BWIAirport
UA 2 scheduled stops in HNL
Thu Dec 22, 2016 7:19 pm
http://flightaware.com/live/flight/UAL2 ... /WSSS/PHNL
Apparently the past couple days United Airlines flight 2 has been stopping in Honolulu, presumably for refueling, on its trip from SIN to SFO. Interestingly, about an hour before the flight FlightAware has the route filed as SIN-HNL rather than SIN-SFO, with another leg filed separately for HNL-SFO.
For what it's worth, SQ32 (an Airbus A359) does not make that stop. I think I saw on a previous thread that UA's 789 was ideal for this route over the A359 because of less drag on the airframe, which makes this even more perplexing.
Why is UA scheduling fuel stops for this route on some days while SQ is not? The winds aloft data on SkyVector does not seem to indicate winds are a huge issue.
Next flight: October 17 DL2641 BWI-ATL B739
October 17 DL2607 ATL-TPA B752
SWA, UAL, DAL, AWE, ASA, TRS, DLH, CLH, AFR, BAW, EIN, AAL | E190 DC94 CRJ2 B712 B733 B737 B738 B739 B744 B752 B753 B762 B77W A319 A320 A321 A333 A343 A388 MD88
codc10
Re: UA 2 scheduled stops in HNL
Thu Dec 22, 2016 7:24 pm
The flight is initially filed SIN-HNL, then refiled all the way to SFO if at the 'recheck' point, the flight crew determines there is sufficient fuel to make it to SFO within all safety margins.
A fuel stop is definitely suboptimal with competition from SQ now. UAL will likely be weight restricting the flight more heavily than forecast.
flyguy84
Thu Dec 22, 2016 7:30 pm
UA2 only stopped in HNL once, and that was the flight originating on the 22nd from SIN. This was also not a fuel stop, it was related to crew duty issues.
Edit: The same goes for 12/10.
SFO
BWIAirport
Thu Dec 22, 2016 7:32 pm
FlightAware also has the December 10 flight as SIN-HNL-SFO.
SonomaFlyer
Thu Dec 22, 2016 7:33 pm
I would think it more likely that weight restrictions or fuel stops would be more likely west bound than east. Jet streams travel west to east so should (even south of the equator) be a benefit for UA 2 on the SIN-SFO flight.
We will likely not get the full scoop but I don't see how even fully loaded why they can't make this flight non-stop east bound.
flyguy84
Thu Dec 22, 2016 7:34 pm
Also related due to crew duty issues... these are not fuel stops. If one of the crew of four is ill or can't complete journey, the flight time is too long for a three man crew to complete. Thus, they stop in HNL for a planned re-crew.
SFO
Newbiepilot
Thu Dec 22, 2016 7:42 pm
I think the sick pilot explanation is more logical. There would not be an eastbound fuel stop unless there is a problem with the plane. Eastbound the flight is about 14 hours. It is closer to 17 hours westbound and that is where they run into weight restrictions.
BravoOne
Thu Dec 22, 2016 7:50 pm
Kind of hard to believe that UAL has a crew standing by in HNL just in case they need to make a technical stop. i call the BS flag on that scenario,
SQ22
Thu Dec 22, 2016 7:55 pm
BWIAirport wrote:
http://flightaware.com/live/flight/UAL2/history/20161222/0145Z/WSSS/PHNL
In general you can expect the A359 to have longer legs, but it can be weight restricted as well in the current version operated by SQ.
BostonBeau
Thu Dec 22, 2016 8:04 pm
Not sure why they are going to HNL for fuel. SIN-ANC-SFO is about 500 miles shorter than SIN-HNL-SFO.
codc10
There are no crews standing by in HNL, but pilots can be deadheaded in on scheduled flights with adequate notice, which is certainly within the realm of possibility.
DaufuskieGuy
Thu Dec 22, 2016 8:06 pm
they certainly have pilots in HNL given all their flights to it - not that they are standing by, just available if necessary (with some shuffling to get other flights covered). I am surprised these pilots would be 787 certified though since HNL doesn't see any of those on a scheduled basis.
ikolkyo
Thu Dec 22, 2016 8:11 pm
Doesn't make sense to me, I'd expect this to happen going from SFO-SIN not SIN-SFO.
LAXintl
Thu Dec 22, 2016 8:14 pm
There is the little detail of jetstreams. Nautical air miles matter more when flight planning that any ground mile calculation.
Many of these traverse the Central Pacific versus North Pacific.
Newbiepilot
Thu Dec 22, 2016 8:19 pm
I think a crew can dead head to HNL and have enough time to operate the plane to SFO. They have enough notice to get a crew to HNL. The challenge is resting them in HNL.
barney captain
Thu Dec 22, 2016 8:32 pm
I've never heard of a flight landing mid-way to it's destination to accommodate a crew duty issue. AFAIK, the legality of those crews has to be verified before the aircraft departs.
