Matt6461 wrote:I've never actually flown on the 787 myself - specifically for this reason. I recently had an opportunity to do so on long haul but picked a 9ab 777 operator instead. I've heard it's a barely noticeable difference but I'm a bit wider than average and didn't want to risk 13 hours of rubbing shoulders with a stranger.
zeke wrote:People do not care if its cheap enough.
jeffrey0032j wrote:How about the 10 abreast A350 that is entering service soon, that is a much fairer comparison as the 787 was designed as an 8 abreast plane, so we should be comparing the "tight squeeze" version of the 787 with the "tight squeeze" version of the A350.
Spiderguy252 wrote:jeffrey0032j wrote:How about the 10 abreast A350 that is entering service soon, that is a much fairer comparison as the 787 was designed as an 8 abreast plane, so we should be comparing the "tight squeeze" version of the 787 with the "tight squeeze" version of the A350.
Who is going to operate a 10 x abreast A350?
DUBAI: Airline adoption of ultra high-density economy class cabins shows no sign of abating with Airbus confirming to RGN that a European carrier has become the first operator to select a 10-abreast configuration for the Airbus A350 XWB.
He declined to name the airline, but there was some speculation at the show that perhaps French holiday carrier Air Caraibes has potentially gone in this direction; its first A350-900s are scheduled for delivery next year and it already operates high-density A330s with seat width that is sub 17
817Dreamliiner wrote:jeffrey0032j wrote:How about the 10 abreast A350 that is entering service soon, that is a much fairer comparison as the 787 was designed as an 8 abreast plane, so we should be comparing the "tight squeeze" version of the 787 with the "tight squeeze" version of the A350.
The A350 at 10 abreast is more than an inch narrower per seat than the 787 at 9 abreast. How is that a fairer comparison when the seats at 9 abreast for both aircraft are 0.51 inches different in total (59.6 for 787 vs 60.11 for the A350)?
scbriml wrote:jeffrey0032j wrote:How about the 10 abreast A350 that is entering service soon, that is a much fairer comparison as the 787 was designed as an 8 abreast plane, so we should be comparing the "tight squeeze" version of the 787 with the "tight squeeze" version of the A350.
That would only be a valid comparison if all bar one A350 operator were fitting 10-across. They're not - 10-across A350s will be as rare as 8-across 787s. The vast majority of 787s are 9-across in standard economy, just as the vast majority of A350s will be 9-across in standard economy.
jeffrey0032j wrote:Would anyone who designed the 777 foresaw it being used in a 10 abreast config? I would think no, but 10 abreast 777 is now the new norm despite largely being a 9 abreast plane for the first 10 years of service (approx), and who knows, the 350 will be a similar story, albeit they went 10 abreast pretty early on with a small handful of carriers.
scbriml wrote:jeffrey0032j wrote:Would anyone who designed the 777 foresaw it being used in a 10 abreast config? I would think no, but 10 abreast 777 is now the new norm despite largely being a 9 abreast plane for the first 10 years of service (approx), and who knows, the 350 will be a similar story, albeit they went 10 abreast pretty early on with a small handful of carriers.
The 777 is not relevant to the comparison of the 787 and A350 at 9-across (which is the subject of this thread). What may or may not happen in the future is not relevant either. Today, AFAIK, all airlines except for one are flying the 787 at 9-across in standard economy. One or two airlines may fly the A350 at 10-across in standard economy but the rest are at 9-across. So the comparison at 9-across is fair and totally relevant.
817Dreamliiner wrote:Well, If you consider 0.55 inches per seat "significant" in terms of shoulder width then sure. The seats in both ACAPS are only 0.51 inches different in total (59.6 for the 787 and 60.11 for the A350).
seahawk wrote:zeke wrote:People do not care if its cheap enough.
Maybe. I think we will soon see an economy basic class being introduced that will define the bottom line. Making standard economy worse is reaching a point where it is damaging the reputation for legacy carriers. If this happens it might be a chance for Airbus to gain a small advantage.
You can not make it worth than 3-3-3 on a 787 and 3-4-3 on a 777, while you could do 3-3-3 on an A330 and maybe even 3-4-3 on an A350 for the basic economy rows. The other options is that airlines are forced to remove some seats in the Boeings so that they have more rows of 2-4-2 / 3-3-3 for the basic economy product. In both cases the difference in seats changes in Airbus favour.
scbriml wrote:The 777 is not relevant to the comparison of the 787 and A350 at 9-across (which is the subject of this thread). What may or may not happen in the future is not relevant either. Today, AFAIK, all airlines except for one are flying the 787 at 9-across in standard economy. One or two airlines may fly the A350 at 10-across in standard economy but the rest are at 9-across. So the comparison at 9-across is fair and totally relevant.
JoeCanuck wrote:Oh my lord....17" isn't "making it worse". It's the same seat width that's been around forever. It's the standard seat width of the 747, which has been around since the 60's, so when people clamor on about how the 9 abreast 787 has introduced an all new level of torture to the traveling public, they are blowing it out of their nether regions. It's the same width that has always been used on the 737 and the 757.
seahawk wrote:JoeCanuck wrote:Oh my lord....17" isn't "making it worse". It's the same seat width that's been around forever. It's the standard seat width of the 747, which has been around since the 60's, so when people clamor on about how the 9 abreast 787 has introduced an all new level of torture to the traveling public, they are blowing it out of their nether regions. It's the same width that has always been used on the 737 and the 757.
