Btblue wrote:Recent visit to Phuket island, Thailand saw daily widebody flights between it and Bangkok by Thai using A330, 747, 777-200, 777-300(non ER) 777-300ER, 787... When I say daily each of these types makes an appearance at least once (777s and A330 at least x3) with the exception of the 787 which is usually weekends. The A350 gets a turn too on occasion. There are the odd couple of A320s also.
The flight time is typically 90 minutes and clearly using such equipment works for Thai.
DocLightning wrote:For short-haul routes, part of the calculus is the amount of time it takes to turn the airplane. A larger widebody can take quite a time to unload and load, while a smaller narrowbody can turn quite quickly. Every minute that plane is parked at the gate is a minute that the airplane is not making money. So it doesn't make sense to fly an A330 from ORD to JFK since the time at the gate is likely to be longer than the flight but it makes perfect sense to fly that same A330 from JFK to SFO or even HNL.
AA300B wrote:Another one that always has me thinking is South African CPT - JNB on an A346 and A332, considering they have a decent amount of narrow bodies, why are they deploying these aircraft on such a short domestic route.
c933103 wrote:flyingcat wrote:The biggest issue is that Airbus and Boeing no longer make widebodies optimized for short sectors. Airlines have focused on maximizing usage on longer sectors and thus they no longer ask for models optimized for short haul. Unless I am mistaken the 747-400D was the last short haul optimized model.
A 777 variant was supposed to include a short haul model with reduced wingspan to fit a DC10 gate, .
yet 777 are flying on routes which 744D used to fly. Although they will also be retired
nadavatar64 wrote:Dominion301 wrote:In Canada, AC use widebodies daily on many of the 1hr-1hr20 YYZ-YOW/YUL Rapidair runs. YOW gets the 763, while YUL mostly gets 333s. Both routes also see 787s and 77W from time-to-time, especially YUL.
I also saw this summer YYZ-YYC gets 77W from AC and YYZ-YEG gets 767, nice for Alberta!
Birdwatching wrote:Examples:
Thai BKK-HKT
Delta757MD88 wrote:Recently went EWR-ORD and back, EWR-ORD was on a UA 3 class 777-200 was completely full and on the way back a 3 class 767-300 also completely full. UA does a ton of domestic widebodies. EWR-IAH/ORD/SFO/DEN(winter) ORD-IAH/SFO/EWR/LAX DEN-LAX/SFO
DaufuskieGuy wrote:you have to wonder with what on a route like HND CTS, 24 777 a day and 37 WB total https://flightaware.com/live/findflight ... ation=RJCC
I'm thinking this is the #1 WB route in the world?
B747forever wrote:Delta757MD88 wrote:Recently went EWR-ORD and back, EWR-ORD was on a UA 3 class 777-200 was completely full and on the way back a 3 class 767-300 also completely full. UA does a ton of domestic widebodies. EWR-IAH/ORD/SFO/DEN(winter) ORD-IAH/SFO/EWR/LAX DEN-LAX/SFO
UA must be the leader when it comes to domestic WB flights now that they have dedicated 10 777s for domestic use.
shankly wrote:SAA uses its A330's and A340's on the JNB - CPT rotation
gloom wrote:I think we all know the story.
Two A320s or 738s are cheaper to run than one 787. You pay twice as much to pilots, but cabin crew will be more or less the same (one per 50pax), and fuel burn of 787 is nowhere near to 2* fuel burn of 320s/737s. And in most cases, two daily will generate extra income comparing to once daily.
That being said, there are at least two more conditions that might apply to actually reverse the equation. Slots (or airport capacity in general) and cargo. In both cases, it just might turn more economical to fly widebody instead of 320/737. Excellent example is AY831/832.
Adam
Do the 767 and/or 777 head for Europe after arrival in Alberta? Could be a good way to get the metal to the prairies for the transat runs.
airbazar wrote:Strictly from an operating cost perspective, 2 narrow-bodies are cheaper to operate than 1 wide-body, where feasible. However sometimes the demand is so great that a narrow-body just won't be enough. The main reason why the 2x NB is cheaper has been alluded to: Today's wide-body aircraft are too optimized for long haul and thus are too heavy for short haul. In addition, generally speaking people don't carry a lot of luggage on short haul routes so the airline is burning fuel to carry a whole lot of empty space under the seats. The you have labor costs. Wide-body crews tend to be more senior and thus are more expensive to the airline. Of course it goes without saying, that these and many other factors differ from airline to airline.
william wrote:A better comparison would be an A330 Regional since that's the closest aircraft flying now designed for domestic flying. There really is no replacement for the 767s,L1011s and DC10s that flew domestically in the USA.
aemoreira1981 wrote:Flighty wrote:In general, widebodies cost more money per seat, and are not more fuel efficient than maximum narrowbodies.
The only cost economy that widebodies have is 1 cockpit crew vs. 2 crews for a pair of narrowbodies. And airport slots, if applicable.
In the USA for example, domestic widebodies are not cost competitive with narrowbodies. They are just repositioning flights or utilization flying.
Or if the airport is slot-restricted, which applies to JFK in New York---one of only 3 airports in the USA (LGA and DCA are the other two) with FAA-imposed slot restrictions. Since you can't increase frequencies, you need to increase the size of the planes. This is why from JFK to LAX and JFK to SFO, Delta flies wide-bodies or ex-TWA 757s.
As for domestic, it needs to be defined. Air France, as someone has said before, needs wide-bodies for routes to its overseas departments (Air France flies 468-seat 77Ws to its Caribbean and Indian Ocean overseas departments or 275-seat A340s to smaller overseas departments, depending on whether the route is from CDG or ORY, and British Airways needs them to the Caribbean overseas territories and Bermuda (although an A321neoLR could work to Bermuda). Russia needs wide-bodies for routes between Moscow and Vladivostok; Transaero before it shut down employed non-ER 773s between those two cities. Likewise, in the USA, JFK or EWR to HNL must use a wide-body (UA uses an 764 while HA uses a 332).
BTW, someone mentioned LHR-EDI---might BA's 767 utilization depend on the cargo needs? It seems as though the one-class 767s always fly with a full belly cargo load.
incitatus wrote:This is a question that deserves a lot of qualification in an answer.
The thread starter asked about Air India. Air India bought 787s to fly long-hauls. As such, it specified the airplane for such missions with 9 lavs, crew rests, large galley that can hold multiple meals and premium 74-in pitch for business class. AI can still use the plane for shorter missions, but at 256 seats with the additional weight of the long-haul configuration, it is not going to be as efficient as an A321 on a per seat basis. In between the long-haul trips the 787s will still have some down time, and scheduling them incrementally in shorter routes at busy times makes sense financially: AI can fly more shorter routes without buying more narrow bodies.
Jerry123 wrote:BA regularly use a wide body on LHR-EDI. Usually the aircraft overnights and does the first EDI LHR departure the following morning.
