MaxTrimm wrote:What is AA's longest 738 route?
Q wrote:Miami to Seattle AA has B738 daily.
Q
33lspotter wrote:Q wrote:Miami to Seattle AA has B738 daily.
Q
Well, this would have to be the longest that I know of. Does AA operate any 738s to South America (and if so where)?
33lspotter wrote:Does AA operate any 738s to South America (and if so where)?
MSPNWA wrote:I'll jump in with the obvious. They've made a short-sighted mistake that's costing them more and more every day they wait. There's just no good reason not to install them, particularly when they have so many young frames.
commavia wrote:For airlines as for any business, there is always the matter of opportunity cost - a dollar spent "here" is a dollar not spent "there." Each profitability improvement - lower costs and/or higher revenue - has to be weighed against a simple question: compared to what?
Raventech wrote:No it is not that simple. That's the line of thinking that makes people justify buying a brand new prius to save money on gas when you only drive 5 miles a day.
commavia wrote:When viewed in the context of managing an entire fleet, as opposed to a single aircraft type, AA's decision not to go with split scimitars on the 737s makes perfect sense.
For airlines as for any business, there is always the matter of opportunity cost - a dollar spent "here" is a dollar not spent "there." Each profitability improvement - lower costs and/or higher revenue - has to be weighed against a simple question: compared to what? And when you look at where AA's fleet is (and was) relative to some of its competitors, and the amount of capital it has been spending on its fleet, AA's rationale is self-evident. As compared to 30-year-old MD80s and 757s, it is intuitively obvious that one incremental, marginal additional dollar of capex investment is better spent on buying a new airplane to completely replace an MD80 as compared with simply marginally improving the efficiency of a new and already-relatively-efficient 737. And that's before even accounting for the other ancillary benefits that come with entirely new aircraft such as the maintenance holiday and other cost-saving and revenue-enhancing opportunities.
AA has consistently concluded that the biggest "bang for the buck" in terms of reducing per-seat fuel consumption was to (1) replace aging MD80s, 757s and 767s and (2) densify the cabins of remaining aircraft. AA has weighed such fleet investment decisions against the current state. But the "current state" is a moving target, and in a few years, when the fleet renewal is largely finished, AA may have a different opinion about the economic efficacy of split scimitars. And, needless to say, if fuel prices spike again, that, too, could obviously change the calculus and make the marginal fuel efficiency improvement more financially attractive.
But for now, the bottom line is this: at the time the fleet transaction was announced in July 2011, AA said that the new 737s and A320 family aircraft being purchased were 35% more fuel efficient than MD80s, and 12% better than 757s, on a per-seat basis. The comparable improvement from split scimitars is nowhere near that. And so, given that AA has lots of MD80s and 757s still left to replace, it's clear why AA is spending money on new 737s and A321s at the moment instead of split scimitars.
Raventech wrote:No it is not that simple. That's the line of thinking that makes people justify buying a brand new prius to save money on gas when you only drive 5 miles a day. Just because they save fuel does not mean they save enough fuel to justify the expense. If it takes several years to break even then its no wonder they would opt not to as they won't save enough fast enough to be worth it. It might be that they took that money and spent it on other items that either saved them more money or increased revenues more than the fuel saving would be.
Acutally, since im curious, why don't we run the numbers. I will source all my data from http://www.aviationpartnersboeing.com/ , http://www.iata.org/publications/econom ... lysis.aspx , and http://www.boeing.com/assets/pdf/commer ... ps/737.pdf
We will assume 160 Pax at 220 lbs (195 for Pax and 25 for luggage) at full load unless payload restricted, then max payload. OEW: 91300 MTOW: 174900 (Assumed for both).
ZFW unless Payload restricted is 126,500 lbs.
