vhebb wrote:1x of the freed up A380s will pretty much be used to fund the planned A380 cabin refurbs.
777ER wrote:With regards to EK capacity on Tasman, would it be possible if EK flew the route on behalf on QF? WLG-BNE comes to mind
a320fan wrote:777ER wrote:With regards to EK capacity on Tasman, would it be possible if EK flew the route on behalf on QF? WLG-BNE comes to mind
Why would they do this? Would be much easier for them to use Jetconnect on a 738.
Talking of Jetconnect. Is there a contractual limit on how big they can grow? It's becoming increasingly common to see VH 738s and AU crew across the Tasman.
777ER wrote:a320fan wrote:777ER wrote:With regards to EK capacity on Tasman, would it be possible if EK flew the route on behalf on QF? WLG-BNE comes to mind
Yes it would be easier but if EK have an aircraft sitting around doing nothing when it could be used on a Tasman route then why not use it? QF is going to be using an EK aircraft from next year for its MEL-DXB customers so why not use an EK B777 (if it does operate the extra service) on a BNE-NZL service on behalf of QF? Freight would be heavily used on it just like SQ's WLG service is. Pretty much all of Jetconnects B738 fleet is fully used hence why WLG-MEL for example is frequently operated with one of the Aussie based PTV equipped aircraft. How much Jetconnect can grow depends on how many aircraft they have. Rumour here is Jetconnect is going to get another B738 shortly
The other one will probably do the daily SYD-HKG-SYD replacing the B744.
The HKG switch and B789s doing the QF95/QF96 will allow both older B744s OJM/OEB to be retired.
smi0006 wrote:[threeid][/threeid]vhebb wrote:1x of the freed up A380s will pretty much be used to fund the planned A380 cabin refurbs.
That would make sense. Then when all are complete MEL-HKG could be upgraded too. Equally I like the idea of MEL-DXB-BER to connect with QF1, but AJ has stated it would go via PER.
I wonder if we will see F continue? Could this be why SYD/MEL international lounges haven't been touched? Discontinue F on the 380s?
ZK-NBT wrote:This starts to paint how QF plan to retire 5 744's with 8 787's arriving, they had to do something with MEL-DXB-LHR and sending the aircraft to DXB and back to MEL wouldn't have freed up a frame so dropping it doesn't surprise me sadly.
I'd see the A380's going onto SYD-HKG with 1 other permanent route and SYD-LAX will return to daily A380, MEL-HKG is now a 744 daily most of the year, MEL-SIN is 10 weekly A330, could do a daily A380 instead? SYD-SIN is 2 daily A330's year round and at best peak time A380's could work. Asia was a problem before but QF seemed to have turned that around. Re HND, it can take A380's I believe in off peak? So QF maybe able to send 1 there but it requires 2 frames so seems unlikely while the 744ER's are around atleast.
zkncj wrote:777ER wrote:a320fan wrote:Why would they do this? Would be much easier for them to use Jetconnect on a 738.
Its not possible EK is allowed 4x daily return Tasman services, in in which are currently been used up (AKL-SYD,BNE,MEL & CHC-SYD).
777ER wrote:zkncj wrote:777ER wrote:Yes it would be easier but if EK have an aircraft sitting around doing nothing when it could be used on a Tasman route then why not use it? QF is going to be using an EK aircraft from next year for its MEL-DXB customers so why not use an EK B777 (if it does operate the extra service) on a BNE-NZL service on behalf of QF? Freight would be heavily used on it just like SQ's WLG service is. Pretty much all of Jetconnects B738 fleet is fully used hence why WLG-MEL for example is frequently operated with one of the Aussie based PTV equipped aircraft. How much Jetconnect can grow depends on how many aircraft they have. Rumour here is Jetconnect is going to get another B738 shortly
Yes EK are personally restrained but I'm pretty certain the EK/QF deal allows either airline to operate more services if they wish (not less then what they currently have) but also on behalf of each other. If this is correct then technically EK can operate a service on behalf of QF, like what EAA does for JQ here with Q300s
qf2220 wrote:Can someone step it through for me how the MEL-DXB-MEL sector (if it was maintained) would still tie up the same number of frames as MEL-DXB-LHR-DXB-MEL?
Obzerva wrote:
I wouldn't rush to Berlin, QF's yields were apparently average on FRA, and BER's yields are notoriously worst than FRA. Yes they have a oneworld "partner" based in Berlin, but they obviously lean very much to VA rather than QF.
Note that both SQ and CX have opened up DUS recently rather than TXL.
