msycajun wrote:Nice add! Probably has to be a regional jet, though. I don't think 737s can even make it to Houston without severe restrictions.
TWA1985 wrote:msycajun wrote:Nice add! Probably has to be a regional jet, though. I don't think 737s can even make it to Houston without severe restrictions.
Forgive me for not having a lot of technical knowledge on the industry, but what restrictions are you referring to?
STT757 wrote:Looks like UA is going to launch EYW-EWR, ORD this Winter.
http://keysnews.com/node/76928
I'm guessing weekend 73G service.
a380787 wrote:maybe too many people complained about the S340B experience on Silver Airways =p
Polot wrote:DL use to fly the 73G to LGA from EYW (with baggage restrictions- one checked bag and that is all allowed, for all passengers). While I do not know how UA's are speced EWR may be doable for their 73Gs. Probably even ORD, which is ~50 mi further, albeit with more restrictions.
Josh32121 wrote:FWIW, all of DL's flights from EYW are restricted to one checked bag--not just the LGA flight.
redzeppelin wrote:What kind of range will the CS100 have from EYW?
toltommy wrote:Since it's a seasonal city for UA I wonder who will ground handle them? Can't see them opening a United Ground Express station just yet for one flight.
klwright69 wrote:Very cool. I wonder why no IAD service though.
yyztpa wrote:redzeppelin wrote:What kind of range will the CS100 have from EYW?
https://www.ainonline.com/aviation-news ... -or-moscow
"Bombardier has managed to squeeze another 140 nautical miles of range out of the C Series CS100 on flights to and from London City Airport (LCY), allowing the new narrowbody to fly 2,350 nautical miles with a full 108-seat passenger load."
LCY runway is listed as 4900'
EYW-ORD is 1087nm
asuflyer05 wrote:klwright69 wrote:Very cool. I wonder why no IAD service though.
If I had to guess AA's DCA-EYW flight probably takes care of all the demand from the DC area. UA has very little IAD-Florida presence.
TFlintoff24 wrote:United will offer daily, nonstop service between Key West and Newark, New Jersey Dec. 16 through May 4. Nonstop service between Key West and Chicago will occur Saturdays only Jan. 7 through April 29 to start. The flights will take place on 70-seat, E-170 regional jets.
GolfBravoRomeo wrote:E-170 Takeoff field length MTOW, ISA, SL is 4,865 ft.
From http://www.embraercommercialaviation.co ... rmance.pdf
OneSexyL1011 wrote:Just ran some numbers. These vary by +/- 500'ish lbs depending on which aircraft is used. (Older engines, empty weight differences...etc)
Zero wind
Bleeds (packs) OFF
Optimum flap setting
29c temperature
29.92 altimeter
737-700 (tried out 10 of our models)
Nets an average max take off weight of about 137,000. I was able to get it as high as 138,100 and as low as 136,500
Max structural take off on our 737-700's are 154,500. So we're looking at 16,500 restriction on the maximum take off weight.
Obviously these numbers would be better with wind credit and lower temperatures, but I wanted to use a constant standard line.
jetskipper wrote:What fuel quantity did you use? Max fuel in 46,000 pounds however a flight to Chicago would need no where near this. Even using 30,000 pounds of gas would give you approximately 5 hours of flight time for the burn, plus alternate, plus reserve.OneSexyL1011 wrote:Just ran some numbers. These vary by +/- 500'ish lbs depending on which aircraft is used. (Older engines, empty weight differences...etc)
Zero wind
Bleeds (packs) OFF
29c temperature
29.92 altimeter
SurfandSnow wrote:Wow, more Florida expansion for UA! Maybe after all these recent additions and resumptions UA won't be criticized on here all the time for giving up on Florida. Whereas moves like EWR-SRQ and SFO-TPA were to be expected, this is quite a pleasant surprise! I wonder if UA could be considering a resumption of EWR-DAB, EWR-MLB and/or some kind of nonstop service between EWR and the panhandle beaches (ECP/PNS/VPS). I have to think UA is looking into some sort of nonstop link between LAX and South Florida (most likely FLL) for the sake of important Angeleno FFers that have plenty of competitor alternatives to connecting through the likes of IAH or ORD...
ryan78 wrote:Tourism in the Keys has been been increasing over the last 5 years. I've been going down every year and each time is more noticeable then the last. Lots of new hotels popping up all over the islands. With that being said I'm surprised nobody has looked at starting flights to Marathon Intl Airport (MTH). It's smack in the middle of the Keys, 1H30 drive from Key West and Homestead and with a 5008ft RWY would give a little extra breathing room over EYW, not to mention an extra 1000ft of clearance on either end of the runway for added climb out performance. And if they really had too they could easily extend that runway almost another 1000ft comfortably while staying within the current airport boundaries. The facilities are all there too, a small terminal with a baggage carousel and three car rental companies on site, not to mention it recently became and International Airport with on-site customs. Would love to see commercial service return to this awesome little airport!
United787 wrote:piedmont762 wrote:STT757 wrote:Perhaps a stop in MCO.
I would bet they could demand a better fare than if they flew to MIA and compete directly with AA and indirectly with everyone at FLL. If I were travelling to Key West, I would pay a premium for a non-stop flight over connecting to another airline at MIA or renting a car and driving 3-4 hours. I would probably save some money in the long run also...
You are incorrect. MIA to EYW is not only a very scenic drive but only 2-2.5 hours at the most. Not 3-4 hours.
piedmont762 wrote:You are incorrect. MIA to EYW is not only a very scenic drive but only 2-2.5 hours at the most. Not 3-4 hours.
ryan78 wrote:Tourism in the Keys has been been increasing over the last 5 years. I've been going down every year and each time is more noticeable then the last. Lots of new hotels popping up all over the islands. With that being said I'm surprised nobody has looked at starting flights to Marathon Intl Airport (MTH). It's smack in the middle of the Keys, 1H30 drive from Key West.
toltommy wrote:piedmont762 wrote:You are incorrect. MIA to EYW is not only a very scenic drive but only 2-2.5 hours at the most. Not 3-4 hours.
You are the incorrect one. I've been driving into the keys since 1993. While it's only 150 miles or so, it is congested 2 lane road most of the way. The 18 mile stretch between Homestead and Key Largo was supposed to be rebuilt as a 4 lane, but the locals shot is down. Now its a congested stretch with a wall down the middle to prevent head-ons. The road is 4 lane from Key Largo to Tavernier, but volume and traffic lights make 45 a good speed. We plan on 4 hours from MIA to our place on Big Pine. The road is beautiful, yes. But it is also the ONLY road and traffic reflects it.
