trpmb6
Navy Confirms UFO Videos Real
Wed Sep 18, 2019 12:51 pm
But they denounce the release of said videos and stop short of detailing what they believe the objects are or providing any further context.
These videos originally popped up a few years back when the New York Times released them. Three separate videos, each one contains commentary from flight crew and unexplained objects flying around.
Aliens? Weather Phenomena? Mechanical malfunction of equipment? You be the judge...
https://www.popularmechanics.com/milita ... deos-real/
Armadillo1
Re: Navy Confirms UFO Videos Real
Wed Sep 18, 2019 1:18 pm
"I watched porn that started the same way"
this must be only thing can be said about this news.
casinterest
Wed Sep 18, 2019 2:42 pm
Well, They are UFO's. but my expectation is that someone was flying rockets or heat intensive items, that were launched while on screen and the IR sensors didn't know what to do with multiple items for a bit.
Where ever you go, there you are.
trpmb6
Wed Sep 18, 2019 4:21 pm
Could even be as simple as a meteor coming in.
tommy1808
Wed Sep 18, 2019 4:43 pm
Nah, i would think we can rule that one out. No trail behindert it, and kinda hard to see any geometry yield that apparent trajectory change at the end. It would also not appear black in the visible spectrum, the color temperature of those things is sun level-ish.
Best regards
Thomas
This Singature is a safe space......
seb146
Wed Sep 18, 2019 5:25 pm
I always thought UFO stood for "unidentified flying object"? If they can not identify a flying object, it is, technically, a UFO, right?
Now that no one is storming Area 51, we will not know if it was one of ours or from somewhere else on the planet or not from here.
We had some big storms roll through here last night, so I did not sleep much. That is why I am "off" today.....
You bet I'm pumped!!! I just had a green tea!!!
ChrisKen
Wed Sep 18, 2019 5:44 pm
Correct. It's only the tinfoil hat brigade that jump to the conclusion it must be extra terrestrial.
trpmb6
Thu Sep 19, 2019 12:47 pm
Best regards
Thomas
Good point, the heat given off would make the object appear whiter in the spectrum.
DL717
Thu Sep 19, 2019 12:49 pm
Navy looking to boost recruit numbers by getting some press?
Welcome to Nothingburgers. May I take your order?
Users browsing this forum: smallvoyageur and 45 guests
