**Profile Picture/Avatar Upload Issues Thread**
Mon Jul 25, 2016 9:23 am
I may have asked this before and forgotten... :(
airkas1
Head Screener
Re: How do I change my profile pic (Avatar)?
Mon Jul 25, 2016 9:41 am
No problem :)
--> Go to the homepage
--> Most upper right corner
--> "Settings"
--> Choose your new photo
--> Scroll down and click "save"
Mon Jul 25, 2016 9:58 am
You're a lifesaver.
The confusion arose from me only using the forum pages, which have a different menu in the top right hand corner.
airkas1
Head Screener
Mon Jul 25, 2016 11:00 am
Yeah, it is a bit confusing at first. Hopefully the unified header will be implemented soon to bring some structure into it.
Nice avatar choice by the way!
Dutchy
Tue Jul 26, 2016 1:37 pm
I want to have an avatar too ;). I click on my "avatar" in the upper right corner and see 3 things, user control panel, profile and log out, neither of those will bring me to something where I can change the avatar(!) HELP!
airkas1
Head Screener
Tue Jul 26, 2016 3:03 pm
You need to go further up, into the corner. Zoom out your browser to 90% if needed and you will see it.
Wed Jul 27, 2016 2:51 pm
I made this same mistake. Do it from the main airliners.nut page, not from a forum page.
Dutchy
Wed Jul 27, 2016 3:10 pm
Thanks! It worked, Dutchy had a Dutch avatar! ;)
777GE90
Wed Aug 10, 2016 8:23 pm
Thanks this helped me too.
ssteve
Thu Aug 11, 2016 12:48 am
I also had to switch browsers... I suspect I had an ad blocker issue with the interface for setting an Avatar.
Saavy
Sat Sep 17, 2016 1:46 am
I couldn't figure out how to set my avatar but I thought if I poked around in here long enough, I'd find the instructions.
Thank you so much!
Things that go bump in the night are usually caused by cats.
CitizenJustin
Sat Jun 09, 2018 10:32 am
airkas1 wrote:
No problem :)
--> "Settings"
Hi, I’m a bit late to the game and having the same problem. I don’t know if the system has changed or what, but oncant figure out how to change my profile pic. Has it changed? And if so could you point me in the right direction?
Thanks so much.
JohnKrist
Head Support
Sun Jun 10, 2018 5:29 am
CitizenJustin wrote:
airkas1 wrote:
No problem :)
--> "Settings"
Thanks so much.
Kas description is still correct, but a quick link is right here:
https://www.airliners.net/user/account/settings
5D Mark III, 7D, 17-40 F4 L, 70-200 F2.8 L IS II, Canon 50mm 1.4, Sigma 50mm 1.4 ART, Sigma 105mm 1.4 ART, EF 1.4x II, EF 2x III, SPEEDLITE 600EX-RT
Runway28L
Unable to change cover photo on profile
Tue Jun 19, 2018 3:26 pm
I am currently trying to change my cover photo on my profile from one image to another. Whenever I select the new photo I want from my personal folder, the image will load at 0% and nothing will ever happen. It'll just remain being stuck at 0%. Also, adding my personal web address either doesn't carry over, isn't valid, or just simply gets erased when I save.
I have tried several other images to see if they will work but nothing else I have does. Every image I'm selecting is 1200x800px, well within the limits. I have decided to wait several days a few times and tried again, but the same thing happens every single time. Is this some known issue/bug that others are also dealing with?
cpd
Wed Sep 05, 2018 8:28 am
I'm also having the same problem and cannot find any way to replace the avatar I have currently on the forum. It just doesn't want to change. It has changed in the settings area linked above, but on the forum it stubbornly remains as before.
