Waterbomber wrote:The DC-10 tanker is pretty useless by itself on big fires like the ones raging in California now.
It's comparable to trying to extinguish or even control a fire engulfing the entire Empire State building using a single fire extinguisher.
The way they are doing it now, they might as well not do it at all.
In my opinion anything comparable or smaller than a CL415, including the C130MAFFS and the Bae Tankers, be it airplanes or helicopters, are by single units, useless on anything but a camp fire.
Single MI26's, the Martin Mars bombers, the 10 Tankers or the B742 Supertankers can be effective on small starting fires up to a couuple of acres.
On a big fire spanning over more than a couple of acres, you need to line up enough aircraft, such that by adding up the length of each aircarft's fuselage, you get the same distance as the front of the fire. So if your fire front is 1 kilometer long and it consists of dry material or combustible wood forests, you more or less need to fight the fire using at least 15 B747 Supertankers simultaneously. If the winds are strong, you need double that.
Any less than that and all you have is an expensive airshow that does nothing.
rcair1 wrote:Waterbomber wrote:The DC-10 tanker is pretty useless by itself on big fires like the ones raging in California now.
I'm afraid I must disagree with you on most of this - and BTW - this is my area... meaning my job is related to effectiveness, efficiency and sustainability of aerial firefighting technology.
Before I start in specifics, it is important to recognize that Aerial firefighting, be it fixed wing or rotary wing, is just one tool in the process of fighting a wildland fire.
The primary purpose of dropping retardant from a/c is to retard (slow) the advance of the fire to buy time. In some cases, if the fire is moving slowly, a retardant line will stop that advance, but in the conditions you are seeing in California, they are trying to slow it down and decrease the intensity to provide both time for other intervention and so that the fire front is less intense when it hits values (structures).
It is not intended to extinguish the fire - that is why it is called retardant and it is dropped ahead of the fire, not on it. (indirect attack).
If you were intending to extinguish the fire, you would use another product, a suppressant, perhaps a gel type product like FireIce. That is dropped on the fire directly (direct attack).
Use of this later type of agent is very new and not very common from a/c.
Water can be used both ways but is less effective as a retardant because it will likely evaporate before the fire hits it.
The VLAT (Very Large Air Tanker) - in this case the DC-10 (and no, there are no L-1011's doing this. There is a 747 in process for getting certified - see Global Supertanker))
There is certainly discussion (maybe controversy) in use of the VLAT in wildland fire fighting. A lot of this is driven by cost and focus - but mostly it is not based on actual effectiveness which is not, yet, well characterized.
Certainly a VLAT drop is very expensive. Maybe 50K per load. But it is also very large. A VLAT can put a long line down that would take many drops from smaller a/c. Depending on the circumstances, that may or may not be optimal.
In some cases, using the same $ to drop a number of SEAT (single engine air tanker) loads might be more effective on a given fire. The VLAT, for instance, cannot easily build line that has curves in it - whereas multiple SEAT's can.
Regarding this discussion about adding up the length of an aircraft fuselage to determine how many you need for a line. Pure fantasy. The length of a line dropped from any fixed wing aircraft is far more than one fuselage length - and it depends on what coverage level is being set.
Finally - helicopters are used in a different way than fixed wing. Typically helicopters will be dropping water (not retardant) on specific targets - maybe to help with putting out hot spots, maybe to help protect values. Sometimes helos will drop retardant, but usually they will be focused on rapid intervention on a point target using whatever water source they can get to quickly.
Most of what I'm seeing on Blue Cut right now are helo's. There are some SEATS. I don't see any medium, heavy or VLAT's in the air right now, but perhaps there is weather preventing it. I'm no where near it.
Waterbomber wrote:SEATS like the AT802 are useless.
Have you ever seen documented evidence of any SEAT extinguishing or containing any kind of wildfire? I haven't and would love to see some.
Waterbomber wrote:On some airshow in Italy, a bonfire was lit on a runway to showcase the Protezione Civile's CL415's capabilities. It turned out to be an embarrassment as the small fire couldn't be extinguished despite several drops on that fire.
Waterbomber wrote:The fuselage length is a measure of the carrying capacity of an aircraft. It's not about setting a precise standard but a reference point.
You can't set a standard because there are too many variables to account for, both on the fire and the aerial firefighting platform.
Waterbomber wrote:Blue Cut and all other preceding fires that got out of control highlights that current aerial firefighting methods are not effective at battling, nor containing large-sized wildfires.
Dropping fire retardant is a waste of money. A well-sprayed corridor can win you a few minutes and it can only be useful to give ground staff precious time to move out of a precarious spot. But other than that it's useless.
Waterbomber wrote:Watch how the Blue cut fire cut right throught the retardant over the course of an hour, to reach a resort in the valley:
https://www.youtube.com/watch?v=A-iVHn6d4mQ
https://www.youtube.com/watch?v=VdWUhreksJw#t=74.163438
https://www.youtube.com/watch?v=3MPxWtbLPO8
The reporter in the 3rd video from min 2:00 confirms that despite lines after lines of retardant, the fire just burns through it.
Very well documented proof that the scale of the aerial firefighting does not match up to the scale of the wildfire, which is why it expands in the first place.
In the end, the wind shift and the ground crews saved the day at Lytle Creek.
Waterbomber wrote:It's not about one guy or the other being right, it's about investing enough resources. Our governments can invest more, but they're not doing it.
The way they are doing it now, it's a waste of money. Big problems require big solutions. Yes, it's a big problem because of the big environmental impact of these mostly human-made fires.
The U.S. can afford a fleet of thousands of military aircraft, so I wonder why they can't afford a decent fleet of a couple hundred of large aerial tankers that could make a real difference.
Waterbomber wrote:RCair1, does it mean that you are happy that things continue the way they are?
