commavia wrote:I think we can now definitely see that this is not Herb's airline anymore
piedmontf284000 wrote:The Herb Kelleher days are a very distant memory....
enilria wrote:I don't think the problem has anything to do with not spending enough money. They are spending a crap-ton on the cutover to Altea. The mistake was WN taking soooooo long to cutover to a modern system. They waited much much too late and tried to keep the old system running with bailing wire and electrical tape for so long that now unwinding the mess of kludges that were created to keep it running makes it very hard to cutover and maintain the old system...particularly both at the same time.
usflyguy wrote:piedmontf284000 wrote:The Herb Kelleher days are a very distant memory....
Except this IT debacle is what Herb built... this is all his. By being thrifty and pinching pennies instead of upgrading over 30 years, this is the final result.
hivue wrote:commavia wrote:I think we can now definitely see that this is not Herb's airline anymore
But it sounds like it may be his IT infrastructure.
DfwRevolution wrote:You're absolutely right. So what should they do? Fire Kelly? The fix to this problem was already in progress before the system failure.
I think we are burying the lead here. What organization on earth needs 20 board members. Holy smokes. Jesus only needed 12.
jetmatt777 wrote:Is it possible to build new IT from scratch and once it is ready, have a reservation cutoff date? For example any attempted reservation after March 1 would go into the new system, and anything prior to that would be booked in the old system.
klkla wrote:I think Kelly has had enough time in the job that he can be held responsible for this issue.
usflyguy wrote:Except this IT debacle is what Herb built... this is all his. By being thrifty and pinching pennies instead of upgrading over 30 years, this is the final result.
klkla wrote:usflyguy wrote:piedmontf284000 wrote:The Herb Kelleher days are a very distant memory....
How long as Kelly been in charge? How long has it been since Kelleher gave up day-to-day control? I think Kelly has had enough time in the job that he can be held responsible for this issue.
commavia wrote:In general, I agree that the issues now facing Southwest are, in many cases, years in the making. These issues are the natural growing pains of a business that is steadily "growing up" and embracing the reality - much as its culture may have tried in some ways to resist it in recent years - that it's not the small, nimble competitor it once was. Southwest is now every bit as much the large, lumbering giant of a company as it started out competing against - far larger, in fact, than any of the competitors it faced back in 1971. As such, investments like IT are far, far more critical than they ever were back then, and the lack of investment in those areas - perhaps exacerbated by the fuel hedges hiding a proverbial multitude of sins in the 2000s - are definitely costing Southwest big time now.
commavia wrote:Southwest will figure it out. It's a generally well-run company with a lot of very smart, very motivated employees. But culturally, yeah - it must be said - Southwest is not the airline it was when Herb was there. The unions crossing the Rubicon of openly calling for the CEO's firing - that's not something one would historically expect at Southwest, to say the least.
enilria wrote:It's actually a testament to how much WN has going for them that all the constraints caused by their archaic technology hasn't put their earnings outside of a competitive level. OTOH, one can imagine they would be significantly beating everybody else if they had fixed these problems and the solution was not overly costly.
commavia wrote:Wow. As if we needed another reminder ... I think we can now definitely see that this is not Herb's airline anymore, and that - for better or worse - the Southwest of the past is definitely gone in many (if not most) ways.
piedmontf284000 wrote:You don't think the fact the pilots have gone without a contact for 4 years has anything to do with them voting 20-0 to oust their CEO and COO nor calling them out about stock buybacks? Puhlease.
par13del wrote:are seeing the birth of another legacy?
commavia wrote:par13del wrote:are seeing the birth of another legacy?
In many ways, I think that ship has already sailed. Much as most of the media and pretty much the entirety of the politicians and bureaucrats in the U.S. government have completely missed it, Southwest has been functioning increasingly just like one of the network carriers for some time now. Indeed, many - though certainly not all - of the hallmarks of the Southwest business model that differentiated it from the network airlines have vanished in the last 10-15 years. Southwest still has only a single fleet type, only one class of service, open seating and free checked bags. But on the flip side, Southwest today is flying directly into busy, congested close-in airports in direct competition against major competitors, with all the higher revenue and cost that entails. Southwest operates a constellation of huge hubs around the U.S. (LAS, PHX, DEN, HOU, MDW, BWI) that cater to tons of connections going in all directions. Southwest long ago abandoned the 20-minute turn and today turns similarly-sized aircraft at something far closer to the speed of AA, Delta and United. Southwest has a multi-tiered frequent flyer program, has moved heavily into corporate sales, is flying extensively internationally, and on and on.
