quiet1 wrote:Since this seems to be more of a theoretical discussion: How about a T-tail with aft-fuselage-mounted engines a la DC9?
SomebodyInTLS wrote:You would have to change to a T-tail as well, but the big problem is you're completely reconfiguring the basic aircraft - i.e. where all the the mass, lift and thrust vectors are centered. In effect, your entire aircraft is now "wrong" and needs a complete redesign and re-certification...
767333ER wrote:quiet1 wrote:Since this seems to be more of a theoretical discussion: How about a T-tail with aft-fuselage-mounted engines a la DC9?
That would have been the 7J7, but Boeing kept the 737 instead.
Yflyer wrote:For that matter, weren't there some early 737 concepts that were basically just a shrink of the 727 with two engines engines instead of three?
a320fan wrote:The VFW 614 is a clear example that the design can be used, however that aircraft was limited to Mach .65 due to flow separation around the pylon.
