BWIAirport
Winglets on new Alaska 737-900s
Wed Oct 19, 2016 2:10 am
As Alaska unveiled its latest 737-990/ER (N265AK) I couldn't help but notice it was equipped with standard scimitar winglets, while the vast majority of the 737NG fleet (aside from the oldest 739s) are equipped with the split scimitar winglet. The planes with standard winglets seem to only be on -900 and -900ERs, but some of those have split scimitars and there doesn't seem to be a pattern as to which planes get the split scimitars.
Why doesn't AS have split scimitars on all possible aircraft, especially new ones?
SWA, UAL, DAL, AWE, ASA, TRS, DLH, CLH, AFR, BAW, EIN, AAL | E190 DC94 CRJ2 B712 B733 B737 B738 B739 B744 B752 B753 B762 B77W A319 A320 A20N A321 A333 A343 A388 MD88
alasizon
Re: Winglets on new Alaska 737-900s
Wed Oct 19, 2016 2:16 am
My guess is that the split scimitars get added on a secondary check later on so they probably fly their first couple hundred hours without them.
For those that existed before the split scimitar was an option, they probably get added in C check or as part of a secondary mod (all depends on what the fleet utilization is)
Sancho99504
It has standard winglets from the manufacturer and will be retrofitted with the split scimitar winglets at a later date as those are essentially an aftermarket job.
kill 'em all and let God sort 'em out-USMC
bayareablue
Wed Oct 19, 2016 3:26 am
All new 900ER's from the factory come delivered with standard blended winglets typically matching the color of livery. Shortly after delivery and almost always before it makes it's first revenue flight it is modified where the blended winglets are removed and split scimitar winglets are installed; they match the livery when installed. Boeing does not offer the split scimitar as an option.
All of the 800's are modified with split scimitars.
9 of the 12 900's (delivered early 2000's) have winglets, most are blended with some being split scimitar but the remaining blended winglets are being replaced with splits. The first three 900's (N302AS, N303AS, and N305AS) do not have any winglets.
All 700's have blended winglets.
Blue
RWA380
Wed Oct 19, 2016 5:03 am
With regards to the AS fleet of 737-900ER's, how many are ETOPS vs how many are not? I see according to their webpage they currently have a fleet of 51 total 737-900ER's, ith that being 53 by years end.
I was pretty sure that when AS took delivery of their first 900's, that none of them were coming ETOPS & the 800 was going to be the ETOPS certified model.
Then AS started taking the 737-900ER which has the legs for Hawaii came on line it was still only the 800's flying to Hawaii. 900ER's have subbed before, Now when AS is taking delivery of each new 737-900ER, are they all coming ETOPS or is there a mixture of both certified & non-certified?
707 717 720 727-1/2 737-1/2/3/4/5/6/7/8/9 747-1/2/3/4 757-2/3 767-2/3/4 777-2/3 DC8 DC9 MD80/2/7/8 D10-1/3/4 M11 L10-1/2/5 A300/310/320
AA AC AQ AS BA BD BN CO CS DL EA EZ HA HG HP KL KN MP MW NK NW OZ PA PS QX RC RH RW SA TG TW UA US VS WA WC WN WP YS 8M
EA CO AS
Wed Oct 19, 2016 6:38 am
41
RWA380
Wed Oct 19, 2016 8:25 am
EA CO AS wrote:
41
Thanks for that information. For future 900ER deliveries will they all come ETOPS from now on?
I know the 900's are not ETOPS with their limited range.
I'd also be curious if AS is taking on more 900 / 900ER / 800 aircraft with their upcoming deliveries from Boeing? I see more flights being operated by 900s & 900ER's.
yyz717
Wed Oct 19, 2016 4:01 pm
>> Is there a reason these 3 aircraft were not fitted with winglets? Regards
I dumped at the gybe mark in strong winds when I looked up at a Porter Q400 on finals. Can't stop spotting.
yeelep
Wed Oct 19, 2016 5:48 pm
All the N2xxAK registered planes that began with the first delivery in April of this year are non-ETOPS.
DocLightning
Wed Oct 19, 2016 8:07 pm
Is the winglet a standard 73G fitting now? Wouldn't it make more sense to order them without winglets and then add the scimitars after delivery rather than have the winglets only to remove them and re-fit split scimitars?
Or is AS going for the winglet mod in which the top of the winglet is replaced with the scimitar tip and the additional lower wing-like element is added?
-Doc Lightning-
-Carl Sagan
Polot
Wed Oct 19, 2016 8:14 pm
The winglet is standard on the -900ER.
Varsity1
Wed Oct 19, 2016 8:15 pm
They come with the standard winglets and are replaced by aviation partners with the ss via STC.
I don't think boeing sells 737's without winglets anymore but could be wrong.
"PPRuNe will no longer allow discussions regarding Etihad Airlines, its employees, executives, agents, or other representatives. Such threads will be deleted." - ME3 thug airlines suing anyone who brings negative information public..
bayareablue
Wed Oct 19, 2016 9:22 pm
Structure at the wingtips.
Passedv1
Thu Oct 20, 2016 12:53 am
Correct. All deliveries between now and when the Max arrives will be non-ETOPS.