Maybe the ULH sectors have additional restrictions.
Southeast Of Disorder
codc10
Thu Dec 22, 2016 8:37 pm
HNL is not a pilot domicile for United. Mainland pilots would comprise any 787 relief crew positioned in HNL to meet UA2 stopping for duty time reasons.
FRMS ("Fatigue Risk Management System") gives United some additional flexibility (but not much) on crew duty limitations for ULH sectors than what would be provided by FAR 117 as enacted.
flyingadam89
Thu Dec 22, 2016 8:43 pm
This was in fact due to a sick crew member. FAR 117 duty limitations required a crew stop in HNL and a new crew got placed in HNL to bring the flight back to SFO.
LAXintl
Thu Dec 22, 2016 8:46 pm
It happens. For example some Europe-US flights running late land short in places like BOS for crew change.
For UA specifically recently a couple PVG-ORD flights land short in SFO for recrewing. Similarly, a couple FRA-SFO flights landed in ORD for crew change.
Few years ago I flew to HKG, and we landed short in Japan to be recrewed.
Ultimately its a smart way to avoid cancelling a flight entirely and stranding the passengers.
DaufuskieGuy
Thu Dec 22, 2016 9:01 pm
I assume these instances are mainly crew timing out and more rarely illness?
badgervor
Thu Dec 22, 2016 9:02 pm
DaufuskieGuy wrote:
BravoOne wrote:
I thought the 787 and 777 are considered a common type rating? At least I swore I read that somewhere
DaufuskieGuy
Thu Dec 22, 2016 9:31 pm
badgervor wrote:
DaufuskieGuy wrote:
regardless they apparently flew the new crew in from SFO.
Newbiepilot
Thu Dec 22, 2016 9:32 pm
Essentially we are talking about the same thing. Two crew can fly 8 hours, three can fly 12 and four can fly 16 (plus two to four hours depending on circumstances). If they are scheduled for a crew of four and one gets sick then duty time shrinks from 16 to 12 hours. Since the flight is blocked at 14 hours 40 minutes, they won't make it all the way to SFO.
In the other examples weather or maintenance delays used up some of the duty time before takeoff so that there was not enough remaining time. Either way you have a crew with not enough duty time to complete the flight so you stop short. Occasionally this happens and UA is not putting an extra pilot on board for contingencies. I think it is extremely rare. Also if this happened twice in a 10 day period, it could be the same person (how about that for a conspiracy theory?)
usflyguy
Thu Dec 22, 2016 9:35 pm
SFO-HNL-SFO is short enough that a crew can be deadheaded to HNL to then work the leg back to SFO without an overnight.
My post is my ideas and my opinions only, I do not represent the ideas or opinions of anyone else or company.
Newbiepilot
Thu Dec 22, 2016 9:36 pm
badgervor wrote:
DaufuskieGuy wrote:
That was a goal early on in the development, but I think there is a 4-5 day differences course require and separate ratings.
Utah744
Thu Dec 22, 2016 9:49 pm
codc10's reply#2 was right on.
Commercial Flights
Per ICAO Annex 6, Part I, section 4.3.6 "Fuel Requirements," airplanes should calculate their required fuel quantity as follows (summary; see below for actual ICAO text):
•Taxi fuel
•Trip fuel (to reach intended destination)
•Contingency fuel (higher of 5% of "trip fuel" or 5 minutes of holding flight)
•Destination alternate fuel (to fly a missed and reach an alternate)
•Final reserve fuel (45 minutes of holding flight for reciprocating engines, 30 minutes for jets)
•Additional fuel (if needed to guarantee ability to reach an alternate with an engine failure or at lower altitude due to a pressurization loss)
•Discretionary fuel (if the pilot in command wants it)
For example if the flight was scheduled to burn 200,000# (I have no A359 experience) you'd be required to have 5% or10,000# of contingency fuel, BUT if you are only released to some mid point you'd need a lot less contingency. So the Captains and dispatcher plan the flight NS but load contingency fuel only for the mid point and then the flight is re-released to the destination now requiring much less contingency fuel. Now actual stops in HNL must be for other reason listed above. NWA used this technique on almost all long flights.
You are never too old to learn something stupid
Newbiepilot
Thu Dec 22, 2016 10:15 pm
Commercial Flights
•Taxi fuel
While the concept you discuss is correct, it does not make sense in this case. UA made stops eastbound, not westbound. Westbound is where there are headwinds and the flight time is two hours longer. UA has not made westbound stops.
BobbyPSP
Thu Dec 22, 2016 10:22 pm
Quick question re: deadheading flight crew HNL.
This might be a contract issue so i'm asking: I know DH is usually considered "on duty", however if in an F seat, is the flight to HNL also considered part of the rest period for a pilot having maybe a 12 hr total day?
BravoOne
Thu Dec 22, 2016 10:32 pm
DaufuskieGuy wrote:
Not a common "FAA type rating". Some countries yes, but not here in the US.
