enilria wrote:I hate to cry safety, but I don't think two passenger planes flying 750 feet apart at 150-200 mph is safe.
rickabone wrote:Perfectly safe and perfectly legal. That's what visual separation is all about. Some pilots are uncomfortable with it, some love it. As a controller at SFO, the closer they are to parallel the better because that gives us more of a hole to get the Rwy 01L/R departures out. This is our preferred approach...
iahcsr wrote:The big problem with SFO is when they don't have clear skies... That when flights have to be majorly staggered on approach. This reduces the arrival rate and aircraft have to be held, sometimes for hours, at their departure point. With current technology the only way to solve this problem is to build a new runway or two out in the bay... And the treehuggers in SFO will never permit that.
9V-SPJ wrote:What's better about that use of the 28s?Flights at SFO landing on the 28s on visual conditions typically use the Simultaneous Offset Instrument Approach (SOIA) to allow for better use of the 28s
rickabone wrote:It's a beautiful thing when it works this well.
b747400erf wrote:iahcsr wrote:The big problem with SFO is when they don't have clear skies... That when flights have to be majorly staggered on approach. This reduces the arrival rate and aircraft have to be held, sometimes for hours, at their departure point. With current technology the only way to solve this problem is to build a new runway or two out in the bay... And the treehuggers in SFO will never permit that.
It is not only treehuggers that care about the environment. And SFO is more limited by OAK across the bay. Where would you put the runway? You could extend the 1's so more heavies can take off from there but most people would not agree the pollution and other effects are worth it.
BartSimpson wrote:rickabone wrote:One question though: is is somehow related to the aircraft type - say, you wouldn't prefer that with a B737 / A380 combo?
iahcsr wrote:With current technology the only way to solve this problem is to build a new runway or two out in the bay...
iahcsr wrote:A new runway(s) could only happen by landfill in the bay obviously... And that is what will never be permitted to occur. I don't see this as a bad thing... Just a limitation.
timz wrote:9V-SPJ wrote:
Presumably airliners never land side by side at SNA, with runway centerlines 500 ft apart-- but do airliners land alongside Cessnas?
flyPIT wrote:As mentioned this is nothing new for SFO. However it was also commonplace at several other US airports with dependent parallel runways. Places such as EWR, BOS, DFW, and LAX:
https://www.airliners.net/photo/Untitled/Grumman-G-1159-Gulfstream-II-TT/150311
https://www.airliners.net/photo/Shuttle-by-United-%28United-Airlines%29/Boeing-737-522/25176
But it doesn't seem as common at these other airports as it used to. Anyone know why?
Does anyone know how to imbed photos from the A.net database into a thread?
uta999 wrote:This would never happen in the UK.
How did they both join final at almost the same time and altitude?
What about a burst tyre on landing, a go around of one or both aircraft (vortex), or a crash similar to the Korean 777, where the plane inverted and landed between the parallels.
rickabone wrote:BartSimpson wrote:rickabone wrote:One question though: is is somehow related to the aircraft type - say, you wouldn't prefer that with a B737 / A380 combo?
IF wake turbulence is an issue then the larger (wake category) aircraft cannot pass the smaller. They can get right next to each other and the smaller is allowed to pass the larger. At SFO we just went through "Wake ReCat" that established new wake turbulence aircraft categories and rules we need to follow but that is the general rule.
Wake turbulence will not be an issue in parallel approaches because it is behind (and typically below) the leading aircraft. If they are, basically, side by side, you will not encounter it.
Web500sjc wrote:If you go out and measure them, I'll bet they turn out to be 500 or 501 ft.@SNA the runway centerlines are 525 feet apart
