Aaron747 wrote:I don't understand what else it is you wish to know.
Sokes wrote:Did he have democratic legitimation to do so?
Sokes wrote:Aaron747 wrote:I don't understand what else it is you wish to know.
What technologies to subsidize with how much.
c933103 wrote:Ia nuclear energy being included in the plan to slow climate change in the US?
olle wrote:c933103 wrote:Is nuclear energy being included in the plan to slow climate change in the US?
The cheapest energy shall win. Today this is not nuclear, oil nor coal.
c933103 wrote:olle wrote:c933103 wrote:Is nuclear energy being included in the plan to slow climate change in the US?
It depends on how you calculate the cost and for what purposes. There are no single answer
One simple example is this;
Power Plant Type Cost (LCOE)$/kW-hr
Coal with CCS $0.12-0.13
CC Natural Gas $0.043
CC with CCS $0.075
Nuclear $0.093
Wind onshore $0.037
Wind offshore $0.106
Solar PV $0.038
Solar Thermal $0.165
Geothermal $0.037
Biomass $0.092
Hydro $0.039
Dutchy wrote:olle wrote:c933103 wrote:It depends on how you calculate the cost and for what purposes. There are no single answer
CC with CCS $0.075
Nuclear $0.093
Wind onshore $0.037
Solar PV $0.038
Geothermal $0.037
Biomass $0.092
Hydro $0.039
What is the source for this, if I may ask. What the cheapest energy source is - ignoring the environmental cost of course - is quite dependent on local circumstances. Off shore wind parks are the cheapest source of energy at the moment in the Netherlands.
bennett123 wrote:What is the cheapest?.
WIederling wrote:bennett123 wrote:What is the cheapest?.
using less ( i.e. being more efficient.
olle wrote:In the source it is stated;
This table compares the US average levelized electricity cost in dollars per kilowatt-hour for both non-renewable and alternative fuels in new power plants, based on US EIA statistics and analysis from Annual Energy Outlook 2019 (data for coal and combined-cycle (CC) with CCS are taken from 2018 report).
So of course if you build onshore wind mills in non populated areas or EU like Lappland (northen Scandinavia) the cost will be lower then try to do this in Netherlands
This was estimated as mentioned for USA in 2018 and the cost today not mentioned 2025 will be much lower for Solar and wind including offshore. Gas in this table is calculated with low USA prices not prices in EU and still it cannot compete.
olle wrote:One simple example is this;
CC with CCS $0.075
Nuclear $0.093
Wind onshore $0.037
...(etc)
Dutchy wrote:Absolutely!the cheapest energy source is .... quite dependent on local circumstances.
olle wrote:Interesting!So of course if you build onshore wind mills in non populated areas or EU like Lappland (northen Scandinavia) the cost will be lower then try to do this in Netherlands
Aesma wrote:And have heard of using molten salts, allowing to make electricity at night, but I guess this has proven difficult/expensive too. Mass produced PV panels, regularly increasing in efficiency and cheapness, are hard to beat.
ER757 wrote:c933103 wrote:Ia nuclear energy being included in the plan to slow climate change in the US?
It should be, but there is a stigma attached to nuclear due to several well publicized accidents. It's also incredibly expensive to build a nuclear plant which is why no new ones have been built in the US for quite some time. When done right, it's clean and has a virtually inexhaustible fuel supply. Yes, waste is an issue but there are emerging technologies that can help with that.
