KarelXWB
First Boeing 787-10 enters final assembly
Wed Nov 30, 2016 9:49 pm
Stitch
Re: First Boeing 787-10 enters final assembly
Wed Nov 30, 2016 10:24 pm
Well now it is clear why the extended (center) Section 44+46 cannot fit in a Dreamlifter.
LAX772LR
Wed Nov 30, 2016 10:27 pm
78Xs will be made solely in CHS, correct?
Stitch
Wed Nov 30, 2016 10:31 pm
Yes, as the center section cannot be transported to PAE.
LAX772LR
Wed Nov 30, 2016 10:35 pm
Considering all of the tracks.... I wonder if they ruled out rail due to cost, or was size preventative there too.
Then again, could be both, I guess.
Sooner787
Wed Nov 30, 2016 10:36 pm
I assume after the B7810's first flight, it will be flown to Boeing Field for flight tests?
tortugamon
Wed Nov 30, 2016 10:47 pm
That is going to be a long bird.
Another picture:
https://twitter.com/Reeega_/status/804050553336725504
tortugamon
MrHMSH
Wed Nov 30, 2016 10:48 pm
I'm looking forward to it, I think it will merely be the 2nd best out of 3 pretty sisters, but 787s always look good. I think the 789 will be much more balanced and proportional.
817Dreamliiner
I've always wondered why they extended the mid body section and not the forward section (section 41).(they extended the aft section as well)
Maybe they should convert some of the unwanted 747-8s to LCFs to replace the current ones in the future.
Yes, but I wouldn't expect it to go straight there on its second flight.
Life is encrypted, you are modified, Like a virus in a lullaby, Artificial till the day you die, silly programme, You're corrupted
PlanesNTrains
Wed Nov 30, 2016 11:21 pm
At a minimum, I'd think the width would kill any chance of moving by rail.
-Dave
MAX’d out on MAX threads. If you are starting a thread, and it’s about the MAX - stop. There’s already a thread that covers it.
kanban
Thu Dec 01, 2016 12:00 am
I think the combination of width, height and length would have been a railway routing nightmare.. possibly doubling the distance
PlanesNTrains
Thu Dec 01, 2016 12:21 am
I agree, but I don't think it would even be commercially viable at that point. The railroads are so busy here in the northwest - almost a parking lot at times - that virtually shutting lines down while a very wide load passes through would seem to be a non-starter. Not that I wouldn't have minded seeing it. :-)
-Dave
iahcsr
Thu Dec 01, 2016 1:06 am
Might fit in the AN225, but likely not.
SCAT15F
Thu Dec 01, 2016 1:36 am
Yeah. The cargo hold on the 225 is wide enough and long enough but not tall enough...
CHI87LG
Thu Dec 01, 2016 1:59 am
In some weird way, this is just the new 767-400ER isn't it?
It's eerie when I compare them in terms of specs. I am probably reading into things, but the 787-10 also seems like a bit of a stretch to try to improve the sales of the airplane (after all, longer is better).
The 787-10 is:
+23 feet longer than the 767-400ER
+805 nautical miles further range than the 767-400ER
+40 passengers (roughly) depending on configuration than the 767-400ER
+17 years younger than the 767-400ER
Now, before you find that discouraging - consider that the 767-400ERs are still flying. Last winter I regularly saw the Honolulu to Newark United 767-400ER flying directly over Chicago. It's both a beautiful and reliable plane that showed Boeing honing in on its longer range twin-engine craft and refining how those airplanes were implemented. However, let's not try to polish the fact that only 37 767-300ERs were built.
Boeing has 154 787-10 orders on the books today. That seems like a decent expansion of the market for this type of twin-engine airplane. It's just stunning that it took so much to get there. It's also stunning that the amount of comfort and fuel economy gains have been made - things which I haven't even attempted to quantify for this discussion. It seems like this plane could well hold its own alongside Airbus' stunning A350 as the living future of long-haul airplanes (and I say that while realizing that the 787 vs. 350 discussion is a bit pointless given the craft are so dramatically differently purposed).
