chrisnh
EKA380: Who gets it first, SEA, ORD, BOS
Wed Jul 13, 2016 10:44 pm
With so many A380s to deploy, which of these three cities will likely see it first? All are at various stages of 'readiness' for the A380.
piedmontf284000
Re: EKA380: Who gets it first, SEA, ORD, BOS
Wed Jul 13, 2016 10:53 pm
BOS at 2 to 1 odds. ORD at 3 to 1. SEA at 5 to 1.
FlyPeoria
Wed Jul 13, 2016 11:08 pm
Remember that EK is using an A380 on a scheduled ORD flight July 19. Probably a test for a future deployment.
Ammad
Wed Jul 13, 2016 11:11 pm
ORD, BOS, SEA. In this order.
HALtheAI
Wed Jul 13, 2016 11:36 pm
SEA can't even handle it and last I heard, they don't intend to redo the runway layout to accommodate it.
dfwjim1
Wed Jul 13, 2016 11:46 pm
Lol...DFW
jcwr56
Thu Jul 14, 2016 1:06 am
MCO
chrisnh
Thu Jul 14, 2016 1:18 am
I agree on the ORD-BOS sequence; EK has announced a trial flight for ORD but not BOS. But I do think both cities will debut the A380 within months of each other.
wedgetail737
Thu Jul 14, 2016 2:34 am
SEA's runways are not equipped to handle the A380. The 747-8 is pushing it.
Fatbus
Thu Jul 14, 2016 3:00 am
Sea is code F compliant, EK uses it as an enroute alt. Recurrent sim training used Sea . 1 380 gate.
airway1
Thu Jul 14, 2016 5:36 am
BOS doesn't need a test trial for the A380 as Logan gets diverted A380 flights from NYC in winter. I think its an approved airport as per FAA regulation.
PerfectGriffin
Thu Jul 14, 2016 6:44 am
Think it will be ORD since BOS and SEA are already served twice daily.
Cipango
Thu Jul 14, 2016 9:07 am
Also British Airways are operating the A380 to BOS next February and March.
Let's fly! Unless it's on a CRJ 200, then I'll stay down here.
chrisnh
Thu Jul 14, 2016 10:09 am
Although several A380s have diverted to Boston (Singapore, Korean, AF, EK, LH and maybe others), none of them pulled up to a gate to deplane and receive passengers I don't believe. As diversions, they landed and parked and waited things out. The BA 'trial' is pretty much a series of 'familiarization flights' as I see it, to get the folks on the ground a sense of the mechanics involved...from how the plane and the jetways operate together all the way to CBP and what kind of 'flow time' penalties an A380 presents. Being in the dead of winter, I don't believe any of these BA A380 flights will be as 'full' as might be expected over the summer months, so it isn't because the capacity is needed.
As for EK, it poses an interesting situation because now they pull the 777-300ER over to C after it empties out from Dubai...a scenario they won't be able to accommodate with the A380. So if only one of these A380-capable gates is ready this winter, and BA is using it, then EK will have to wait until the 2nd one is ready. BA isn't going to want their A380 towed away so EK can have the gate. EK is on the ground for around 10 hours; the BA flight only 2-3. And I can't see EK putting the A380 on their daytime flight out of Boston, because that is the weaker performer. Perhaps they will 'trial' the A380 on the morning inbound because it's pretty much a dead terminal when he comes in and goes back out.
soectre99
Thu Jul 14, 2016 11:15 am
Surely BOS, I fly PER-BOS quite regularly on CX, QR or EK. EK is always 95-100% 773 capacity, with mainly passengers from Southern Asia connections.
dubaiamman243
Thu Jul 14, 2016 11:34 am
I would say ORD, BOS then SEA
The next airline CEO :crossfingers:
airbazar
Thu Jul 14, 2016 12:29 pm
BOS will be fist for sure. The only reason EK has not operated a trial to BOS is because there is nothing to try out yet. The A380 gates at BOS will be ready at the end of this year and I would be surprised if we don't see an EK A380 operating here for the busy Christmas season.
BA has already announced A380 service for February, so I guarantee you that EK won't want to be upstaged at BOS.
UAEflyer
Thu Jul 14, 2016 4:20 pm
BOS, SEA & ORD all will get the A380 in 2017
alexinwa
Thu Jul 14, 2016 4:31 pm
Where will they Park it? Cargo ramp? SEA has a shortage of W/B gates as is. I doubt they will lose it for a single 380.
You mad Bro???
Stitch
Thu Jul 14, 2016 4:44 pm
alexinwa wrote:
Where will they Park it (at SEA)? Cargo ramp? SEA has a shortage of W/B gates as is. I doubt they will lose it for a single 380.
As noted by Fatbus, SEA can handle an emergency diversion of an A380, but as of 2015, the airport did not have a master plan in place to accommodate normal A380 operations due to the wingspan. While the 747-8 and A380-800 are both FAA Category F due to their wingspans, the 747-8's span is 37 feel less than the A380's and that makes a difference as the 747-8's wing can clear Taxiway B with traffic on it when operating on Runway 19L / 34R whereas the A380's cannot. So Taxiway B traffic would need to be held while the A380 was on 19L / 34R.
