PSU.DTW.SCE wrote:Regarding the following:
With the latest OAG update more reductions from Delta in the Detroit market.
DL DTW-GSP JUL 4>3 AUG 4>3 SEP 4>3
DL DTW-LEX APR 4>3
DL DTW-SDF JUL 5>4
DL DTW-STL JUL 5>3 AUG 5>3
DL DTW-SWF APR 1.8>0.9 MAY 1.8>0.9 JUN 1.9>1.1 JUL 1.8>1.0 AUG 1.9>1.0 SEP 1.8>1.0
DL DTW-YVR JUN 0.2>0.1
There are some known filing errors that show up in the weekly OAG data threads. While it is all very interesting, you have to take into consideration the accuracy and issues associated with the source data. As discussed in the weekly OAG thread, there was an issue with many of the changes in the DL Connection carriers and equipment types that showed up this week.
It appears to be that for whatever reason the DL - GoJets G7 CR7 flights are not showing up in the OAG data however the flights are still for sale.
DL DTW-GSP JUL 4>3 AUG 4>3 SEP 4>3 - filing error/timing issue with the GoJets CR7, still showing 4x for sale
DL DTW-LEX APR 4>3 - filing error/timing issues, still shows 4x for sale
DL DTW-SDF JUL 5>4 - filing error/timing issues, still shows 4x for sale
DL DTW-STL JUL 5>3 AUG 5>3 - - filing error/timing issues, still shows 5x for sale (2 717s were swapped to GoJets CR7)
DL DTW-SWF APR 1.8>0.9 MAY 1.8>0.9 JUN 1.9>1.1 JUL 1.8>1.0 AUG 1.9>1.0 SEP 1.8>1.0 - filing error/timing issues, still shows 2x weekday for sale
DL DTW-YVR JUN 0.2>0.1 - seasonal Saturday route (some years this is flown, some years its not)
So really nothing worth crying over spilled milk here.
klm617 wrote:But it should be noted a market like DTW-STL reduced from 5 mainline to 3 and 2 RJs that says a lot about the direction Delta is going in Detroit...
flymco753 wrote:YVR is going 2x on Saturday's next summer too so maybe that's a good sign, tho I believe this flight should be daily.
Most of CG7's are missed filed half of the time, you'd think that from 4>3 GSP flights they'd add a 717. I eventually see a 717 on GSP, BHM, and BTV because these flights have gained more pax not only through connection but locally as well. From what I've heard they want to cut the amount of single class cabins at DTW and introduce the A321, PDX and ATL are the only 2 for now but it'll likely spread to LGA, TPA, FLL and SLC for starters.
klm617 wrote:But it should be noted a market like DTW-STL reduced from 5 mainline to 3 and 2 RJs that says a lot about the direction Delta is going in in Detroit you'd also be hard pressed to find a mainline jet between DTW and DFW or IAH guess those people have to deal with ATL if they want to fly to those places> Also keep in mind with the end of BGR service every one in the upper Midwest that needs to fly to BGR has basically been cut off or are forced to double connect.
compensateme wrote:klm617 wrote:But it should be noted a market like DTW-STL reduced from 5 mainline to 3 and 2 RJs that says a lot about the direction Delta is going in Detroit...
Huh? DTW/STL hasn't been mainline in years; just a few years ago, the route was all-Delta Connection. The fact that we got any mainline back is progress (of course, WN perpetually operates two daily 737 in the market).
I would judge DL by year-over-year, not schedule changes that essentially modifies placeholders. Consider UA, which creates schedules 12-months out almost entirely with placeholder equipment.
flymco753 wrote:Also, where is N310DN? It came in from MIA and never left DTW.
Puissance wrote:Many cruises begin and end in SEA. They just have to have a foreign port of call (Canada) before returning.Isn't the YVR flight done for Alaskan cruises, primarily? Because of the Jones Act, most cruises begin or end in Canada.
flymco753 wrote:Wow, add TUS to this list, PDEW is nearly 100 for every quarter since 2015, DL could do it daily on a 319 no problem, the trend for TUS also is growth from historical data.DL adds or announces ABQ (1x M90), ELP (1x 319), SMF (1x 320), SNA (1x 739), GEG (1x 320), YYC (2x 319), HKG (1x 350), GDL 1x 320 (or AM 1x 737), DAB (1x M80).
flymco753 wrote:I have some predictions for 2017 and the DTW market, some are ambitious and far fetched but possible when you extrapolate data and resources. I also added potential aircraft types. Feel free to discuss.
AA adds LAX (1x 319)
NK increases presence with increased IAH service (2x 319) and year round BOS (1x 319), MSP service (1x 320).
-New service possibilities: BNA (2x 320), DAB (1x 319), AUS (1x 320), JAX (1x 320).
