:29 pm
45
Where ever you go, there you are.
TheF15Ace
Mon Mar 13, 2017 2:33 pm
I got 45
TheFlyingDisk
It's 34
I FLY KLM+ALASKA+QATAR+MALAYSIA+AIRASIA+MALINDO
VSMUT
Mon Mar 13, 2017 2:35 pm
2 + 5 = 7
3 + 6 = 9
5 + 8 = 13
Seriously, this is basic stuff.
dtw2hyd
Mon Mar 13, 2017 2:44 pm
I got 34
All posts are just opinions.
Airstud
Mon Mar 13, 2017 2:49 pm
Everyone on the Facebook thread seems to have gotten 34 or 45.
I'm the only one out there (I think) who got 37. :boggled:
captaink
Mon Mar 13, 2017 2:50 pm
45... When do you show our explanation?
Look Up
Okie
Mon Mar 13, 2017 2:51 pm
I got 34.
Okie
ANITIX87
Mon Mar 13, 2017 2:55 pm
The correct answer is 45.
For those who get 45:
Formula is x + y = z, where the result is taken by doing x + (x * y) = z.
Therefore, 1 + 4 = 1 + (1 * 4) = 5. For the last row, 5 + 8 = 5 + (5 * 8) = 45.
This is the ONLY correct answer which works for any x and y values.
For those who get 34:
Formula is x + y = z, where the result is taken by doing x + y + ("result from previous row") = z.
Using that, 5 + 8 = 5 + 8 + 21 = 34. However, there is a row missing for 4 + 7 so you cannot prove that this is the formula.
This DOES NOT work for all x and y values since you need information on previous instances, which negates the premise of a formula.
It's a silly problem, as it's not mathematically correct and the lack of information means it sort of has two answers, as I've shown, if you assume that only the rows presented exist in the problem.
casinterest
Mon Mar 13, 2017 3:00 pm
I could make a strong argument for 37. but it includes making an assumption of the questioners intent on missing a line. So I stand by 45
ANITIX87
Mon Mar 13, 2017 3:01 pm
How can you make an argument for 37? I put in the argument for 34, but I can't get 37 no matter what assumptions I make.
If you assume the missing row using the formula for 34, you get:
3 + 6 = 21
4 + 7 = 32
5 + 8 = 45
casinterest
Mon Mar 13, 2017 3:05 pm
If you assume that the real equation is N=(x+(y*z)) where y is the line number. so the last line would be 5+(4*8)=37 Like I said, it works out, but it is not logical based on the fact that the missing numbers (4+7) would fall apart if reintroduced.
ANITIX87
Mon Mar 13, 2017 3:06 pm
Interesting, my mind never went in that direction. As the row numbers aren't shown, I didn't even entertain the idea of using them. As you say, the logic falls apart when considering the lack of 4 + 7.
Airstud
Mon Mar 13, 2017 3:07 pm
In each statement; the 2nd operand is multiplied by +1 to said multiplier in the previous statement. Hence 8 → 32.
Edit: casinterest & I clicked submit at the same time :-/
Tugger
Mon Mar 13, 2017 3:27 pm
My issue is with the assumption it is requiring you to make. If one is required to assume that a missing row is to be included in the final answer then the answer could also be "infinity" as you could logically equally assume that every row thereafter should be included.
Tugg
There are many kinds of sentences that we think state facts about the world but that are really just expressions of our attitudes. - F. Ramsey
casinterest
Mon Mar 13, 2017 3:47 pm
ANITIX87 wrote:
Interesting, my mind never went in that direction. .
If you have ever debugged enough code, you will learn your mind has to examine all the possibilities. Off by one errors are prevalent is software engineering.
SAS A340
Mon Mar 13, 2017 4:03 pm
45 for sure :)
It's not what u do,it's how u do it!
mham001
Mon Mar 13, 2017 4:18 pm
45. I just took that online IQ test (139), it was full of these.
JoeCanuck
Mon Mar 13, 2017 6:47 pm
I got 45...and a headache.
What the...?
seahawk
Mon Mar 13, 2017 7:02 pm
45 as 4+7 is missing.
AirPacific747
Mon Mar 13, 2017 7:16 pm
45 for sure. First you multiply the first digit with the second, then you add the first digit to the multiplied number. It didn't seem very difficult as it was easy to pick up the logic using the examples above.