I just hope that world events don't spoil the party ;)
Sooner787
Thu Dec 01, 2016 2:13 am
That long jet will look awesome in SQ colors :)
Revelation
Thu Dec 01, 2016 3:02 am
Or perhaps on top (with suitable fairings) like Buran? :scratchchin:
DfwRevolution
Thu Dec 01, 2016 3:31 am
I can confirm that. When planning cross-country transport for machinery packages, we try very hard to stay within a 17.5 x 4 x 4 meter box (LxWxH) for rail shipment. The 787 fuselage at 5.77 x 5.94 meters (WxH) is way beyond those limitations.
jagraham
Thu Dec 01, 2016 8:11 am
They can barely move 739s from Wichita to Renton
StTim
Thu Dec 01, 2016 8:34 am
Sorry but may need a new thread as it is off topic...
If it is a struggle to move 739's now - what would the plan be for a -10? A body join in Renton?
WIederling
Thu Dec 01, 2016 10:05 am
The new Beluga XL could be a fit? :-)
( my gues Section 44+46 :: 113ft/ 34m, Beluga Classic 38m but the rear tapers.
The XL is a bit longer and wider moving the taper restriction further aft.)
The LCF is so much bigger but apparently this did not rub off on capabilities.
Murphy is an optimist
WIederling
Thu Dec 01, 2016 10:10 am
The required railway loading gauge does not change with a longer fuselage.
Only more length for rednecks to shoot holes into.:-)
WIederling
Thu Dec 01, 2016 10:59 am
You have to adapt those sections anyway for the longer moment arm of front and rear fuselage ( 3 + 3 m longer).
The load case does not change for the tail and cockpit section ( as much ).
Nonetheless I am surprised that the LCF is too short ( 33m isn't really long for a 747, right)
OA940
Thu Dec 01, 2016 11:54 am
Congrats to Boeing!!
A350/CSeries = bae
PW100
Thu Dec 01, 2016 5:41 pm
I like that split banner. Nice touch!
Sooner787
Thu Dec 01, 2016 5:49 pm
Have they completed construction of the paint hangar at CHS yet?
Dutchy
Thu Dec 01, 2016 5:53 pm
when is the fist flight planned? Q1 '17?
nimool
Thu Dec 01, 2016 7:32 pm
Who is the Launch customer? :o
Iran Air, we take you there, we take you back!
Polot
Thu Dec 01, 2016 7:40 pm
SQ will be the first operator.
gatechae
Thu Dec 01, 2016 7:59 pm
I've always been told (as a Spirit Employee) that its the width of the rail tunnels in the mountains that prevent the rail shipments of the 787.
The 777, 767, and 747 Section 41's are shipped in pieces so they can be rail shipped, the 787 section 41 is a single piece barrel so it has to be put on the dreamlifter.
RL777
Thu Dec 01, 2016 8:07 pm
The 787-10 is:
The 767-400ER sold poorly due to its inability to carry LD3 containers side by side. It rendered the cargo carrying abilities inefficient and difficult for airlines to incorporate into their fleets.
Polot
Thu Dec 01, 2016 8:15 pm
It was also, and probably more importantly considering that cargo disadvantage is shared with all 767s, introduced far too late into the 767's lifecycle. If it was released ~10 years earlier we would likely have seen a lot more of them (probably at the expense of 763 sales however).
Same story with the 753 while we are at it.
coolian2
Well we might finally get a 787 that looks as good as any A350. Fingers crossed!
