OA940 wrote:So it still could be a terrorist act. Huh, didn't see that coming.
hoya wrote:Is it possible for aerodynamic forces to cause the breakup after loss of control of the aircraft?
Does anyone have the #'s on the causes of accidents that occur when the flight is at cruise? I suppose it is a fairly samll sample size but still would be good to see big picture.
An Egyptian aviation official said the voice recorder from the cockpit indicated that the mood there was relaxed in the minutes before the plane veered off course.
Crew members were playing music and chatting amiably when the pilot, Capt. Muhammad Shoukair, 36, suddenly said there was a fire on board and asked the co-pilot, Muhammad Mamdouh Assem, 24, to get an extinguisher. That was the last human sound the recorder captured.
rfields5421 wrote:In flight aerodynamic breakup after loss of control is very possible. Especially at the altitude this aircraft was flying. It was over 7 miles/ 10 km high. That is a long way for a plane to travel if there is no control input.
rfields5421 wrote:Yes, planes are designed to fly at a basically aerodynamic position without human input.
7BOEING7 wrote:Not exactly. As far as Boeing airplanes are concerned no matter how well trimmed they are for straight and level flight, within minutes the 727 thru 767 would be out of control without any pilot input. The 777 would maintain altitude but would roll off left or right until reaching BAP (bank angle protection).The 787 is the only Boeing airplane that would maintain straight and level flight with no pilot intervention. In a degraded flight control mode (direct) on the 777 and 787 they would behave just like the other Boeing airplanes without pilot input. I'm guessing Airbus airplanes in a similarly degraded mode would also go out of control with no pilot inputs.
smokeybandit wrote:I'm going with the small meteorite hitting the cockpit theory
I still think that the time frame is very short for a technical fault Everything in a plane is some form of fire protected and this has been tested over and over again. Even the 787 battery failures did not cause a big fire and that was a lot of energy. Imho it needs very unlikely conditions to be a technical fault. For example a device with a battery fault and a fault in the oxygen system at the same time. Imho the most likely reason is an incendiary explosive device planted in the plane. Something like a white phosphorous grenade. This burns so hot and ignites on its own, that the fire protections in place are unable to control it, it creates lots of smoke in a short time and it burns hot enough to quickly cause critical damage to structures.
There is nothing to suggest that a fire associated with the onboard oxygen supply could not have been the cause. It is a far simpler explanation than many presented, and there have been previous instances on other types. It possibly can happen, and happens very rapidly.
http://avherald.com/h?article=44078aa7/0000
OA940 wrote:The avionics bay doesn't have smoke detectors (I think).
zeke wrote:OA940 wrote:The avionics bay doesn't have smoke detectors (I think).
There is a smoke detector in the outflow duct from the avionics that will pickup smoke in the cockpit or avionics bay.
Air is drawn past the the displays and controls in the cockpit before going into the avionics bay for cooling the cockpit instruments etc.
