AMERICAN757
Whats next at IAH?
Fri May 05, 2017 3:09 am
Now that the new C North has been opened fully what is next at IAH? Has United vacated old C North? With all the money being invested in IAH I am curious to see how it could grow in the future. As my home airport for the past 3 years now I hope to see it continue to thrive and eventually grow again.
iahcsr
Re: Whats next at IAH?
Fri May 05, 2017 3:17 am
Old C North will make way for an expanded D Terminal.... Whenever the HAS sorts out what to do. There was a plan in place until the new mayor decided he didn't like it. Last I know the project is in the rebidding process ATM.
UA still has control of old north for now. But don't have need or the staffing for both old and new unless bad weather forces the need for extra gate space.
GamingPolaris
Fri May 05, 2017 3:35 am
At the moment, the MLIT is still postponed at the moment. Still waiting on the new bidding to commence and later for construction to start.
jetero
Fri May 05, 2017 3:52 am
Design contract was issued in December.
AVENSAB727
Fri May 05, 2017 4:29 am
According to their 1st quarter 17 earnings conference call, United plans to re-bank IAH by the end of this year, in order to give them the platform to grow IAH further. Regarding the rumor about China Eastern starting IAH-PVG in June or July this summer seems to be nothing more than hot air, since there has been no DOT application nor any announcement from HAS, which is a bummer because it would be cool to add another foreign flag to IAH's already impressive lineup.
Always look on the bright side of Life!
GamingPolaris
Fri May 05, 2017 4:39 am
MLIT construction is supposed to start during Fall/Winter 2017. Fingers crossed that construction will start in order to get a massive facility that significantly improves the first impression that IAH needs to further attract airlines.
With the old Terminal C North now empty, some Terminal D flights can now shift to the abandoned terminal, meaning more aircraft can arrive at the same time. With this in mind, there's a bigger possibility of China Eastern launching IAH-PVG, but only time will tell.
Would love to see CX launch IAH-HKG with Airbus A350 equipment though.
GamingPolaris
Fri May 05, 2017 4:42 am
Some contracts have yet to be released for bidding, which further delays the project.
jetero
Fri May 05, 2017 5:01 am
Actually, it doesn't have to--pretty typical to issue the design contract before the construction contract. Certainly not according to plan, but if United wants it, it will be built. if it doesn't, well, Terminal D will just be fine. It's about 10, if not 15, years away from being an LAX disaster. Not quite sure I understand why people perceive Terminal D to be so bad. Not nice by any stretch of the imagination, but I've seen way, way worse.
FlyingSicilian
Fri May 05, 2017 5:50 am
Yeah, terminal D is a bit bland, as it was cut down a bit during design and during construction due to the oil bust, but it is usable. I do find it a bit annoying when they board two large aircraft flights departing within ten minutes of each other right at D4 and 5 as it gets crowded, but the terminal "works".
American Airlines should be reopening its lounge soon in terminal A, and United should be starting the Polaris lounge at the top in E also.
Would be nice to see a few small domestic city flights return eventually, but I am not holding my breath. I know a large number of pilots at UA who are reserve pilots in the AF down at Laughlin and they really miss the Del Rio flight from IAH.
“Without seeing Sicily it is impossible to understand Italy.Sicily is the key of everything.”-Goethe "Journey to Italy"
thomasphoto60
Fri May 05, 2017 7:42 am
Yeah, I suspected as much. Given the time that the rumors broke to the start up date (no actual date) seemed a little short, never mind the silence from MU and HAS and no DOT filings as mentioned above, huge red flags, then again, how knows?
"Show me the Braniffs"
jplatts
Fri May 05, 2017 1:10 pm
Southwest Airlines actually has room to expand domestically at Houston Hobby, including opportunities to add new nonstop service to domestic destinations that are not currently served nonstop from Houston Hobby. If Southwest adds nonstops to additional destinations out of HOU, would some of the demand for Houston air travel shift to HOU, or will there be a significant increase in demand for air travel out of both IAH and HOU?
TWA772LR
Fri May 05, 2017 2:56 pm
HOU and IAH will continue to coexist just fine. Any increase in demand for Houston will effect both airports, but the question is what area of Houston will have the bigger draw.