-Existing possibilities: PBI (1x 320), SEA (1x 321).
AS adds PDX (1x 739), SFO (1x 738), LAX (1x 739) or SAN (1x 738).
EK announces DXB (1x 772).
B6 adds MCO (1x 320) or JFK (2x E190).
LOT announces WAW (2x weekly 788).
DY announces LGW (1x weekly 788), CDG (1x weekly 788), AMS (1x weekly 788), BCN (1x weekly 788), CPH (2x weekly 788), or OSL (2x weekly 788).
F9 adds TPA, (3x weekly winter 319) LAS (1x 320).
G4 closes FNT or TOL, adds PIE (320), SFB (M80), PGD (320), JAX (M80), MSY (M80), AUS (320), AZA (M80), LAS (320).
cvgComair wrote:Everyone I ask that I know that flies Allegiant goes to FNT or TOL, when I'm up in the area I've been seeing commercials advertising Allegiant service, they don't say which airport but it's advertised and there's a decent customer base from the area that uses them, so I could see it happening, PIE especially. PDEW for JAX and MYR is pretty large for the amount of service that is offered, 1x CR9 on DL to JAX and 1x NK 320 1x DL CR7 for MYR. Both of them can work. I guess we'll see what happens, it's not impossible though.I think that G4 could start some interesting routes like VPS/MYR/SAV from DTW, in addition to typical routes like SFB/PIE/PGD.
falstaff wrote:Yep, used to fly this route a lot in the 2005-2011 timeframe. NW typically flew with with all DC-9-10/30/40/50 like mentioned. They started using the ARJ and 319 on occassion but it was mostly DC-9. Once the ARJ went away, occasionally a CRJ-200 would show-up on a flight or two. STL was a bridge city for a while for CRJ-200s between DTW, MSP, MEM. Post-merger it was common to have a mix of mainline and DCI - a lot of CR7, CR9 aircraft plus some MD88 and A319/A320s.compensateme wrote:
I fly that route six times a year, or more, usually on DL. I don't recall ever flying on RJs in both directions. I have flown it on 717s, A319s and MD88/90 before. The CRJ-900 is the common RJ on the flight. From what I've seen. This February I'm booked on a CRJ-900 to STL and 717 to DTW.
I have been flying that route since 2000. NW usually had DC-9s (10/30/40/50) on the route but I flew the A319 a couple times. Sometimes the they had XJ ARJ-85s on the route, which was great. F in the ARJ was great. I loved those four engines. They also flew the CRJ-200 and later 900 on the route.
I sometimes fly WN on the route depending the schedule. The two carriers are competitive on the route. I used to like flying WN when they still had the 737-200 on that route; I liked the club seating.
klm617 wrote:APN, CIU, ESC.I think it would be interesting and telling to see how many markets are only served over Detroit verses the other hubs in the Delta network to further give evidence that Detroit is rock bottom as far as hub priority in the Delta network.
These come to mind.
ERI
SWF
ELM
ITH
SCE
NGO
BGM
PSU.DTW.SCE wrote:Jokes on you my friend. XDI predict in 2017 that DL announces the draw-down and closure of the DTW hub scheduled to take effect in early 2018. All that will remain is hub and focus city flights and maybe an AMS flight.
You heard it here first.
PSU.DTW.SCE wrote:I predict in 2017 that DL announces the draw-down and closure of the DTW hub scheduled to take effect in early 2018. All that will remain is hub and focus city flights and maybe an AMS flight.
klm617 wrote:PSU.DTW.SCE wrote:I predict in 2017 that DL announces the draw-down and closure of the DTW hub scheduled to take effect in early 2018. All that will remain is hub and focus city flights and maybe an AMS flight.
It may take a bit longer than that but reductions will continue a little at a time in favor of ATL,SLC,SEA and MSP you can count on that. I am sure you can see slowly international traffic is being diverted away from Detroit with the extra AMS-SLC/MSP and ICN-ATL flights this will further reduce the transfer passengers over Detroit.
falstaff wrote:I fly that route six times a year, or more, usually on DL. I don't recall ever flying on RJs in both directions. I have flown it on 717s, A319s and MD88/90 before. The CRJ-900 is the common RJ on the flight. From what I've seen. This February I'm booked on a CRJ-900 to STL and 717 to DTW...
PSU.DTW.SCE wrote:No big bad DL is out to get DTW, MSP, and SLC...
compensateme wrote:This might not be the most appropriate time to mention this, but in this month's Sky magazine, the ATL terminal map takes up a whole page whereas DTW, MSP & SLC have been shrunk to fit on the same page. You need a magnifying glass just to read the maps.