Fuel Cost will be calculated based on empty tanks at $1.535 per gallon
ASL = Average Stage Length
**** Step 1: No Winglets ****
@ 500nm ASL: Fuel Needed - 13000 lbs, Fuel Cost - $2,978.36
@ 1000nm ASL: Fuel Needed - 19000 lbs, Fuel Cost - $4,352.99
@ 2000nm ASL: Fuel Needed - 33000 lbs, Fuel Cost - $7,560.45
*** Step 2: With Winglets ****
@ 500nm ASL: Efficiency Gains: 2.5%, Fuel Needed 12675 lbs, Fuel Cost - $2,903.90, Money Saved - $ 74.46
@ 1000nm ASL: Efficiency Gains: 3.45%, Fuel Needed - 18344.5 lbs, Fuel Cost - $4,202.81, Money Saved - $ 150.18
@ 2000nm ASL: Efficiency Gains: 3.9%, Fuel Needed - 31713 lbs, Fuel Cost - $7,265.59, Money Saved - $294.86
*** Step 3: Scimitar Upgrade ***
@ 500nm ASL: Efficiency Gains: 1%, Fuel Needed 12548.25 lbs, Fuel Cost - $2,874.86 , Money Saved - $29.04
@ 1000nm ASL: Efficiency Gains: 1.6%, Fuel Needed - 18050.99 lbs, Fuel Cost - $4,135.56 , Money Saved - $67.24
@ 2000nm ASL: Efficiency Gains: 2%, Fuel Needed - 31078.74 lbs, Fuel Cost - $7,120.28, Money Saved - $145.31
*** Step 4: Math ***
Assuming approx 20 hours days and about 50 minute block times and 340 days worth of flying per year
500nm = 7 Segments per day
1000nm = 5 Segments per day
2000nm = 3 Segments per day
At 500nm ASL: (ex SFO- PDX)
Blended Winglets upgrade will save $521.21 a day and break even in 5.98 Years
Scimitar Upgrade will save $203.27 a day and break even in 8.32 Years
At 1000nm ASL: (ex PHX-SEA)
Blended Winglets upgrade will save $750.89 a day and break even in 4.15 Years
Scimitar Upgrade will save an additional $336.22 a day and break even in 5 Years
At 2000nm ASL: (ex PHX-BOS)
Blended Winglets upgrade will save $884.57 a day and break even in 3.52 Years
Scimitar Upgrade will save an additional $435.94 a day and break even in 3.88 Years
Basically the shorter the segments the less they save and the longer it takes to break even. At that point the question is can you take the money and spend it somewhere else and make more money in the same amount of time, and if yes then scimitars don't get installed. It's all about priorities, and AA decided that they can make more money if they spend the money elsewhere.
LAX772LR wrote:More like jump in with absolutist conclusions based on information that you don't have.
MSPNWA wrote:If AA can afford billions in investments such as share buybacks, they can afford the investment of a couple hundred sets of Split Scimitars.
Raventech wrote:Basically the shorter the segments the less they save and the longer it takes to break even. At that point the question is can you take the money and spend it somewhere else and make more money in the same amount of time, and if yes then scimitars don't get installed.
MSPNWA wrote:Unfortunately for you my conclusion is based on absolutist information that has already been posted.
MSPNWA wrote:There's a huge difference between buying a new airplane and adding a new winglet to an existing airplane. It's an apples and oranges comparison.
MSPNWA wrote:The only time it should come down to one or the other is if you're nearly broke and can't afford both. AA is obviously not broke.
MSPNWA wrote:Foregoing an easy cost reduction with a guaranteed positive ROI is incredibly foolish and is the type of thinking that runs airlines into the ground.
MSPNWA wrote:By artificially reducing CAPEX for short-term stock prices, they reduce longer-term returns (and stock prices).
MSPNWA wrote:A general rule of thumb is that you always sign off for cost reductions for existing capacity if you can afford the expense, and it's a positive return.
MSPNWA wrote:That's the case here, and it's why all U.S. airlines, besides AA, are going for it.
MSPNWA wrote:Again, there's simply no valid reason out there for AA NOT to do it.
Raventech wrote:MSPNWA wrote:I'll jump in with the obvious. They've made a short-sighted mistake that's costing them more and more every day they wait. There's just no good reason not to install them, particularly when they have so many young frames.
LAX772LR wrote:You managed to miss the key element of what Commavia was trying to tell you:
It's not that they can't afford it, it's that they don't feel they can justify it relative to the opportunity cost at this time, if ever.
LAX772LR wrote:And if you don't want to hear it from either of us; then look to the poster whom you just alluded to, as he ALSO told you the exact same thing. Here it is again, in case you didn't see it:Raventech wrote:Basically the shorter the segments the less they save and the longer it takes to break even. At that point the question is can you take the money and spend it somewhere else and make more money in the same amount of time, and if yes then scimitars don't get installed.
LAX772LR wrote:Okay, I'll bite:
Posted by who, and where?
Cite it..... I'll zip right to it, bringing it here, and we'll discuss.
commavia wrote:Indeed. No question about it. The acquisition of a new aircraft unquestionably requires a lot more capital, but as already said, it also of course delivers a far larger fuel efficiency improvement relative to an old aircraft. And again, that's without also accounting for the other ancillary financial benefits of new aircraft including the significant maintenance "holiday" which is near-term, and thus not only profit-accretive but also NPV-accretive. At today's cost of money, it isn't at all hard to see how AA made the business case close on focusing its next incremental dollar of capex on new aircraft over new winglets.
commavia wrote:Well "nearly broke" is relative, and in any event, every economically rational decision made at a profit-seeking corporation is absolutely made on the basis, among other things, of opportunity cost - regardless of the broader financial state of the company. Indeed, excluding the consideration of opportunity cost would render a decision economically irrational.
commavia wrote:Talk about a logical fallacy. That's not how corporate decision making works - it's not "if we have money for A than we also have money for B." If A is the more NPV-attractive investment, then it should be maximized and prioritized over B until its economic benefits have been optimally realized.