That being said, a single daily A380 operation would not impact SEA too much, so I could see the airport developing a plan to accommodate a daily service from EK to replace the two-daily 777 services.
http://www.bizjournals.com/seattle/news ... -into.html
https://upload.wikimedia.org/wikipedia/ ... _diagram(2).svg/2000px-Seattle-Tacoma_International_Airport_diagram(2).svg.png
Sooner787
Thu Jul 14, 2016 5:29 pm
DFW on September 1st :) :)
airbazar
Thu Jul 14, 2016 5:35 pm
IIRC the main issue with the A380 vs. 748 is not so much the wingspan but the outboard engines which are further out on the A380 thus putting the jet blast over the "grass" where it can lift a lot of debris as opposed to over the taxiway. BOS's plan is to do just that, to hold adjacent traffic when the A380 is taxiing. Fortunately for BOS there have been enough diversions here so the folks should know how to handle it by now.
jreuschl
Thu Jul 14, 2016 5:36 pm
So ORD is set for A380 now?
Galvan
Thu Jul 14, 2016 6:51 pm
ORD is set for A380 services. T5 gate M11 can now Handle the A380, RWY 28/10C will be able to handle the aircraft. EK will be sending the A380 into ORD 7/19 as a trial run.
jcwr56
Thu Jul 14, 2016 11:48 pm
I'll split hairs, I would say ORD is in theory ready to handle the A380. Between Air traffic, taxiways and operations from the aircraft arriving at the gate, to attaching the dual bridges (which was just trail run on a LH 748 today, it was interesting to see a bridge attached to the upper deck door) to roadways closures on push back, hold room issues to ticket counter queuing. Lets not get too excited EK or anyone else will be rushing to start service.
After Tuesdays EK flight, they'll be plenty of meetings to discuss what went wrong to, oh s**t, how was this missed items.
ORD will get its' 380 but not before next summer.
Galvan
Fri Jul 15, 2016 3:37 am
Very good points. I might be mistaken, but ORD has been able to take A380 diversions at least since January?
On the Subject of A380 service.
Do you see LH and/or BA being the airlines that bring the 380 into ORD in addition to EK?
Does the newly announced ORD expansion plans include more 380 capable gates?
UAEflyer
Fri Jul 15, 2016 10:52 am
SEA will be A380 ready by the second half on 2017, although EK should have some respect to Boeing and don't send A380 to their territory
cloud4000
Fri Jul 15, 2016 1:02 pm
Correct if I'm wrong, but BOS doesn't have the gate facilities to handle a 380? I know EK said it would like to do double daily with 380s, but it was due to lack of facilities.
Boston, USA
airbazar
Fri Jul 15, 2016 1:12 pm
BOS is expanding the terminal and building 3 A380 gates. The full project completion date is set for Summer 2017 however there are rumors that at least one gate will be ready by the end of 2016 and BA has already announced A380 service to BOS starting in February.
http://www.routesonline.com/news/38/air ... bmar-2017/
chrisnh
Fri Jul 15, 2016 4:01 pm
None of the diversion A380 landings (including yesterday's AF) have posed a problem because the planes just sit where they are told to park and never pull up to the terminal. I personally think 2x A380s to Dubai is a stretch for Boston. I think the right mix would be to downgrade the morning one to a -200LR and upgrade the evening one to the A380. But I also realize there aren't many -200LR's in the EK fleet (ten, I think) while they've got well over 100 of the -300ERs. So a -300ER (AM) + A380 (PM) seems to be a good mix.
The question is whether EK announces a 'trial' at BOS much like they'll do next week at ORD. If only to somewhat upstage BA by legitimately being 'first' at BOS with the A380 even though everyone knows BA will have it in there February & March. Others have suggested they'll do the trial over the Christmas holiday season and I'll bet they're right.
7BOEING7
Fri Jul 15, 2016 4:37 pm
What are they doing? I know they're planning on remodeling the South Terminal (international arrivals) and adding a lot more widebody gates but that's still years off.
lavalampluva
Fri Jul 15, 2016 5:13 pm
My suspicions are the ORD will be next.
Remind me to send a thank you note to Mr. Boeing.
chrisnh
Fri Jul 15, 2016 5:47 pm
Seems like BOS and ORD are neck-and-neck in this unofficial poll! I say it's a coin-flip, notwithstanding the fact that ORD has a July 19 'trial' while BOS doesn't.
alexinwa
Sun Aug 14, 2016 10:54 pm
Im sorry.....IMHO SEA has bigger fish the fry than EK. The DL AS battle is forefront!!!
You mad Bro???
Miami
Mon Aug 15, 2016 12:30 am
Technically ORD got it first with that one-off.. ;)
Aviation is proof that given, the will, we have the capacity to achieve the impossible. - Eddie Rickenbacker
RL777
Mon Aug 15, 2016 12:52 am
ORD then BOS. SEA can't currently handle the A380 and the airport authority has made it clear that it doesn't intend to renovate its infrastructure unless there is significant interest from multiple carriers. I would say the chances of SEA seeing the A380 from any carrier is nearly zero.
frmrCapCadet
Mon Aug 15, 2016 1:05 am
I am sure SeaTac will welcome 380 service to Seattle, there may be some costs which would need to be recouped by fees. But we would like to see 380 service to our airport, Boeing fan boys or not.
airbazar
Mon Aug 15, 2016 2:21 am
Why? What does the Port of Seattle have to do with that battle?