Unless there's a pot of gold waiting in BER that QF knows about, serving it as they currently do via codeshare out of LHR, might be sufficient, or if they need another option to capture the dollar, out of HEL or via DUS with at least an interline on AY and AB would be the cheaper answer.
a7ala wrote:I agree and wouldnt discount that EK may be looking at that option. They have previously publically expressed interest in WLG and cited the runway being too short for their Australian fleet (300ER/A380). Bringing a 200LR down provides an aircraft which can presumably get into WLG (SQ's is a B777-200?) and flying on a monopoly sector (VA only) that QF doesnt currently fly on (BNE-WLG) may be palatable for QF.
zkncj wrote:a7ala wrote:I agree and wouldnt discount that EK may be looking at that option. They have previously publically expressed interest in WLG and cited the runway being too short for their Australian fleet (300ER/A380). Bringing a 200LR down provides an aircraft which can presumably get into WLG (SQ's is a B777-200?) and flying on a monopoly sector (VA only) that QF doesnt currently fly on (BNE-WLG) may be palatable for QF.
Pretty sue WLG-BNE isn't an goldmine - NZ choose to give this route over to VA and not operate any of there own services on this route, really has something to say about the route
qf789 wrote:qf2220 wrote:Can someone step it through for me how the MEL-DXB-MEL sector (if it was maintained) would still tie up the same number of frames as MEL-DXB-LHR-DXB-MEL?
A MEL-DXB-MEL would need 2 frames, flying time would be 27 and a half hours plus turn around times at each end. Currently there are 5 frames used on QF1/2 and QF9/10 and currently rotated SYD-DXB-LHR-DXB-MEL-DXB-LHR-DXB-SYD. With QF9/10 MEL-DXB-LHR being axed QF1/2 will have a ground time of 15 and half hours at LHR so you would need 3 frames for that
a7ala wrote:777ER wrote:a320fan wrote:Why would they do this? Would be much easier for them to use Jetconnect on a 738.
LamboAston wrote:a7ala wrote:777ER wrote:Yes it would be easier but if EK have an aircraft sitting around doing nothing when it could be used on a Tasman route then why not use it? QF is going to be using an EK aircraft from next year for its MEL-DXB customers so why not use an EK B777 (if it does operate the extra service) on a BNE-NZL service on behalf of QF? Freight would be heavily used on it just like SQ's WLG service is. Pretty much all of Jetconnects B738 fleet is fully used hence why WLG-MEL for example is frequently operated with one of the Aussie based PTV equipped aircraft. How much Jetconnect can grow depends on how many aircraft they have. Rumour here is Jetconnect is going to get another B738 shortly
What is the longest flight/heaviest load that a NZ 77W has lifted out of WLG?
Using data from a few sources, and a bit of estimation, the flight looks easily suitable for a 77W.
According to here: http://www.flugzeuginfo.net/acdata_php/ ... 773_en.php B773/W empty weight is approx 160,000kg. I know the 77W would be heavier, and I am not sure which this is for (773/77W), but as I keep going, you will see this doesn't matter.
On the third post on this: viewtopic.php?t=766921 there are CX's numbers for 77W fuel burn (for pilot calculations) at 8100kg/h, and I estimated 5 hours of fuel - 40,500kg (I am not a pilot, so this is a guess to the amount needed, tell me if you need more).
On Boeing's chart http://www.boeing.com/assets/pdf/commer ... 2lr3er.pdf at 3.3.9, for 6000ft runway (I know WLG is more, just leaving more margin), MTOW is around 270,000kg.
If I work this all out, it leaves a 69.5 tonne payload, which is far more than necessary, so their runway too short is a lie.
jupiter2 wrote:What is the longest flight/heaviest load that a NZ 77W has lifted out of WLG?
There is a reason why the biggest thing that NZ put into WLG is a 320.
The only current widebody flight is the SQ 777 and it departs on a 3 hour flight. Previously largest were the 767's of NZ and QF and they also only went as far as the Australian east coast, can you see the recurring theme ? Sure you can put them in and fly them out, but you're not going to be able to do it legally with any reasonable payload and substantial distance. Besides the fact that a 77W into WLG would be completed overkill for the market there.
LamboAston wrote:jupiter2 wrote:What is the longest flight/heaviest load that a NZ 77W has lifted out of WLG?
And it would be on a 3-4 hour flight to East coast Australia. The fact that SQ can run a 772 effectively into CBR then SIN just proves that a flight through a higher demand airport like BNE, SYD, or MEL would work. As a7ala pointed out though, it is landing length that is the problem, not take off length.
a7ala wrote:LamboAston wrote:jupiter2 wrote:What is the longest flight/heaviest load that a NZ 77W has lifted out of WLG?
Which then comes back to the previous point that EK's B777-300ER and A380 is too big to land at WLG, but if the rumours at true they are considering a B777-200LR into BNE then that provides at least a capable aircraft they could extend across.
