AC02
Upload bug report
Tue Oct 09, 2018 5:52 am
Hi,
recently while uploading photos to A.net, I found a bug that prevented me from submitting:
If I select "Boeing 737-89L" under "Version", the submission just keeps saying "Your form submission was incomplete. Please review the form and provide missing and/or correct invalid data. "
Also under "version" it says "This value is already used."
I tried both autocomplete and manual input but neither works out.
Hope somebody can figure out this problem, thanks!!!
airkas1
Head Screener
Re: Upload bug report
Tue Oct 09, 2018 8:55 am
What is the registration?
AC02
Tue Oct 09, 2018 8:51 pm
B-5447.
I also tried other registrations with the same aircraft type, none of them working..
airkas1
Head Screener
Thu Oct 11, 2018 9:36 am
This has now been fixed.
AC02
Thu Oct 11, 2018 10:53 pm
Just tried and it works now. Thank you so much! :D
dxmekch
Wed Oct 17, 2018 11:36 am
On Sunday I received an E-Mail that the following picture was accepted to the site:
https://www.airliners.net/photo/Italy-A ... EX/5226369
But it seems like this picture isn't online furthermore it doesn't show up in my profile under accepted nor under rejected.
airkas1
Head Screener
Wed Oct 17, 2018 12:05 pm
Probably has to do with the issues we experienced the past few days. Please upload the photo again as priority, with a note to the screeners that you were asked to do so because the phioto got lost.
trijetsonly
Mon Oct 22, 2018 12:18 pm
Something is not right here
https://www.airliners.net/photo/Alitalia/Airbus-A330-202/5236589
Description says Alitalia A330 in Toronto.
Picture shows an EastarJet 737 in extremely poor quality.
Happy Landings
airkas1
Head Screener
Mon Oct 22, 2018 12:45 pm
I've asked the editors to fix the info, thanks for the FYI.
AC02
Sun Dec 30, 2018 6:18 am
Here's another bug I met:
If I select "COMAC" under "Manufacturer", there's no option of "COMAC C919" under "Generic Type". Therefore, I tried to create "COMAC C919" manually, but it says "This value is already used."
Then I used autocomplete to try to fill the info of C919 (the reg I used is B-001C), but weirdly the section of "Manufacturer" doesn't appear, only "Generic Type" and "Version" appear.
airkas1
Head Screener
Sun Dec 30, 2018 11:17 am
Whenever you can't find what you're looking for, switch to "no" at "Aircraft Manufacturer Filter Enabled?" and you will likely find what you're looking for. It's been likely that since the site revamp. So it's not that weird, that's what the function is there for. Unfortunately the editors still don't have the necessary tools yet, so the options have become a bit corrupt. Carefully choosing the correct info is important.
Can I ask why you didn't use the autocomplete in the first place?
AC02
Sun Dec 30, 2018 1:38 pm
Well because I wanted to add a new registration that wasn't in the database (B-001D)...
airkas1
Head Screener
Sun Dec 30, 2018 1:40 pm
Ah right :)