Southwest today looks far more like a network airline than it does like the original Southwest. Not saying that's good or bad, but that's reality as many of us have long seen it.
BestWestern wrote:Comparisons to DL / NW system merge aren't the same, as DL NW shared the same system architecture in their Joint Venture Worldspan, which resulted in an easier merging of data.
par13del wrote:So the future for WN is to mirror union / management relationships like the other legacies
deltal1011man wrote:commavia wrote:Wow. As if we needed another reminder ... I think we can now definitely see that this is not Herb's airline anymore, and that - for better or worse - the Southwest of the past is definitely gone in many (if not most) ways.
It is really a shame. One of the reason WN was able grow into a great airline is they were one of the very few airlines in the world that would work with the unions. They are now into the us vs them management style.
enilria wrote:"This latest move by the new leaders of the Southwest Airlines Pilots’ Association is designed to pressure the company to meet its demands," the statement says. "Their maneuvering is not about our leaders. It’s not about 'IT infrastructure.' This is about the union’s approach to contract discussions and it’s attempt to gain leverage in negotiations."
enilria wrote:The company's response is sad because it shows denial about the IT problems that clearly exist and the decline in labor relations from both sides of the table.
barney captain wrote:"SWAPA leaders need to understand that we want to work with them, not against them, and as soon as they take a similar approach, we'll be closer to finalizing a contract for our pilots that rewards them for their service and professionalism," the statement says.
The VONC has nothing to do with contract talks.
But since he brought it up, what part of being in contract talks for four years without movement does RB see as "working with us"? That goes for the labor unions of the FA's and MX people as well - all well past four years of "talks". The VONC was also signed by the mechanics union - this isn't just the pilots.
Amiga500 wrote:Meh.
I wouldn't give much credence to a new york taxi driver saying the mayor should be replaced...
deltal1011man wrote:enilria wrote:The company's response is sad because it shows denial about the IT problems that clearly exist and the decline in labor relations from both sides of the table.
It was always going to end up in a pissing contest about the contract. It always does. Even legitimate issues get tossed out by the company or by the union when its contract time.
it all boils down to how the airline management and airline unions act. We are even starting to see the same s**t tossing at DL now between the company and the union. Best friends till that contract date comes up. Then its all about how worthless and evil this side is or that side is.
sad thing is it can become a safety issue.
exunited wrote:Investing in the business and people does not boost the stock price quickly like a dividend increase or buy back will.
enilria wrote:In the next downturn when the airlines are all filing Ch11 again they will wish they had used the money to pay down debt.
enilria wrote:exunited wrote:Investing in the business and people does not boost the stock price quickly like a dividend increase or buy back will.
In general I agree. In the next downturn when the airlines are all filing Ch11 again they will wish they had used the money to pay down debt.
Thenoflyzone wrote:Amiga500 wrote:Meh.
Forgetting the fact that your comment doesn't make sense.....what a stupid thing to say!
Amiga500 wrote:Meh.
MSPNWA wrote:You wouldn't see this if a contract dispute wasn't going on. Kinda sad, really. WN pilots have been arguably the most well-off rank-and-file employees in the industry. They don't have much to complain about.
winginit wrote:So they go after the CEO and the COO over a technical snafu but not the CTO?
smart.
INFINITI329 wrote:Thenoflyzone wrote:Amiga500 wrote:Meh.
You just dont understand the comment
The 4 unions representing 38K out of the 49K @SouthwestAir employees have joined in a vote of no confidence in the CEO and COO.
barney captain wrote:And you are well-off-the-mark.
Allegiant pilots now make more than SWA. Four years without a contract or pay increase is nothing to complain about?
winginit wrote:barney captain wrote:And you are well-off-the-mark.
It really isn't if, for years, you've been the highest paid 737 pilots in the industry no? Can they really not stand to ever not be the highest paid? I could see that if they were the most punctual airline, or the most profitable, or something like that - but they're none of those things.
commavia wrote:BestWestern wrote:Comparisons to DL / NW system merge aren't the same, as DL NW shared the same system architecture in their Joint Venture Worldspan, which resulted in an easier merging of data.
Okay, but there are other examples of merger-driven res migrations that were also pretty much flawless, though - the AA/TWA cutover in December 2001 and the AA/USAirways cutover last October, as examples.