LamboAston wrote:a7ala wrote:LamboAston wrote:And it would be on a 3-4 hour flight to East coast Australia. The fact that SQ can run a 772 effectively into CBR then SIN just proves that a flight through a higher demand airport like BNE, SYD, or MEL would work. As a7ala pointed out though, it is landing length that is the problem, not take off length.
I did just run the calculations on the NZ thread and the 77W could land with 50T of payload and fuel on a 6000ft runway.
qf2220 wrote:qf789 wrote:qf2220 wrote:Can someone step it through for me how the MEL-DXB-MEL sector (if it was maintained) would still tie up the same number of frames as MEL-DXB-LHR-DXB-MEL?
Thanks for this. Shame about the 15hrs at the LHR end...
Why do people prefer a late departure from LHR as opposed to a morning one? Or is it more to do with the curfew back in SYD?
jwoww wrote:Does anyone know what countries Australia has 5th Freedom rights with? Obviously we have it with England and UAE, but who else?
I have a week off and when i do i try and create things, and at the moment i'm creating a new airline for australia and was wondering what countries australia is allowed to fly from and transport passengers not coming from Australia. Obviously this isn't a serious thing its just a fun thing to give me something to do.
And it would be on a 3-4 hour flight to East coast Australia. The fact that SQ can run a 772 effectively into CBR then SIN just proves that a flight through a higher demand airport like BNE, SYD, or MEL would work. As a7ala pointed out though, it is landing length that is the problem, not take off length. Also, QF operated the 747SP out of Wellington before the 767s.
jupiter2 wrote:
The SQ 777 runs 3 times a week, you're talking about a daily service with a larger aircraft, it's just not going to happen with what they fly with to Australia now, besides they fact that they have no more traffic rights.
Probably more to do with business traffic, do a days work/meetings in London fly late evening, sleep on board, arrive early morning in SYD then off to the office for a days work/ meetings
smi0006 wrote:In another thread it was suggest HND couldn't handle 380s? Is this correct?
HKG being slot contradicted and with VA completion does seem a logical place to deploy the 380- especially if it was a consistent route and F was offered. SIN with no slot issues could become a mix of 744 and 330s 14/10 times weekly + EK and JQ.
jupiter2 wrote:LamboAston wrote:jupiter2 wrote:What is the longest flight/heaviest load that a NZ 77W has lifted out of WLG?
Yer they put the 74L in there, with heavier more powerful brakes and specially trained crew, if they weren't on the ground by a certain point they had to go around, no exceptions. The heavier brakes had to get removed before they could use the 74L to LAX as they would've hampered performance on the route. Before the 74L they used NZ DC8's because the 707 couldn't land there, before that it, it was Electras.
Jupiter - I think you missed the point. Point was that there are rumours they are bring a B777-200LR to BNE which same size aircraft as the SQ service - much smaller then their current Australian aircraft.
BTW SQ flies 4/week not 3/week...
DeltaB717 wrote:jwoww wrote:Does anyone know what countries Australia has 5th Freedom rights with? Obviously we have it with England and UAE, but who else?
Singapore, Hong Kong, China, Japan, India, Sri Lanka, Malaysia... there's a few for starters.
a320fan wrote:JQ are getting there name dragged through the mud in Australian media today having been named the worlds worst airline in a consumer survey. Mainstream outlets such as Seven, Ten and Nine have picked up the story running sensationalist headlines like 'Jetstar worst airline in the world' there must be tears in the PR department today. Good to see more defence for the airline on social media than criticism. Worst airline in the world it certainly is not. Fly Jetstar a lot when traveling on a budget. While I prefer VA and QF for my domestic flights, I've never had a problem with JQ. Cancelation rate is under 3%, on time performance stats could be better but aren't terrible. They ranked last consistently last year in the on time stats, but seem to have picked up the game a bit this year and have beat tiger the last few months. (Months that have been pretty terrible for all domestic airlines actually)
log0008 wrote:a320fan wrote:JQ are getting there name dragged through the mud in Australian media today having been named the worlds worst airline in a consumer survey. Mainstream outlets such as Seven, Ten and Nine have picked up the story running sensationalist headlines like 'Jetstar worst airline in the world' there must be tears in the PR department today. Good to see more defence for the airline on social media than criticism. Worst airline in the world it certainly is not. Fly Jetstar a lot when traveling on a budget. While I prefer VA and QF for my domestic flights, I've never had a problem with JQ. Cancelation rate is under 3%, on time performance stats could be better but aren't terrible. They ranked last consistently last year in the on time stats, but seem to have picked up the game a bit this year and have beat tiger the last few months. (Months that have been pretty terrible for all domestic airlines actually)
Yep - absolutely ridiculous, I have flown a number of LCC's and its one of the best in the world. Saw one media article that said "Jetstar was shockingly beaten in all departments by Virgin and Qantas" - well what a surprise, maybe that has something to do with the fact your ticket cost 50% that of VA or QF??
