jetblastdubai wrote:Is there a net gain in gates or just a replacement of an older terminal?
iahcsr wrote:jetblastdubai wrote:Is there a net gain in gates or just a replacement of an older terminal?
Let's see. A few years ago old north had C14-27 = 14. Stopped using C27 to expand B84 complex. More recently stopped using C15 to allow C14/16 to become full time WB gates. C24-26 will now be part of the new north as C1-3. New build C4-15 (no C13) Total 14. To avoid duplication the current C14 will become C24. So until such time as HAS decides to tear down/remodel the old, C1-15 will be a left turn at Brooks Bros. C16-24 keep walking north.
TWA772LR wrote:And to think the original C1-3 is today's D1-3.
TWA772LR wrote:Does anyone have a status update on B-North and the proposed, desperately needed, B-FIS?
jetero wrote:TWA772LR wrote:And to think the original C1-3 is today's D1-3.
I can't remember there ever being a C1, but perhaps the gates were renumbered when the IAB was built in 1989. I also can't remember where the old C FIS was--I think it was where C-24-27 are today.TWA772LR wrote:Does anyone have a status update on B-North and the proposed, desperately needed, B-FIS?
Why is another FIS "desperately needed"? The current FIS is going to be enlarged when D gets rebuilt to add more bag claim capacity. Otherwise, the building is perfectly fine from a capacity standpoint. Long lines are a product of CBP staffing and opening another FIS isn't going to help that problem. The B FIS died long ago. B Phase III, whenever it does get built, will be built as domestic gates. United will use the rebuilt Terminal D.
WTXJET wrote:jetero wrote:TWA772LR wrote:And to think the original C1-3 is today's D1-3.
In the 1980's prior to the Leland Terminal opening the Terminal C FIS was located where gates C43-C45 are today. This area served Continental international flights along with Viasa, British Caledonian, and Air Canada. The other international airlines used Terminal B. Also, in the early 1990's the old Terminal C FIS was remodeled and handled the Continental Express operation.
nikeson13 wrote:Somewhat reminds me of the redone terminal E at SFO, very similar styling
jetero wrote:C-North is cramped? It's a bowling alley most of the day.
WTXJET wrote:You mean the tiny area between C45 and E1(where the credit union is) was the FIS for all of those arrivals? Hopefully they were all spaced out... Regarding the old B FIS, which pod/banjo was that located in? How did pax get in an out of that area? Where was international baggage claim? I've been trying to figure this out for a long time.
Pbb2173 wrote:jetero wrote:C-North is cramped? It's a bowling alley most of the day.
I meant in terms of size of the concourse. Sorry, I'll have to dumb down my posts for you next time.
United1 wrote:jetblastdubai wrote:Is there a net gain in gates or just a replacement of an older terminal?
UA may not see an initial net gain in gates but they do have preferential rights to the gates in one of the new international terminal piers. Once the new "D" Terminal has been build out UA should have a few new gates to play around with.
WTXJET wrote:In the 1980's prior to the Leland Terminal opening the Terminal C FIS was located where gates C43-C45 are today. This area served Continental international flights along with Viasa, British Caledonian, and Air Canada. The other international airlines used Terminal B. Also, in the early 1990's the old Terminal C FIS was remodeled and handled the Continental Express operation.
SurfandSnow wrote:The cramped C gates
IAHWorldflyer wrote:The old Terminal B FIS is where B83 is today. The NW banjo of the terminal. If you ever go over there, look for some stairs next to the gate agent's desk. The FIS was on the lower level of this banjo. I've not been down there, but hard to believe they could process a 747 load of passengers down there!
KTPAFlyer wrote:Hello A.net,
I am flying through IAH Terminal C next week, and I have heard that it is opening some time in March. After checking Twitter, I noticed that one person indicated that it actually opened today! Is this a soft launch? And also, is it connected airside by the train to the other terminals?
https://mobile.twitter.com/airlinemaps/ ... 0274138112
