callumconroydub
Fate of the 747's
Sat Apr 22, 2017 11:16 pm
Here is a question:
Are all the 747-100's gone now? Why?
I don't see 747-300's around much anymore. Why?
Thought they were great old planes...
ASQ400
Re: Fate of the 747's
Sat Apr 22, 2017 11:28 pm
Part of that stems from the times when the 747 was built.
When the 747 was devised in the 70's, before ETOPS, Twinjets had to stay within 60 minutes' distance (with one engine running) of a suitable airport, for fear of an engine failing, which was more common then. Quads and Trijets were the mainstays of cross-Ocean flights. Airlines also tended in general towards the hub-and-spoke model, which called for big aircraft on the long routes between hubs.
With the advent of ETOPS and the 777, the 747 was no longer king of ocean-crossing. The 777 is a good deal cheaper to fly per passenger-mile, and a lot easier to maintain. The 747s from the 90s onwards began to be used on routes where high capacity was actually needed, as opposed to anything long. This, I assume, created a surplus, which is why there are very few 747-100/200/300 out there.
The 767, 777, and especially the 787 today also make the point-to-point model more economical for long distances, which reduces the number of high-capacity routes where the 747 (as well as the A340 and A380) are warranted.
TLV, BRU, ZRH, CDG, FRA, EWR, JFK, DEN, SFO, AUS, RNO, SEA, YYC, YYZ, IAH, ATL, IAD, DCA, ORD, SJC, SNA
callumconroydub
Sat Apr 22, 2017 11:31 pm
Are there any airworthy 747-100's in service today?
ASQ400
Sat Apr 22, 2017 11:32 pm
Nope. Iran Air got rid of the last one in 2014
callumconroydub
Sat Apr 22, 2017 11:40 pm
Is there still 741 freighters?
ASQ400
Sat Apr 22, 2017 11:41 pm
There was never a freighter variant of the 741.
callumconroydub
Sat Apr 22, 2017 11:43 pm
So, the 741, effectively, doesn't exist anymore? Where they not brilliant planes?
TNST3B
Sat Apr 22, 2017 11:47 pm
They were fine for their day, just obsolete now.
ASQ400
Sat Apr 22, 2017 11:49 pm
As I explained, there were too many 747s around by the 2000's.
The oldest, and therefore crappiest, 747s were the first to die, and so the 741 met its end.
Regardless of how good an airplane was in its time, it gets outdated eventually.
The 742/744 were the successful models, anyway.
Spacepope
Sat Apr 22, 2017 11:51 pm
UPS operated 8 741 freighters (converted). That is if you count the SRs as -100s.
xjetflyer2001
Sun Apr 23, 2017 12:12 am
I have a photo of a UPS 747 N691UP which shows as LN: 7, was that a converted 747-100?
Channex757
Sun Apr 23, 2017 12:27 am
Here is a question:
That's your answer, great OLD planes.
Not only do they guzzle fuel compared to today's twinjets, it is increasingly hard to support them with spares and consumables. There will be very few early model JT9D engines that are suitable for a 747-100 with some meat left on the bone. Systems all throughout the aircraft wear out or need replacements, and the spares pool just isn't there any more.
Same goes for the 747-300; operators retired them and better value 747-400s came on to the market so those aircraft became unwanted and obsolete. Many of them ended up as freighters as their engines were more powerful, but again better aircraft came onto the market and the old ladies went to the desert. The converted 747-300F was a good load hauler but the 747-400F is much, much better.
Cunard
Sun Apr 23, 2017 12:52 am
I can't honestly believe this is being discussed, does the OP see many cars on the road that are nearly fifty years vintage, no because there obsolete just like the aircraft he is questioning, it's quite obvious at the end of the day.
94 Countries, 327 Destinations Worldwide, 32 Airlines, 29 Aircraft Types, 182 Airports, 335 Flights.
jimatkins
Sun Apr 23, 2017 12:53 am
Don't -300s have a 3 person crew? 400s are 2 person crew, cheaper right off the bat.