I meant you can not squeeze in another seat in the 3-3-3 787 or 3-4-3 777, you can squeeze in another seat in the 2-4-2 A330 and the 3-3-3 A350, although the seats that result from this are worse than the seats in the 787. I personally find the 3-3-3 787 just fine and due to the windows and better and clean air, I prefer it over any other aircraft.
JoeCanuck wrote:17" long haul seats aren't a new phenomena...they have been the standard for a very long time...long enough for passengers to have been able to choose between 17 and 18" long haul...and they still seem to be choosing with their wallets.
This same conversation was running rampant when EK went 10 abreast in their 777's more than a decade ago. It was going to ring their death knell. Instead, it turns out they read the tea leaves correctly and popularized what turned out to be the new 777 standard.
Group51 wrote:817Dreamliiner wrote:Well, If you consider 0.55 inches per seat "significant" in terms of shoulder width then sure. The seats in both ACAPS are only 0.51 inches different in total (59.6 for the 787 and 60.11 for the A350).
I recently flew an A380, A330 and 787 in quick succession. To my surprise, despite the apparently marginal statistics, the only seat I felt was narrow was the 787. definitely noticeable.
enzo011 wrote:Airbus mind you went for probably the smallest cabin width to fit 18" seats into for the A350. That is why when you look at the numbers it is only 6" wider than the 787. But the design that was on the minds were always the 18" seat width in Y. Boeing has claimed the better economics (less drag for the fuselage) but they have not won the comfort stakes, no matter how much posters will try to tell you its fine. It really isn't.
Matt6461 wrote:JoeCanuck wrote:17" long haul seats aren't a new phenomena...they have been the standard for a very long time...long enough for passengers to have been able to choose between 17 and 18" long haul...and they still seem to be choosing with their wallets.
I don't think we have sufficient data to make this judgment. You're sort of assuming that EK's decision to go 10ab was "free" from a RASM perspective. Likewise with any 10ab operator. That simply can't be true - otherwise airlines like SQ and KE are leaving money on the table. Maybe they don't notice that they could fit another seat?
CX's decision to go 10ab on 777 was made pursuant to a long market study. Surely that market evaluated the impact on RASM versus CASM or revenue versus cost - however you want to phrase it. Surely JAL made the same evaluation in its decision to stay 8ab with its 787's.
That passengers vote with their wallets doesn't tell us everything we need to know. What entices those votes? And if it's lower fares, is it worth it? Regarding the 10ab 777, most airlines find the tradeoff "worth it." Ok, so a 10ab 777 is generally more profitable than a 9ab 777.
What we don't yet know is whether a 9ab A350 is generally more profitable than a 9ab 787, or vice versa. It took a decade for the industry to figure out the 777 question; a similar process may unfold for the 787/A350. Pretending there's no potential tradeoff, no issue here, just won't do.
bgm wrote:Anyone see a pattern here? The cramped planes seem to come from one manufacturer...
JoeCanuck wrote:18" seats on 330's and 340's, and people still flocked to EK, which goes to show there is a lot more to airline comfort than seat width.
Matt6461 wrote:CX's decision to go 10ab on 777 was made pursuant to a long market study. Surely that market evaluated the impact on RASM versus CASM or revenue versus cost - however you want to phrase it.
zeke wrote:JoeCanuck wrote:18" seats on 330's and 340's, and people still flocked to EK, which goes to show there is a lot more to airline comfort than seat width.
At the start starting new markets low price, dump capacity, low yield, high volume. And now they have pulled the 77W off a lot of their long haul routes and replaced them with A380s.Matt6461 wrote:CX's decision to go 10ab on 777 was made pursuant to a long market study. Surely that market evaluated the impact on RASM versus CASM or revenue versus cost - however you want to phrase it.
I am not aware of any decision to go 10 across in the 77W long haul, I am aware of 10 across on the short/medium haul RR powered aircraft, and 10 across on the long haul 777X. The RR powered 777-300 need the additional capacity since the 744 was retired from passenger service. They are already around 400 seats with a regional business class 7 across which is very different from the long haul fleet.
Matt6461 wrote:Crucial point: If only 20% of pax develop a strong preference for the A350, that would really challenge 787 operators.
bgm wrote:Airplanes with narrow seats:
Boeing 737 - 17"
Boeing 747 - 17"
Boeing 757 - 17"
Boeing 777 10x - 17"
Boeing 787 8x - 17"
Anyone see a pattern here? The cramped planes seem to come from one manufacturer...![]()
Boeing really should have made the plane either a bit narrower, so that 9 abreast wasn't possible, or a bit wider, giving it wide enough seats. It's a great plane to fly if you're not in Y.
Stitch wrote:But by not doing that, they offered flexibility to their customers. And that might have in the end won them orders because it improved CASM and CASM is a major influencer in airframe purchases. It also probably helped them keep customers by allowing them to go to denser configurations.
