Probably one of these ones I would imagine. Quite impressive indeed! - https://www.google.com/maps/place/Heathrow+Airport+(LHR)/@51.4731581,-0.4780372,398m/data=!3m1!1e3!4m5!3m4!1s0x48767234cdc56de9:0x8fe7535543f64167!8m2!3d51.4700223!4d-0.4542955
southsidesilver wrote:I took the British airways flights from Austin to London last month and walked down probably the longest Jetbridge I have ever encountered around the world, this thing was insane, has anyone else walked it.
southsidesilver wrote:Probably one of these ones I would imagine. Quite impressive indeed! - https://www.google.com/maps/place/Heathrow+Airport+(LHR)/@51.4731581,-0.4780372,398m/data=!3m1!1e3!4m5!3m4!1s0x48767234cdc56de9:0x8fe7535543f64167!8m2!3d51.4700223!4d-0.4542955
I have walked those before, and this was almost double the length of those.
In case you wanted to see the length, i did capture it in my trip report, its at 2.05 in the video
https://youtu.be/TB1sS2H8KYM
ACCS300 wrote:Does anyone know why T5-C was built like that from the start?
What concourse & gate was it? Because your video looks like the one in the link based on number of bends in in.
reltney wrote:Gate 13 in the Delta terminal BOS.. 2min 12 seconds.....
tonystan wrote:Technically it's not a jetway. The jetway is just the articulated bit from the "Node" to the aircraft door. The rest is just a stationary walkway, in fact much of it is actually on top of an existing structure.
Not a fun gate to be at if you're running for a tight connection! Lol
ScottB wrote:It's just a temporary structure in place so that the terminal concourse can be extended without taking several gates out of service.
keitherson wrote:It's not about how long it is but how well you use it.
KTPAFlyer wrote:When is AUS scheduled to finish and remove the temporary gate extensions?
Jshank83 wrote:It is crazy how long the ones at AUS are in the image. I thought you were just exaggerating saying 600 ft but you might be right.
ikolkyo wrote:Maybe I'm blind but I'm not seeing these freakishly long jetbridges.