I searched this forum for a solution and found nothing, so hence this question. :?:
Runway28L
Thu Sep 06, 2018 2:13 am
+1
Haven't been able to change mine either. It also took me several tries to finally get my cover photo changed.
airkas1
Head Screener
Fri Sep 07, 2018 9:37 am
I've asked the developer to have a look at possible issues regarding the avatar issue.
airkas1
Head Screener
Fri Sep 07, 2018 9:34 pm
He says it's a caching issue. He changed Mariner's avatar after his passing and says it shows the change after ~24h for him. Could you guys please try again?
Runway28L
Sat Sep 08, 2018 5:37 am
Just tried again Kas. Looks like the issue still exists so far. I've only given it a few minutes though.
I am also unable to save a link to a website (Instagram, Flickr, etc.)
cpd
Sat Sep 08, 2018 11:00 am
Just tried it then, will check back tomorrow.
And why am I not surprised about caching issues. The bane of my existence in my real world job! :bomb:
cpd
Sun Sep 09, 2018 1:14 pm
I'm afraid it didn't work.
airkas1
Head Screener
Sun Sep 09, 2018 2:17 pm
So I see. I will inform the developer and report back once I know more.
cpd
Sat Sep 15, 2018 10:27 pm
Any word from the devs?
Thanks.
Runway28L
Fri Sep 21, 2018 2:50 pm
Hey Kas, I was able to change mine last night on my Mac and it updated after a few minutes. But it is not showing up on my smart phone and still shows my old avatar. Is this normal?
Also, I originally chose one image for an avatar but I changed it again to what should be the current avatar. It updated for the forums on my computer but it did not for my profile and the photo database.
cpd
Sat Sep 22, 2018 7:26 am
Found something - delete your old avatar, save the changes, leave it blank for a few days.
Now go and upload your new one. It took effect immediately! :confused:
I'm guessing that is allowing all the cache to clear out on the servers. I'm also a Mac user like Runway28L above.
cpd
Sat Sep 22, 2018 8:17 am
Do you have cache on your smart phone browser? Try clearing the cache and see what happens. Also try in a private browsing tab - see if that works (like incognito mode that Chrome has).
Those are the usual tricks we try at work in solving caching issues on our websites when updates don't come through, before clearing the server cache (which is a change request). In our case, updates usually go through quickly, but if not, no more than 24 hours. You can also try appending random query strings to the URL, that can help on static sites, but something like this forum might not take that so well.
Runway28L
Sat Sep 22, 2018 1:08 pm
Just cleared my search history for Safari. Looks like that worked. Thanks!
Runway28L
Sat Sep 22, 2018 8:58 pm
Actually upon further review, my photo DB avatar (which is seen when I click the link in my signature) will not update to my forum avatar on my screen. I even tried signing in and out while clearing my search history and that doesn't seem to be doing anything.
airkas1
Head Screener
Wed Sep 26, 2018 3:19 am
Hey guys,
Sorry, I forgot to follow up on this with you, although I did do so o the backend with the developer. If cpd's workaround works, then great! At this moment I don't have a better solution to the issue.
Kilopond
Sat Mar 09, 2019 9:33 pm
Something must have changed since this thread had been started... However, for the absolutely first time in my life I'm unable to upload an avatar pic. What's the trick to avoid an anoying errror message?
tigerzhong13
Mon Mar 11, 2019 12:01 am
I just registered today and when I tried to change the profile pic it's got blocked by cloudflare. Everything else is fine.
longhauler
Mon Mar 11, 2019 7:46 pm
It did the same thing to me.
Is this new?
I have changed my profile picture in the past.
PanAm_DC10
Community Manager
Wed Mar 13, 2019 1:09 am
Hi All
Could you please provide the following details so we can look into this for actioning.
-actions that led to the error with URL
-device info and time stamp
-screenshots of error
-the other is your username and link to profile which I can take care of
Paul
Ask the impossible to achieve the best possible
tigerzhong13
Wed Mar 13, 2019 8:55 am
PanAm_DC10 wrote:
Hi All
Paul
https://imgur.com/a/NSrVxV9
Error message
This happens when you upload a profile picture here:
Device: Windows 10 PC, 0850Z 13MAR2019
longhauler
Wed Mar 13, 2019 12:12 pm
I got the same thing from my iPad using either Safari or Chrome.
