GalaxyFlyer
Re: Should there be a Multi Party System in American Democracy?
Sat Dec 01, 2018 1:46 am
But it is the same elements of the crime tried by two sovereigns which you said couldn’t happen under “lesser included”. You can be charged in what many erroneously believe to be double jeopardy.
No, South Carolina isn’t the same as Spain, I never asserted it was, but it is a separate sovereign and out system is based on states being so. It’s closerto Spain than say Brittany is in France or Rutland is in the UK. You would wish it otherwise, in fact, seem to be open to eliminating states, in the international sense, altogether.
GF
GF
DL717
Sat Dec 01, 2018 6:35 am
DarkSnowyNight wrote:
GalaxyFlyer wrote:
That does not contradict anything I've said. Especially where the example you have of UCMJ comes in. One event can easily trigger multiple charges. It doesn't require multiple jurisdictions either, although, as I have said, if the same event violates two different codes, you can expect to pay for both. In all of the cases you mention (and all like that there have ever been), the code/statute violations do have different numbers based on who's prosecuting at the moment. The fact that it is the same event is not relevant.
This is not controversial.
Of far greater import, it also adds nothing to the notion that american states are somehow equal to countries, as another poster quite foolishly suggested. That's the larger point. Semantics will not make South Carolina equal to Spain.
Keep up that GPA bro. Meanwhile, the rest of us understand how it works.
Everything is chits and giggles until you get old enough to giggle and then you chit.
DarkSnowyNight
Thu Dec 06, 2018 1:02 am
Yes, because it's literally a different crime. But you would be right to say it's the same event. I have my feelings about how far that should go, but as long as we give states the privilege to charge for something the feds already have, this will be a thing.
This is true; you did not say that. I was actually just answering someone who thinks wishful thinking is a substitute for knowledge/awareness on a matter.
In practice, what you say there is true, but it's still a huge misnomer to refer to our provinces as states. Definitely closer to sovereignty than Rutland, but far further than Hong Kong or Taiwan. Or even Puerto Rico, for that matter.
GF
It is not something I care enough to bring up on my own, but I wouldn't be opposed. There's very little I like about my nation that has anything to do with it being a nation. Most of the good things here got that way through circumstance as much as anything else.
If eliminating borders eventually resulted in a more stable world market economy (which it probably would), I'd be hard pressed to find a problem with that, if I'm being honest.
Much like a GE90, I'm a huge fan of Big Twins...
Users browsing this forum: 1337Delta764, BlueberryWheats, wingman and 22 guests