Dreadnought
Mon Mar 13, 2017 7:47 pm
34
Democrats haven't been this angry since we took away their slaves.
afterburner
Mon Mar 13, 2017 8:13 pm
37 for me.
Wait. I changed my mind. It's 45.
cjg225
Mon Mar 13, 2017 8:38 pm
Yeah. I got 45, but the way it's written is just so dumb. Someone trying to be way too cute with a "logic" problem.
Restoring Penn State's transportation heritage...
TheFlyingDisk
Mon Mar 13, 2017 10:09 pm
4+7? Shouldn't it be 5+7 = 12?
ANITIX87
Tue Mar 14, 2017 12:09 am
No, the last two rows are:
3 + 6 = 21
5 + 8 = ??
The missing row is, therefore, 4 + 7.
TheFlyingDisk
Tue Mar 14, 2017 12:21 am
3 + 6 = 21
5 + 8 = ??
But you're assuming that a row is missing. If you assume that there's no missing rows then the answer is correct!
DLFREEBIRD
Tue Mar 14, 2017 9:00 am
i got 45 following a pattern, but since it said 97% of you would get it wrong and almost everyone here says 45
maybe the answer is hiding in plain sight and is just 12?
seahawk
Tue Mar 14, 2017 9:52 am
You mean 13, if we assume the line is broken due to the missing 4+7 and starts again.
cjg225
Tue Mar 14, 2017 12:30 pm
5 plus 8 is 13.
The interesting thing is that you can be "wrong" no matter what, since the person determining if you're wrong is the person who first presents this problem, because only that person knows whether they want to pull a fast one by saying it's just 5+8=13 or making you read a formula into the entire set that you need to figure out and apply.
DLFREEBIRD
Tue Mar 14, 2017 3:16 pm
lol yes, i meant 13
ANITIX87
Tue Mar 14, 2017 3:38 pm
5+7 doesn't appear anywhere in the problem.
TheFlyingDisk
Wed Mar 15, 2017 12:17 am
It's 2+5+5 on the second equation
Raventech
Wed Mar 15, 2017 4:50 am
I got 45, I did it based on finding a pattern and fitting am equating to it like one of the guys above, and the "true" equation I saw was n=x*(y+1)
ANITIX87
Wed Mar 15, 2017 7:35 pm
What? That has nothing to do with what I was saying and with what I thought you were saying. Run through the problem row by row and tell me what you're doing.
TheFlyingDisk
Wed Mar 15, 2017 10:13 pm
It's exactly what you're saying = X + Y + (result from previous row) = Z
1) 1 + 4 + (0) = 5
2) 2 + 5 + (5) = 12
3) 3 + 6 + (12) = 21
4) 5 + 8 + (21) = 34
ANITIX87
Wed Mar 15, 2017 10:19 pm
1) 1 + 4 + (0) = 5
2) 2 + 5 + (5) = 12
Right, I was saying there's a row for 4+7 missing, and you corrected me to say it should be 5+7.
Mortyman
Thu Mar 16, 2017 4:43 pm
45
Quantos
Thu Mar 16, 2017 8:55 pm
34 seems correct when you go with the assumption that the values given are the only one in the series. If there is indeed a 4+7 not shown, but implied, then 45 would be the only answer. Pedantic me would say that there is no indication of a missing row, like a "..." or "[...]", so I'm saying 34 is absolutely a correct answer based on the parameters provided!
Quantos,
I maintain the Airbus A220 (formerly Bombardier C Series) Aircraft Status sheet: https://goo.gl/HZshto
Feel free to comment on the sheet with any improvement suggestions and data update requests! Thanks to Paolo92 for his advice!
Braybuddy
Fri Mar 17, 2017 7:59 am
It's impossible to get a correct answer with a flawed formula, so the 97 per cent are not wrong at all.
seahawk
Fri Mar 17, 2017 8:03 am
13 would make sense, if you believe the line was broken (missing 4+7) and the formula starts new with 5+8
34 would make sense, if you believe the line continues
45 would make sense, if you believe that the missing 4+7 is implied
With this not precise starting formula it is up to the person asking the question to decidce what he thinks is correct.
Users browsing this forum: Francoflier and 70 guests