When it was launched, the 787 was an 8-abreast airframe and it was highlighted as being more comfortable than the A330/A340/777. And airlines like NW, CO and BA all announced they would have 8-abreast seating when they ordered. But costs rose and revenues didn't, so they all reversed themselves and went 9-abreast. If they didn't have that option, and taking into account the delays on the 787 program, how many would have cancelled and jumped ship to the A350, choosing a less-comfortable 9-abreast configuration for more revenue generation?
Boeing 737 - 17"
Boeing 747 - 17"
Boeing 757 - 17"
Boeing 787 8x - 17"
JoeCanuck wrote:Most people
JoeCanuck wrote:the rest of the airlines, (with a few exceptions)
JoeCanuck wrote:50 bucks is 50 bucks.
enzo011 wrote:Stitch wrote:But by not doing that, they offered flexibility to their customers. And that might have in the end won them orders because it improved CASM and CASM is a major influencer in airframe purchases. It also probably helped them keep customers by allowing them to go to denser configurations.
Ah, yes the blame the airline point of view again. So what we have is airlines that decided Boeing should design the airframe that it fits seats at exactly the same width as all their previous designs. We also have the airlines that wanted the most comfortable aircraft with the option of making it uncomfortable. Its the airlines that are putting in the extra seats. Boeing are only the party that give airlines what they want, right?
If anything its Airbus that is actually listening to their customers. They are providing the airframe that is comfortable in Y for passengers. They are also giving the choice of adding an extra seat but that choice comes with the knowledge that you are then really squeezing in the seats into LCC territory. The choice that Boeing gave the airlines was to have seats that are extremely comfortable or "LCC" seating that is the company standard seat widths since the 60's. But its the airlines boys and girls, remember its the airlines fault! Repeat enough times and it will become the truth!
Matt6461 wrote:JoeCanuck wrote:Most peopleJoeCanuck wrote:the rest of the airlines, (with a few exceptions)JoeCanuck wrote:50 bucks is 50 bucks.
Ok... And "few people" paying "a little less" can have a big impact on profit margin.
Here's the nub of the issue: We don't know the quantity of people with seat width awareness and preferences, we don't know the strength (in dollar terms) of these preferences, we don't know the fine-grained tradeoffs airlines made in the 77W decision.
You haven't addressed the obvious point that 10ab isn't "free" regarding RASM - else you'd have to argue that SQ and KE, inter alia, are just stupid.
The decision seems clear when we're talking about 10ab 777 versus a 9ab 777: the 10ab is a significantly more efficient plane so in the judgment of most airlines you use 10ab.
Now switch to A350 vs. 787. It's not true here - as with intra-777 comparison - that the tighter plane is clearly more efficient.
Suppose that, setting seat width aside, these planes are basically fungible and equal. I.e. they're not the exact same size, but the A359's marginal capacity can be filled with marginal transfer pax at basically break even. This is a hypothetical, but appears to be the view of lessors.
Now, imagine you're an airline CEO who worries that word will get about the 787's seat width.
Or imagine that Airbus offers you a $1 discount on the A350.
That $1, or a small risk risk, can be the tiebreaker in our hypothetical. Most worrisome for Boeing, it would be the tiebreaker in every such scenario.
The hypothetical doesn't seem far off from reality. It's a reason for concern for Boeing.
Matt6461 wrote:CX's decision to go 10ab on 777 was made pursuant to a long market study. Surely that market evaluated the impact on RASM versus CASM or revenue versus cost - however you want to phrase it. Surely JAL made the same evaluation in its decision to stay 8ab with its 787's.
scbriml wrote:Matt6461 wrote:I've never actually flown on the 787 myself - specifically for this reason. I recently had an opportunity to do so on long haul but picked a 9ab 777 operator instead. I've heard it's a barely noticeable difference but I'm a bit wider than average and didn't want to risk 13 hours of rubbing shoulders with a stranger.
I've had multiple 787 flights and all at 9-across in economy. It feels tight and slightly claustrophobic despite the other advantages of the 787 (it's very quiet and I love the bigger windows). On one trip with Ethiopian, we got off the 787 and straight on to a 9-across 777 which felt much nicer despite the 'small' windows and worn-out seating.
I haven't flown on the A350, but was able to tour the fully-fitted demo aircraft at Farnborough last year. At 9-across it seems very comfortable and 'airy' and obviously falls between the 787 and 777 all at 9-across. These days it's sadly getting harder and harder to find 777 operators that still fly 9-across in economy, so IMHO the A350 at 9-across may well become the preferred option over 9-across 787s and 10-across 777s.
Revelation wrote:JoeCanuck wrote:Oh my lord....17" isn't "making it worse". It's the same seat width that's been around forever. It's the standard seat width of the 747, which has been around since the 60's, so when people clamor on about how the 9 abreast 787 has introduced an all new level of torture to the traveling public, they are blowing it out of their nether regions. It's the same width that has always been used on the 737 and the 757.
And yet Boeing is spending $millions to add an extra 4 inches cabin width to their 777x, which means they must think it's an issue, otherwise they'd just roll with the current 777 design.