DBun
Mon Aug 15, 2016 6:18 am
I believe one of the reasons EK flies double daily B777 to SEA is to pick up replacement parts for their 777 fleet.
Replacing these flights with the A380 would yield more passenger space, but less cargo space (which is what they really want).
787fan8
Mon Aug 15, 2016 11:13 am
By far ORD will get it first. You know when EK flies a one off A380 they'll come back. BOS would be second. SEA can't even handle the A380 yet, so it's an obvious third.
Atlanta is an incredibly cool city - Andrew Lincoln
Future Auburn graduate
airbazar
Mon Aug 15, 2016 1:33 pm
I very much doubt that would be a deciding factor. It's not like they fly to TLS and of course, Boeing like many other industrial manufactures source parts from many suppliers, the biggest one of them being Spirit who is not in Seattle and has facilities all over the World. I'm not even sure that a lot of Boeing parts are provisioned from Seattle.
BOS first, SEA second, ORD maybe. Lets not forget ORD was only the 8th or so U.S. destination for EK and it's only a single daily so far, which tells me demand is not great. By contrast, SEA was the second U.S. destination to go double-daily, after only JFK. After the debacle that was IAH I don't expect them to deploy an A380 on another marginal ULH route. Meanwhile BOS is already at 2x daily with 77W.
PerfectGriffin
Mon Aug 15, 2016 8:02 pm
They started ORD late but perhaps it's because ORD already had so much competition. EK has much less competition at SEA, and BOS has only recently become competitive with services to Asia.
ER757
Mon Aug 15, 2016 8:51 pm
They are but it certainly wouldn't be a deciding factor on whether EK were to deploy the A380 to SEA. If the Port of Seattle ever did make the necessary upgrades, it's a pretty good bet EK would rather bring in a single A380 instead of a 77L and a 77W. They do haul quite a lot of cargo out of here, but they could always start freighter service a couple days a week if it's enough - maybe add SEA to the ORD/DWC run - make it a loop DWC/SEA/ORD/DWC or similar
chrisnh
Mon Aug 15, 2016 9:12 pm
On a related note, BA has pushed back the debut of the A380 to Boston until spring '17 at the earliest. The plane was loaded into the schedules for February and March but got yanked...presumably because the gates won't be ready. However, this trio of A380 gates will be ready soon thereafter because you can see construction is already far along.
MaxxFlyer
Mon Aug 15, 2016 9:19 pm
OK, this is funny. I needed the chuckle. I have been under the impression SEA is 2x with 772/77W is belly cargo driven. I love SEA, but it's bursting at the seams. Until they get more international gates, it's going to remain a zoo during certain hours.
ER757
Mon Aug 15, 2016 9:37 pm
UAEFlyer - where did you get this info? To the best of my knowledge they'll do no such thing. I would love to be proven wrong, nothing with please me more than to see the Big Bus touch touch at SEA. Do you have a source for this news? If so please share it
flyer1225
Mon Aug 15, 2016 10:02 pm
All three airports will recieve the EK A380 in time, but I'm guessing ORD in late 2017, BOS in early to mid 2018, and SEA in late 2019 or whenever it can accommodate it.
6E/9W/AA/AF/AI/AS/B6/BA/DJ/DL/EK/FL/HA/IC/IT/JQ/LH/LX/OS/QF/S2/SG/UA/US/VS/VX/WN
747megatop
Mon Aug 15, 2016 10:39 pm
ORD first; and then...maybe BOS?
Kno
Mon Aug 15, 2016 11:09 pm
Any photos of that 747 with the jetway connected to the top? WOuld be cool to see the novelty of a 747 top boarding.
Viscount724
Tue Aug 16, 2016 2:14 am
As a sidenote, BA had two A380 medical emergency diversions to BOS a day apart last month, one from LAX to LHR on July 20 and another from SFO to LHR on July 21. Following from Transport Canada occurrence reports. Aircraft were over Quebec at the time. The LAX-LHR flight originally requested to divert to YUL but then changed the destination to BOS.
A British Airways Airbus A380-800 (BAW268) from Los Angeles, CA (KLAX) to London, England (EGLL) declared PAN PAN due to a medical emergency and requested a diversion to Montreal, QC (CYUL). The aircraft dumped fuel at FL380 from 1012Z until 1016Z. The pilot requested ambulance to be ready upon arrival. At 1028Z, the pilot requested a diversion to Boston, MA (KBOS). Boston ARTCC was advised. No impact to operations.
A British Airways Airbus A380-800 (BAW6B), from San Francisco, CA (KSFO) to London, England (EGLL), requested to divert to Boston (KBOS), MA because of a medical emergency (sick passenger).
Both flights arrived LHR around 4 hours late.