Oddly enough I had changed my picture last week ... I was trying to change it again.
PixelPilot
Settings / Avatar
Sat Mar 16, 2019 1:40 am
Greetings.
Whenever I am trying to save avatar (correct size, weight and file format) I get "You have been blocked" from airliners.net page.
It uploads ok, crop window opens, i can edit it but when I go to save that's what happens.
Obviously here I am posting but any idea what could be wrong?
I just want to have an nice, aviation related avatar :)
This is the page i'm landing at:
SQ22
Re: Settings / Avatar
Sat Mar 16, 2019 7:42 am
PixelPilot wrote:
Greetings.
Please see reply by Paul above.
PixelPilot
Sun Mar 17, 2019 1:46 am
SQ22 wrote:
PixelPilot wrote:
Greetings.
I did and it's not working.
I described every single step.
I mean there's not much else you can say. Every single time I end up on that page with error and no avatar.
longhauler
Sun Mar 17, 2019 8:54 pm
I did the same thing, on both a PC WIN10 and iPad with the same results. I too forwarded the information.
No answer and it still does not work.
I am curious ... are we the only ones for which this is not working? Or just the only ones that have tried?
andrewmoir
Profile picture update error
Mon Mar 18, 2019 5:39 am
"Blocked by CloudFare"
Keep getting this error.
SQ22
Mon Mar 18, 2019 6:59 pm
Please see reply #32, but I have asked for an update from the developers.
PanAm_DC10
Community Manager
Re: How to change profile pic (Avatar) and upload errors discussion thread
Mon Mar 18, 2019 11:03 pm
Thanks for your responses I have forwarded the details to the developers for investigation and am awaiting their response. Will update you when I hear back from them in the meantime please continue to report as per reply # 32
Thanks and regards
Paul
alexandro
Profile picture
Wed Mar 20, 2019 1:33 pm
Good morning I'm Alexandro Dias here from Teresina Piauí Brazil I'm having trouble putting my profile picture
I place the photo at the specified size of 100/100 plus hour
that I will save appears a messages saying that I was blocked
What should I
atcsundevil
Wed Mar 20, 2019 3:23 pm
What should I
Please see the above responses.
acavpics
Unable to add profile, background pic
Sun Mar 31, 2019 9:25 pm
Recently, I have tried to add a profile picture, and a background picture to my page. Once I select "save", I get a page saying "Sorry, you have been blocked,You are unable to access airliners.net." Could someone please let me know how to get around this?
atcsundevil
Re: Unable to add profile, background pic
Sun Mar 31, 2019 9:29 pm
acavpics
Sun Apr 07, 2019 2:16 am
So from what I read in the posts above, I believe that there is no solution? - Correct me if I'm wrong as I might have missed something.
atcsundevil
Sun Apr 07, 2019 2:48 am
I'm not sure if they've found a solution yet — it's not something in our purview. I recommend emailing [email protected]. They would be aware of any possible solution. All I can do is apologize for the inconvenience, but unfortunately there's nothing that we as moderators can do to solve this issue.
longhauler
Fri Apr 12, 2019 1:12 am
I notice that all those that raised the issue, still do not have avatars on their profiles. That would make me think it has not been solved.
One thing of which I was curious, is whether it is just us ... or can no one put/replace their avatar picture? I would think either way, it would make troubleshooting easier.
atcsundevil
Fri Apr 12, 2019 1:21 am
I think it's just an issue affecting some users. I don't know if it's a browser issue or an account/site issue. Again, it's not really something that we as moderators are involved with, so I know about as much as you. The developers are aware of it, so if there isn't a fix yet, then all I can say is that hopefully there will be one soon.
Users browsing this forum: No registered users and 51 guests
