johnwest wrote:5200 nm is pretty tight on a 4900 nm distance of eastcoast to europe.
hOMSaR wrote:The airplane hasn't been designed yet. Nobody really knows what its range will be.
LPSHobby wrote:is there any problem if the MoM would have a bigger range, for examplle the same range of the 788?
ikolkyo wrote:LPSHobby wrote:is there any problem if the MoM would have a bigger range, for examplle the same range of the 788?
Uh yeah.... If airlines really want that kind of range they would just order the 788. MOM needs to be optimized for this 4500-5000nm strange length.
LPSHobby wrote:ikolkyo wrote:LPSHobby wrote:is there any problem if the MoM would have a bigger range, for examplle the same range of the 788?
BUT WOULDn´t the MoM be smaller than the 788?
hOMSaR wrote:If you overbuild a plane for too much capability, it is less efficient on flights that don't require that capability.
This is precisely the reason why the 787-8 isn't a good 767 replacement. It's the same reason the 757 died while the 737NG (and A320 series) grew to be almost but not quite as good, and have thrived. Carrying around too much capability that you don't use is a waste of money. The plane is overbuilt, so it costs too much to buy, and it's heavier so it costs too much to fly. If extra range was free, they'd build everything to be able to fly 10,000 nm. There's a reason they don't.
TheGeordielad wrote:There's no 797 yet.
I believe there are talks.
I don't think anyone really knows for sure about range or anything else.