Q300/ATR72-600/737-200/-300/-400/-700/-800/A320/767-200/-300/757-200/777-300ER/
747-200/-300/-400/ER/A340-300/A380-800/MD-83/-88/CRJ-700/-900
itisi
Thu Dec 01, 2016 10:42 pm
are you allowed to say that here :wideeyed:
737-300/400/500 ... are NOT classics :)
william
Thu Dec 01, 2016 10:51 pm
So the 777-300 replacement is finally here. Considering how many 777s need replacing, even split with the A350,I expect many, many more -10 orders.
coolian2
Thu Dec 01, 2016 11:30 pm
Yeah amazingly
32andBelow
Thu Dec 01, 2016 11:48 pm
Just ship it on a ship
PlanesNTrains
Fri Dec 02, 2016 2:04 am
In the case of the 767, at least, I believe the sections come by ship to Everett where they are transloaded to a barge and sent south a short distance to Mukilteo. There, the oversized containers are transloaded to a railcar and sent uphill the short distance to the Boeing facility. They only briefly encounter the BNSF mainline right at Mukilteo, and there is enough space between the mainline and the siding to accommodate the clearly-oversized containers.
If anyone has additional or otherwise better information, please share. I don't want to misrepresent the truth but I don't believe fuselage sections - in the manner implied in this thread - are being transported cross country by rail.
-Dave
PlanesNTrains
Fri Dec 02, 2016 2:07 am
Well, when the 737-900 was introduced, the railroad loading gauge was indeed not wide enough. In Renton, a bridge had to be replaced because of a lack of clearance as the fuselage swung around a curve over a river. I'm sure the charts showed it being passable - and it was at a walking pace - but ultimately it was too tight. It just might be that there will be a bottleneck somewhere else for a lengthened -10.
-Dave
RL777
Fri Dec 02, 2016 2:13 am
Yep, I have a feeling that the 787-10 will become quite popular in Asia at some point however with low fuel prices at the moment, airlines might tend to hold onto those 330s a bit longer.
Erebus
Fri Dec 02, 2016 2:32 am
Something that long resting on the tiny feet (MLGs) shared with its siblings, it will look odd while on the ground IMO. The 787-9 is the best proportioned in the family.
VC10er
Fri Dec 02, 2016 3:06 am
Amazing, it's like the worlds longest canoli! Just need a few hundred thousand tons of custard!
Bravo Boeing for figuring out how to make that fuselage, and for those giant windows!
To Most the Sky is The Limit, For me, the Sky is Home.
rufusmi
Fri Dec 02, 2016 3:28 am
I don't really view the -10 as a 77W replacement. It's shorter, narrower, and less capable. Maybe a 772 replacement, with a little capacity increase? Which might just explain why UA ordered so many, considering they have the largest 772 fleet in the world?
CHI87LG
Fri Dec 02, 2016 4:04 am
the 777W replacement is the 777-9. the 787 is a different class of airplane.
CXB77L
Fri Dec 02, 2016 4:37 am
He said 773 replacement, not a 77W replacement. I agree it would do well as a 773 replacement, although it isn't quite as big as a 773, and because there are only 8 exits, it's limited to 440 seats anyway, whereas the 773 can theoretically hold up to 550.
Boeing 777 fanboy
LAX772LR
Fri Dec 02, 2016 6:09 am
Agreed. And I'd say the latter is a blessing, not a hindrance.
Allows them to keep similar premium layout, decent cargo capacity (doubt you're going to max out on volume or weight, during medium-haul), while shorting the Y and thus increasing yield in that cabin.
Seems like a win to me.
keesje
Fri Dec 02, 2016 8:30 am
Great to see some hardware finally, more then 10 years after Emirates started pushing for it.
What will be the 787-10's OEW?
KarelXWB
Fri Dec 02, 2016 10:28 am
It is believed to be in the 135-138t ballpark.
ojjunior
Fri Dec 02, 2016 10:33 am
So, we're about to see Boeing dumping themselves with a 787 almost the same as the 777...
Despite the tech differences, don't know how far this is a good move...
ehaase
Fri Dec 02, 2016 12:17 pm
I believe one of Delta's executives spoke favorably of the 787-10 earlier this year, although I don't know what kind of route Delta would use it on.