commavia wrote:Actually, the "if we have money for A than we also have money for B" fallacy above is the type of thinking that runs companies into the ground. On the contrary, concentrating investment dollars on the place where they will have the largest and most immediate impact on profit is highly economically rational.
commavia wrote:Who said anything about "reducing capex," "artificially" or otherwise? On the contrary, nobody is suggesting that AA reduce its investments, and indeed AA is investing more than any other U.S. airline in dramatically improving the cost efficiency of its fleet. The argument isn't about more capex or less. It's about how that capex is spent.
commavia wrote:No. The "general rule of thumb" is that you "sign off" on the decisions that maximize NPV. And as multiple people have now explained, in AA's case, it is entirely reasonable to conclude that the NPV-maximizing decision is to concentrate on rapidly replacing 30-year-old MD80s and 757s with brand new (and winglet-equipped!) 737s and A321s.
commavia wrote:Every U.S. airline is different.
commavia wrote:There are multiple valid reasons restated multiple times in this thread.
777PHX wrote:I'd wager the guys making these decisions at AA are far more informed and have far better data to use to make these decisions than you do.
KTPAFlyer wrote:Title says it all. Is there any one reason in particular? Delta, United, Southwest, Alaska went for it, why is AA the holdout? All contributions appreciated, thank you.
MSPNWA wrote:Commavia's arguments have been nullified by the deeper economic theory and facts brought into this thread.
MSPNWA wrote:Except Raventech's figures (which I defend) shows us why airlines are doing it!
MSPNWA wrote:take those numbers and show me why UA, WN, DL, AS, and others are wrong.
MSPNWA wrote:
Oh yeah, the "the airline guys never make a wrong decision" cop-out. We know that's far from the truth. Why even have a discussion if airlines are infallible?
commavia wrote:For airlines as for any business, there is always the matter of opportunity cost - a dollar spent "here" is a dollar not spent "there." Each profitability improvement - lower costs and/or higher revenue - has to be weighed against a simple question: compared to what? And when you look at where AA's fleet is (and was) relative to some of its competitors, and the amount of capital it has been spending on its fleet, AA's rationale is self-evident. As compared to 30-year-old MD80s and 757s, it is intuitively obvious that one incremental, marginal additional dollar of capex investment is better spent on buying a new airplane to completely replace an MD80 as compared with simply marginally improving the efficiency of a new and already-relatively-efficient 737. And that's before even accounting for the other ancillary benefits that come with entirely new aircraft such as the maintenance holiday and other cost-saving and revenue-enhancing opportunities.
MSPNWA wrote:The economist in me is why I believe AA has been making a mistake. It's not hard to make the same calculations as the airline, and Raventech has done a lot of it already. The data is out there. If AA can afford billions in investments such as share buybacks, they can afford the investment of a couple hundred sets of Split Scimitars. Foregoing an easy cost reduction with a guaranteed positive ROI is incredibly foolish and is the type of thinking that runs airlines into the ground.
MSPNWA wrote:The only way it's even cost effective, let alone worth it on an opportunity cost basis, is if those MDs, Boeings, or Airbuses have higher costs (and we're not counting their lower ownership costs in relation to NPV) even after you subtract a 738s entire fuel burn from their fuel burn. That's not happening. So if AA decided to buy more 737s instead of buying winglets, AA is paying more, and each day they wait, the more they will pay for their mistake. They are literally burning extra money out the back of the CFMs.
MSPNWA wrote:The opportunity cost clearly is in favor of the winglets over short-term stock inflation such as inflated ROICs and stock repurchases. It's even in favor of winglets over new airplanes.
MSPNWA wrote:But like I've said all along, your theory is reliant on a flawed either/or situation. That's not the case with a massive and profitable corporation like AA. They do not have that shortage of capital available to them.
MSPNWA wrote:It's not a fallacy.
MSPNWA wrote:If this is an either/or situation due to capital constraints, and A is an airplane needed for growth, and B is a cost efficiency product, only then do you have a point. AA is not in that situation, and that is not the purchase scenario up for debate.
MSPNWA wrote:Indeed, U.S. airlines are intentionally restricting their capital spending to inflate stock price-friendly metrics. It's a good thing to restrict capital spending when the capital is relatively expensive. It's also good to restrict if it's a negative return or the risk isn't worth the reward. But it's not a good idea to restrict it when capital is relatively cheap, and the return is known, solidly positive, a virtual guarantee, and diminishes over time (while the capital expense required does not diminish).
MSPNWA wrote:And second, it is very wrong to say "most immediate impact on profit is highly economically rational". Proper management looks at both the short-run and long-run. What can be highly profitable in the immediate future could be highly unprofitable over the long-run.
MSPNWA wrote:Now that your "reasonable conclusion" has been debunked, where's your evidence against my theory?
