Early in his book, Juby offers these little-known details about the Sept. 2, 1998 flight: the first class passengers had been moved to the rear of the aircraft, and all aboard were dead before the plane crashed.
NWAROOSTER wrote:Nobody seems to mention that there was was smoke in the cockpit that was caused by shorted wires in the overhead near the cockpit bulkhead causing a fire. Also the pilot tried dumping fuel over the sea by circling when he should of attempted landing the aircraft heavy at Halifax and maybe there would of been survivors.
NWAROOSTER wrote:Also the pilot tried dumping fuel over the sea by circling when he should of attempted landing the aircraft heavy at Halifax and maybe there would of been survivors.
atcsundevil wrote:If we're talking aircraft accidents into the Atlantic in the late 90s, it seems to me that Egypt Air 990 is far more controversial. I feel the NTSB conclusion is best supported by facts, but the Egyptian ECAA refutes the NTSB conclusions to this day.
TheFlyingDisk wrote:I'm surprised A.net's resident "spymaster" didn't try to pin this on that feared post WW2 secret agency of Germany.
ikolkyo wrote:The part about that worker who used fake credentials and worked the shift of the flight and booked it was very interesting to me.
richierich wrote:ikolkyo wrote:The part about that worker who used fake credentials and worked the shift of the flight and booked it was very interesting to me.
If this is even true, it doesn't mean there was a nefarious reason as to why it happened. Imagine your first day on the job as a ground crew worker and then this happens, it would hardly be surprising that he/she didn't go back to work, especially knowing that the 'fake credentials' would get a lot more scrutiny. I'm not buying the disappearing act, that sounds very fishy to me.
This is how conspiracy theories work, they tend to identify a string of perceived inconsistencies and then present that as fact for a cover up. I don't know what happened to SR111 (or TW800 or JFK's assassination, either) and of course there is an outside possibility that there was a lot more to these unfortunate events than we know about, but not having all of the answers lining up neatly is not proof of a greater conspiracy. For those not around in 1998, the Swiss crash was extensively covered in the media, albeit more so in Canada than the US, and was one of four major crashes involving JFK airport as a departure or destination airport within a four year span (TW800, SR111, MS990 and AF4590) so that would seem to indicate a pattern and therefore it lent itself to more conspiracy rumors. If you can discount the Egyptair crash as a pilot-suicide, itself a controversial finding, and the Concorde crash as a result of runway debris, the TWA and SR crash were most similar in that each crashed into the Atlantic Ocean. But as we know, the former exploded 12 minutes after takeoff and the latter was on-fire and had radioed mayday calls before its fatal plunge.
ikolkyo]
Not saying it had anything to do with the crash, I honestly don't think there is anything else behind SR111 other than what the investigators found.[/quote]
That's pretty much where I am with it. You said it shorter.
[quote="trnswrld wrote:One thing I'm curious about that I read above which seems unusual is one post says it was almost impossible to identify bodies even using dental records because of an impact so great teeth were actually shattered....then another post mentions autopsies were done and determined that smoke inhalation did exist, but did not cause death. Maybe I'm just not knowledgeable enough on this, but if teeth were shattered, how the heck was there autopsies done to determine what they found regarding smoke inhalation? Doesnt an autopsie more or less require intact bodies?
