litz wrote:Re: GE failures .... the 777 failures aren't a CF6 engine ... that's a GE90.
There seem to have been four major uncontained disc failures on the CF6 (of various variants) ... UA232, the engine test/run-up on the AA 767 at LAX, the engine test/run-up on the USAir 767 in PHL, and now this one ...
Unless, I'm mistaken, all of these were in the HPT section, right?
Now think about the sheer number of CF6 engines that have been, or are still, in service world wide, and the number of flights those have taken throughout history. That's a failure percentage down near statistical zero.
Not quite. In addition to the four events you mention, here are a few more uncontained failures involving the CF6 which I was able to find at
https://aviation-safety.net/database/ev ... Event=ACEU as well as other sources:
An Air Florida DC-10-30 N101TV had an uncontained engine failure after the stage 3 low pressure turbine disc fractured during the take off run at Miami, USA on22 September 1981 -
https://aviation-safety.net/database/re ... 19810922-2An Air France A300B4 F-BVGK had an uncontained engine failure after the stage 1 high pressure turbine disc fractured during the take off run at San'a, Yemen on 18 March 1982 -
https://aviation-safety.net/database/re ... 19820317-0A Garuda Indonesia DC-10-30 PK-GIE had an uncontained engine failure after a blade (which had exceeded the recommended number of cycles) in the 1st stage high pressure turbine separated during the take off run at Fukuoka, Japan on 13 June 1996 -
https://aviation-safety.net/database/re ... 19960613-0A Canadian Airlines 767-300 C-FCTA had an uncontained engine failure after the stage 3-9 high pressure compressor spool fractured during the take off run at Beijing, China on 6 September 1997 -
https://aviation-safety.net/database/re ... 19970906-1An Atlas Air 747-200 N534MC had an uncontained engine failure after interference from a failed part led to the fan shaft breaking on climb out from Guyaquil, Ecuador on 2 April 2000 (ok, this is not really a direct failure of the high kinetic energy equipment like what we're discussing) -
https://aviation-safety.net/database/re ... 20000402-0A Continental Airlines DC-10-30 N39081 had an uncontained engine failure after a stress rupture of the 2nd-stage low pressure turbine anti-rotation nozzle locks during the take off run at Newark, USA on 25 April 2000 -
https://aviation-safety.net/database/re ... 20000425-2A Varig 767-200 PP-VNN had an uncontained engine failure after the stage 3-9 high pressure compressor spool fractured during the take off run at São Paulo, Brazil on 7 June 2000 -
https://aviation-safety.net/database/re ... 20000607-1An Air New Zealand 767-200 ZK-NBC had an uncontained engine failure after the stage 1 HPT disc fractured on climb out from Brisbane, Australia on 8 December 2002 -
https://aviation-safety.net/database/re ... 20021208-1A Phuket Airlines 747-300 HS-VAC had an uncontained engine failure after the stage 3 LPT disc fractured on climb out from Jeddah, Saudi Arabia on 4 July 2008 -
https://aviation-safety.net/wikibase/wiki.php?id=74533An Arrow Air DC-10-30 N526MD had an uncontained engine failure after the stage 3 LPT disc fractured on climb out from Manaus, Brazil on 26 March 2009 -
https://aviation-safety.net/wikibase/wiki.php?id=59031A Jett8 Cargo 747-200F 9V-JEB had an uncontained engine failure after the stage 3 LPT disc fractured on climb out from Singapore on 17 December 2009 -
https://aviation-safety.net/wikibase/wiki.php?id=74534An ACT Airlines A300B4 TC-ACE had an uncontained engine failure after the stage 3 LPT disc fractured during the take off run in Bahrain on 10 April 2010
These four incidents above led to urgent safety recommendations from the NTSB:
http://avherald.com/h?article=42c44df6A Phuket Airlines 747-300 HS-VAC (yes, the same one as above!) had an uncontained engine failure (no further details of the origin sorry) on climb out from Cairo, Egypt, on 17 July 2010 -
https://aviation-safety.net/database/re ... 20100717-0So all up that's another 13 uncontained failures, 10 of which involved the failure of discs or shafts.
V/F