Okie
Thu Dec 22, 2016 10:36 pm
I am thinking more along the lines since we are in December that there is crewing issues, not sickness, with pilots running out of hours for the year.
Just having crew members with hours left in the wrong position.
Okie
BravoOne
Thu Dec 22, 2016 10:38 pm
Commercial Flights
•Taxi fuel
Close but quite. FAA mandates 10% "Flag Fuel under 121.625 (?)" That's 10% of the flight time so a 10 hour flight would 60 minutes of international reserve fuel + 30 minutes holding fuel. EASA and ICAO are similar but as rigid as FAA rules. Also does not include any additional ETOPS fuels which the 787 is susceptible to.
BravoOne
Thu Dec 22, 2016 10:39 pm
Okie
Love to meet that UAL pilots that fly's 1000 per year. Just say'n:)
xjet
Thu Dec 22, 2016 10:47 pm
If deadheading into an operating flight, the FAA requires that the entire deadhead count as a duty period. If you are operating and then deadheading, the FAA could care less. You aren't in "rest" on a backend deadhead, but neither does it count towards the maximum daily duty limit.
Okie
Thu Dec 22, 2016 10:51 pm
Just a thought.
Yes, I may have to wash my mouth out with soap.
Okie
LAXintl
Thu Dec 22, 2016 10:54 pm
United and the other majors have long held FAA approved Ops Spec deviations to reduce prescribed regulatory contingency figures. (B044, B343, B043, B343+B043, A012, etc)
Matter of fact, in last few years FAA has allowed airlines like UA to entirely move away from fixed regulatory fuel figures to data-driven performance-based planning numbers.
Actual fuel reserves on these United ULH flights are a fraction of the archaic 10% flag rules, and brings the US closer to what airlines in regions such as Europe have long utilized for planning.
BobbyPSP
Thu Dec 22, 2016 11:11 pm
Thank you! Much appreciated
BravoOne
Fri Dec 23, 2016 12:05 am
LAX intl I believe your are speaking to the exception allow for less than 10% time for flight that are not operating in Class ll airspace, i.e, EDDF to KLAX. Much of that fling does not occur in Class ll airspace and thus is not used to calculate the 10% number. Depending on how a Singapore to SFO flight is planned you may be able to recapture some of the time, BUT, a flight the goes close to HNL is not one of them.
blacksoviet
Fri Dec 23, 2016 12:24 am
Was HNL-SFO ever flown with the DC-7?
BravoOne
Fri Dec 23, 2016 12:43 am
DC4, DC6B, DC7, DC7C, B377, all under the PAA banner. DC4 was a 13+ hour tip. DC7C was around 9+
The good ole days
blacksoviet
Fri Dec 23, 2016 12:52 am
Did the DC-7C carry a relief crew?
BravoOne
Fri Dec 23, 2016 2:37 am
3 pilots including the Navigator
2 FE's
blacksoviet
Fri Dec 23, 2016 2:41 am
2 FE's
Why did the DC-7 have two FEs?
iahcsr
Fri Dec 23, 2016 3:05 am
Did the stops in HNL also require recrewing the FAs? Or was there still sufficient duty time remaining for them?
kaitakfan
Fri Dec 23, 2016 3:58 am
Okie
This guy gets it! I'm not going to break 500 hours on reserve on the 756 fleet this year.
TW870
Fri Dec 23, 2016 4:19 am
It would depend on how long the stop was. If I remember right from my UA days the work rule on flights that long was that max duty = scheduled block plus 3 hours. If you are more than three hours over schedule, you have got to re-crew. That is also the work rule in the new contract that was just ratified, and I believe they are all flying by those work rules even though they are not yet flying together (and this was presumably an sCO crew).
FlyHossD
Fri Dec 23, 2016 8:13 am
Such pilot swaps are not uncommon and I participated in one just before my retirement. As I recall, our original relief pilot was used to cover another flight after that flight's first officer had been hit by a car on the layover. The resulting shuffle forced us to land in BOS, short of the destination for a replacement pilot.
b747400erf
Fri Dec 23, 2016 10:07 am
They had to fight the dreaded 100kt+ tail winds that winter time brings.
b747400erf
Fri Dec 23, 2016 10:08 am
Having to fly 5 hours to paradise only to quickly take off on duty back to the continent, the life of a younger relief pilot is not fun!
anshabhi
Fri Dec 23, 2016 11:57 am
Air India 173 DEL-SFO also flies over Pacific, non-stop. It covers almost 2800 km more than UA 2.. In that way, Very strange that UA 2 makes a stop.
BravoOne
Fri Dec 23, 2016 4:07 pm
blacksoviet wrote:
2 FE's
I have to retract that as I'm not really sure that they used two F/E' on this leg. It would have been contractural (FEIA), issue and not a regulatory requirement. Use to see 2 FE on a lot of long range 707 trips.
