pvjin wrote:I'm not so sure whether the aircraft rotates before V1, but definitely before VR.
jetwet1 wrote:pvjin wrote:I'm not so sure whether the aircraft rotates before V1, but definitely before VR.
A question for the pilots on here.
ikolkyo wrote:I'd love to hear what was said in the cockpit.
BALandorLivery wrote:Clearly a grave mistake took place.
Whatever happened, be sure of this: the RECOVERY was first class airmanship.
Nose lowered
Speed allowed to increase
Tail not scraped
Aircraft airborne
TS-IOR wrote:According to RAM crew was cleared for take-off and been advised of possible wake turbulence from the heavy TK landing 07. Early rotation was to avoid the wake turbulence effect. I personally didn't believe a clue in that. Rotation point was well south of the 07 path and thus minor effect and if true pilots had only to wait for a minute or so and then depart.
PeterB wrote:1) Why didn't the pilot reject the take-off?
2) In the video, the flap configuration looks a bit flat for take-off. Am I right or do I see it wrong?
Aesma wrote:Does this technique of "rotating early to avoid wake turbulence" actually exist ? Do they mean making the take-off run shorter ? Which would imply full thrust instead of derated for example.
My instinct would tell me that if you're going to fly through turbulence you'd rather have extra speed than the opposite (not talking about cruise).
TWA772LR wrote:Perhaps it was a reduced thrust take off?
AR385 wrote:It seems very similar to this occurrence:
http://avherald.com/h?article=460db38a&opt=0
Although here the aircraft was a write-off.
StTim wrote:This was something I try and get kids today to do in my line of work - have an idea of the answer so that when the spreadsheet (or what ever) spits out an answer they have some immediate concept of whether it is correct or not. It is amazing how many just trust the answer as it has come out of a computer.
tb727 wrote:TWA772LR wrote:Perhaps it was a reduced thrust take off?
I've watched and listened close a few times now, I hear them push the thrust up to the initial stabilization setting(whatever that is for that 737) but I really can't tell if it's increased much more. Once they lowered the nose and figured it out and maybe set the proper thrust it seemed to fly heck of a lot better.
It seems like a strange thought but I guess I applaud them for continuing the takeoff instead of doing a high speed reject.
rcair1 wrote:
So - the wake turbulence of an aircraft ahead of you will be below it's flight path and will not start till THEY rotate.
That means that, if your aircraft has the performance to do so, you can plan your takeoff to lift off before their lift off point and stay above their climb path.
Incident: Royal Maroc B737 at Frankfurt on Jul 23rd 2016, three takeoffs for the price of one
Clipper101 wrote:Still I do not understand for such smaller aircraft departing behind heavier ones why higher flap settings are not selected for takeoff to guarantee earlier rotation velocities?!
What I feel is a very plausible explanation is that the vortices from the landing A330 off the right wing tip "chased" the RAM 737 during its takeoff roll and gave it a significant tailwind, rendering the pre selected V speeds (likely based on a headwind) totally insufficient. This skipped the crew until rotation, in which case they did an excellent job.