ASQ400
Sun Apr 23, 2017 12:57 am
Yeah. The 400s are more efficient than their predecessors in almost every way, which is only natural given the massive age gap between them
RetiredWeasel
Sun Apr 23, 2017 1:01 am
As discussed in several other threads, the 400 (US Regs) required a third pilot in flights over 8 hours which was usually the case. So the decrease in crew costs were marginal.
rbavfan
Sun Apr 23, 2017 1:02 am
You left out that many 747 routes were too small for the 747s capacity. As such when smaller 767/777/A300/A330 aircraft could fly longer ETOPS routes the capacity was adjusted for demand. Airlines like Air New Zealand used them on routse where there were 50% or lower loads because 4 engines was required to fly the route and the L1011 & DC-10 did not always have the range.
ASQ400
Sun Apr 23, 2017 1:10 am
I implied it by saying that the 747 post-ETOPS was only used where high capacity is actually needed, as opposed to just on long flights.
ZK-NBT
Sun Apr 23, 2017 2:02 am
Curious, where did you hear and what were these routes that NZ flew 747's with 50% or lower loads?
BasilFawlty
Sun Apr 23, 2017 2:50 am
Iran Air Force is still operating several 747-100's.
'Every year donkeys and mules kill more people than plane crashes'
ASQ400
Sun Apr 23, 2017 3:31 am
Wiki says they're all gone.
afterburner
Sun Apr 23, 2017 3:57 am
You forgot to include A330 and A350. :)
ASQ400
Sun Apr 23, 2017 4:01 am
A330 too, but A350 is more of a response to the 787 than a true innovation.
UA444
Sun Apr 23, 2017 6:49 am
GE still has a 741 test bed and the Iranian Air Force has a few. Line number 5, a -131 is still active.
CanadaFair
Sun Apr 23, 2017 9:47 am
Here is a question:
Still in use:
747-100
GE test bed - 1
Iranian Air Force - 6
747-300
AviaTrans Export Cargo - 1
Mahan Air - 1
Saudi Government - 1
Max Air - 2
vv701
Sun Apr 23, 2017 10:37 am
741 CN 20270, LN 169, was originally operated by BOAC and then BA as G-BNWH. It was retired in June 1989 and sold by its lessor, AAR Aircraft Leasing, to Sandia National Laboratories. It was then ferried to ABQ in early June '89. Its British registration was cancelled on 18 June. As I can find no reference to any US registration that could have been its last flight.
However the last I saw of it was a photo taken at ABQ in April 2013. At that time it had had its engines and rudder removed but carried 'FEDERAL AVIATION ADMINISTRATION' and 'FAA/AANC Testbed Aircraft' titling with an FAA tail logo. This suggests it may have been flown. But perhaps it was a ground handling or emergency evacuation test bed?
Anyone know anything more? Is it still at ABQ or has it been broken up?.
G-CIVP
Sun Apr 23, 2017 10:46 am
Typo! G-AWNH
Channex757
Sun Apr 23, 2017 11:33 am
I think the reference to 3 person crew was actually the need for a flight engineer on the -300
Channex757
Sun Apr 23, 2017 11:34 am
Wasn't this the aircraft being used for studies into ageing aircraft, strangely enough?
OldAeroGuy
Sun Apr 23, 2017 3:12 pm
Don't you mean "When the 747 was devised in the 60's...."?
The 747-100 first flew in February 1969 and EIS was in January 1970.
RetiredWeasel
Sun Apr 23, 2017 3:41 pm
Maybe I'm wasn't too clear. Flights between 8 and 12 hours required 3 aviators whether it was 2 pilots and an FE (200,300), or 3 pilots (400). This applied to 200's and 400's. Since they were paid by the hour, the cost difference (paying 3 aviators) was marginal. With flights over 12 hours things got more complicated regarding crew augmentation on the 200. On flights less than 8 hours, of course the 400 cockpit crew cost was probably less because the airline only had to pay 2 aviators (pilots).
ASQ400
Sun Apr 23, 2017 3:50 pm
As always, my memory goes shoddy. LOL
