mikegigs wrote:Is it just me, or does it seem like an overall net loss of gates? Certainly seems like a net loss of terminals (6 to 4).
danj555 wrote:does anyone find the taxiways around the gates a bit narrow? Or is that just the angle?
rebr wrote:Including a picture of airbus' upcoming A747-900 in Delta livery
The Governor also announced today plans to move forward to develop a full master plan for future development at JFK airport. The Governor has directed the Advisory Panel to report back in the next twelve months with its recommendations for an implementable master plan for the development of a 21st century JKF International Airport. Within the next 60 days, the Panel will work with the Port Authority to issue an RFP to retain a master planning firm to advise the Governor, the Panel, and the Port Authority on the future development of the airport.
VirginFlyer wrote:mikegigs wrote:Is it just me, or does it seem like an overall net loss of gates? Certainly seems like a net loss of terminals (6 to 4).
jfkflyer wrote:VirginFlyer wrote:mikegigs wrote:Is it just me, or does it seem like an overall net loss of gates? Certainly seems like a net loss of terminals (6 to 4).
At the moment there are:
Terminal 1 - 11 gates
Terminal 2 - 11 gates (3 of which appear to be connected to a structure to accept, by my count, 14 regional jets)
Terminal 4 - 38 gates
Terminal 5 - 29 gates
Terminal 7 - 12 gates
Terminal 8 - 29 gates
Total - 130 gates
Wrong, Wrong. More Wrong. Terminal 2 has 11 standard 757-capable gates, and the RJ spider web was removed long ago. Terminal 4 has 42 gates. What we need is to EXTEND THE A PIER OF T4, like the B concourse was. Terminal 2/space of 3 should be replaced by t1 extension
Terminal 4 has 38 gates in two concourses: A2–A7, B18, B22–B55 with the exclusion of B40, B50 and B52.
Dutchy wrote:Looks certainly nice. What I am missing is how to get there by land
Varsity1 wrote:Looks nice, but also like a huge waste of space. A modern version of ATL would be appropriate.
Thanks, Thanks. More Thanks. I should have said where I sourced those numbers from. I was going by Wikipedia for the numbers of gates (yes I know the pro visos around Wikipedia), which said:Terminal 4 has 38 gates in two concourses: A2–A7, B18, B22–B55 with the exclusion of B40, B50 and B52.
Perhaps for completeness' sake you could point out which are the extra 4 gates missed out here?
For T2, I was going by images on both Google and Apple Maps which showed the "spider web". I just looked on my desktop and saw the Google Maps image is from 2 years ago. It looked like the T4 extension was already complete so I thought maybe they had kept the "spider web", but zooming in I see it is still a work site in the image. I assume the "spider web" disappeared once the T4 extension opened?
V/F
jfkflyer wrote:Actually your google earth is outdated. it(Spider web) was removed in 2013.
blacksoviet wrote:Why did they remove Terminal 1 from the plan?
FSDan wrote:rebr wrote:Including a picture of airbus' upcoming A747-900 in Delta livery
If you look closely at some of the interior mockups, you can see a DL aircraft departing in the "Wavy Gravy" livery, and even one taxiing in the Widget! They are predicting some retro liveries for DL...
blacksoviet wrote:Is the Ron Allen livery older than Wavy Gravy?
kaitak744 wrote:I am sorry, but this makes no sense. Demolishing a lot of modern facilities in order to gain what? The only JFK terminal that needs rebuilding is T2. Nothing really can be gained from reconfiguring the other terminals.
If you could start from a clean sheet, sure you would configure everything differently. But at this point, the cost of rebuilding would outweigh the benefits.
What JFK needs is more runways.