PSU.DTW.SCE wrote:I understand that some of the routes aren't added to protect another like DTW-YHZ would negatively effect NYC's service so they don't add it to protect it, but instances like ELP, ABQ, and TUS where a daily flight on a 319 or 320 is feasible and wouldn't burn ATL's or MSP's service to those cities, than why not add it? I understand SMF and SNA have been flown but utilization of the right aircraft and a well timed flight can make it work.I wouldn't expect any of that stuff on DL to happen in 2017. Almost every single one of those involves hub overflying on relatively long and thin routes.
SMF and SNA have been flown before and dropped
ELP, TUS, ABQ are all small markets from DTW that are too far long/thin to use mainline aircraft
YYC in theory could be a summer seasonal, but they can easily just add capacity and pick-up the connection traffic over MSP
The reality is that in the context of the network, these routes are better flown from closer hubs or where DL chooses to route over a much larger hub like ATL.
This reads more like a wish-list / hope/prayer than any sort of true prediction. More like throwing darts on the wall.
flymco753 wrote:I understand that some of the routes aren't added to protect another like DTW-YHZ would negatively effect NYC's service so they don't add it to protect it, but instances like ELP, ABQ, and TUS where a daily flight on a 319 or 320 is feasible and wouldn't burn ATL's or MSP's service to those cities, than why not add it? I understand SMF and SNA have been flown but utilization of the right aircraft and a well timed flight can make it work.
lavalampluva wrote:Airlines have a reason behind picking routes. Airlines fly routes and start new service because they feel it makes them money. If it doesn't they trim it back or cut it entirely. DL does NOT have anything against DTW! Why would they hate DTW? If they did why then do they still fly all those international routes from DTW? They could just pack them all up and move them to SEA or MSP.
Maybe AB, NH, OK, or SK (just to name a few) don't fly into DTW because it doesn't fit their needs!
I'm not trying to feed the troll, but I feel like I am. But honestly I'm tired of the sky is falling on Detroit threads
compensateme wrote:I'm sure DAB could happen at the least on an M88, it wouldn't put a dent in ATL's service, you're right about these not being candidates, but the PDEW is there. Some markets have shown an increase of service because of demand, BNA is my favorite example in this situation, I don't know why. DL has planned 6x daily next summer on all mainline, an increase from 2x RJ's and 3x mainline previously, even than the frequency is still 5x at that point. DL has also done some increases from CRJ's to larger regional aircraft like BHM, ALB, GSP, BTV and what not. We'll see what the future holds, it's probably likely that the increase of service will come from other carriers.flymco753 wrote:I understand that some of the routes aren't added to protect another like DTW-YHZ would negatively effect NYC's service so they don't add it to protect it, but instances like ELP, ABQ, and TUS where a daily flight on a 319 or 320 is feasible and wouldn't burn ATL's or MSP's service to those cities, than why not add it? I understand SMF and SNA have been flown but utilization of the right aircraft and a well timed flight can make it work.
ABQ peaks at 1xMSP, 3xATL.
ELP peaks at 3xATL. There is no service to MSP and even SLC was discontinued awhile ago.
TUS peaks at 2xATL. There's only seasonal service to MSP.
None of these are candidates for service from DTW. Consider that before F9 entered DTW/PHX, DL had reduced the route to 3x daily, with a fourth frequency limited to the weeks surrounding spring break, the peak summer stretch and a few days surrounding the year-end Holidays -- and outside the spring break flights, the lion's share were operated with A320. DL brought back the fourth frequency, but AA has since dropped their's.
And this is the first time since the early 2000s that DTW has had daily service to CUN this summer (generally 1x-3x per week) -- the traffic's there but DL route planners masturbate at the prospects of hourly ATL/CUN service. Not unsurprisingly, the addition of DTW/CUN this summer coincides with a reduction in frequency on ATL/CUN (don't feel bad for ATL, they still get a minimum of six flights ... and I wouldn't be surprised if DTW is ultimately whacked). We like to take a 4-day all-inclusive at least once every summer; CUN is a short flight but connecting can be tiresome.
flymco753 wrote:I'm sure DAB could happen at the least on an M88, it wouldn't put a dent in ATL's service, you're right about these not being candidates, but the PDEW is there. Some markets have shown an increase of service because of demand, BNA is my favorite example in this situation, I don't know why. DL has planned 6x daily next summer on all mainline, an increase from 2x RJ's and 3x mainline previously, even than the frequency is still 5x at that point. DL has also done some increases from CRJ's to larger regional aircraft like BHM, ALB, GSP, BTV and what not. We'll see what the future holds, it's probably likely that the increase of service will come from other carriers.
PSU.DTW.SCE wrote:Are they using the 27's for arrivals and shooting departures only off 22R?
johns624 wrote:As much as a certain poster tries to say that it is about lower fares, I think that what he really wants is new tails in DTW. He's sick of blue/red. Even if another airline is metal-neutral, like KLM or VS, he wants it instead of DL.
