ArchGuy1
Retread Tires on Front End Loaders
Fri Aug 16, 2019 3:55 am
What exactly is it like running retread tires on front end loaders. I do know that they are commonly used on 18 wheelers and other large trucks.
TSS
Re: Retread Tires on Front End Loaders
Fri Aug 16, 2019 4:40 am
As long as they were retreaded by a reputable company, it shouldn't be a problem. Aside from damage, two things destroy tires: Weathering from the outside and heat buildup in the tire carcass from the inside. Front end loaders rarely if ever travel fast enough to build up any heat in the carcasses of their tires, and a reputable retreader would never use an excessively weathered tire as a base.
Never in a steering position, though. Traveling at highway speeds over long distances, truck tires can build up tremendous amounts of heat, especially if they or the tire next to them slightly are slightly under-inflated, hence the thousands if not millions of "road gators" (shed treads of retreaded truck tires) that litter the sides of highways across the US.
ArchGuy1
Fri Aug 16, 2019 2:09 pm
Are retreads on the steer axle of a front end loader fine. Also, are they a good investment for construction companies.
Aesma
Fri Aug 16, 2019 2:51 pm
These things never travel on roads, at least here, I suspect it's even illegal, so the state of their tires doesn't matter that much, as long as they get traction in dirt/mud.
ArchGuy1
Fri Aug 16, 2019 3:25 pm
Where exactly do you live
TSS
Fri Aug 16, 2019 5:07 pm
To make sure we're all on the same page, this ^ is what you mean by "front end loader", right? There are of course smaller versions available.
I'm guessing you meant that as a question, and yes, I don't see why they wouldn't be. Most of the ones I've seen in service, though, the tires that came on them lasted as long as the loader itself did anyway, i.e. if the tires that came on a loader are worn out, chances are the loader itself is too, although the smaller ones that are like a farm tractor with an attachment on the front could be an exception to that rule.
Right off, no, because they can be rented. You'd have to compare the cost of renting one regularly if you need to versus the initial investment of buying one plus maintenance and transportation (if it travels more than a block or two it'll need to do so on a trailer) for the full analysis.
Same here. You might occasionally see one going from one end of a large construction site to the other end via road for expediency, but that's rare.
Aesma
Fri Aug 16, 2019 6:18 pm
My company owns lots of them as it's a big construction and public works company, it still rents a lot of them too, but I have really no ideas on the costs, I'm in IT. I know we're being hurt by the end of a tax exemption on "non road diesel" these things use. Might see electric models soon.
Users browsing this forum: Draken21fx, Dutchy, einsteinboricua, frmrCapCadet, sonicruiser, vrbarreto and 41 guests