Terminal D is the next big project at IAH. I'd love to know what happened to the B North renovation plans as well as the B FIS. Slow down in travel or not, another FIS is needed at IAH. Although most of the congestion in the current one is due to CBP staffing (80 positions and only ~15 are filled on a good day in immigration), but the big nightmare is international baggage claim and customs. It is a very unpleasant experience and that whole floor needs to be revamped with more lighting or a whole reconfiguration of the area, or a new FIS ;)
The master plan calls for an eventual 8C/26C and 27L/9R, with the 8/26 to be built first. The MP also includes landside retail areas (not in the terminal), improved water drainage, a perimeter taxiway, and other things like a whole new giant terminal F over where the United 787 hangar is, but who knows if that will happen, IAH is underutilized as it is. Let's hope the rebanking makes room for more flying.
Terminal A is getting crowded however. With UAs gate squatting and Spirit growing like wildfire, the MP calls for a connection between the north and south concourses of A that will allow about (rough guestimate) 7-8 more gates. It would be cool if they incorporate the old control tower with that link as some kind of observation deck.
When wasn't America great?
Rdh3e
Fri May 05, 2017 3:12 pm
Airlines don't care that much about facilities at a spoke airport. It's certainly not going to impact the business case unless the facility is total garbage and unsafe which is not the case at IAH. It's also not airlines first impression, the first impression is usually the data on passenger demand, not some facility concern.
LAXdude1023
Fri May 05, 2017 3:30 pm
Being realistic is important on a.net since threads like these tend to get carried away and before the end of it were talking about how South African and Qantas will be serving IAH before too long.
Since MU has stated it is interested in Houston, I would imagine we will see them at some point here. I dont know when.
CX is a non-starter. UA on IAH-China is a nonstarter.
FOR THE LOVE OF GOD BRING BACK THE PAYWALL!!!!
AMERICAN757
Sat May 27, 2017 1:32 pm
Flying through IAH this morning and I am sitting in the newly renovated United Club at C north and I am surprised to see the OLD C North has some planes parked at the gates. Is this concourse still used as needed? This place is packed today.
What do we think Scott Kirby's plans for IAH are going to be?
jetero
Sat May 27, 2017 4:45 pm
Why tear it down before the expanded Terminal D has even been designed?
AMERICAN757
Sat May 27, 2017 5:14 pm
Well I didn't say anything about tearing it down..but I was surprised to see a terminal full of planes but when I left to head to the gate I noticed a blue curtain blocking it off. It's not like United needs all that space at present.
jetero
Sat May 27, 2017 5:32 pm
The corridor leading to the original C-North gates was blocked by a curtain?
AMERICAN757
Sun May 28, 2017 1:49 am
Yes..
jetero
Sun May 28, 2017 2:22 am
AMERICAN757 wrote:
Yes..
Interesting--if I had to guess it was probably a United corporate event. When it's walled off as the C-Northwest gates are then I'd think there is something up.
Gate requirements are going to increase with the rebanking of the schedules so I doubt they'd leave them now.
AMERICAN757
Sun May 28, 2017 3:44 am
jetero wrote:
AMERICAN757 wrote:
Yes..
It was interesting. As I sat in the club I noticed two aircraft that they pushed away from Old C North and tugged over to New C North
COflyerBOS
Sun May 28, 2017 4:27 am
China Eastern's service to Houston is now rumored to start in the third quarter. We'll see but it's still a solid rumor.
TWA772LR
Sun May 28, 2017 7:20 am
I'm hoping for more regional and Texas cities to be added. Those 50 seaters still have a purpose somewhere. It's sad as a Houstonian to see the reduction in intra-Texas flying post merger, especially when DFW was gaining them through AA. Petty rivalry, I know. Tyler, Del Rio, and air service to Beaumont would be great to be returned, and adding on San Angelo and Love Field. Please bring back the Love UA!!!
thomasphoto60
Sun May 28, 2017 9:26 am
Interesting considering that we are close to ether end of the 2nd quarter.
B737900ER
Sun May 28, 2017 11:55 am
jetero wrote:
AMERICAN757 wrote:
Yes..
The old C north is empty. All the seats and gate equipment have been removed. It's just used for overflow parking.
iahcsr
Sun May 28, 2017 1:48 pm
AMERICAN757 wrote:
jetero wrote:
AMERICAN757 wrote:
Yes..
Old north is being used as a aircraft parking area, no active flight activities. The curtain is there to keep people from wondering around in the unused space.
AMERICAN757
Sun May 28, 2017 2:53 pm
Got it. That makes sense. With such nice facilities being built it would be great to see UA utilized IAH to its fullest potential.
jetero
Sun May 28, 2017 3:21 pm
Seems like a waste of perfectly convenient gates until construction starts. Walking distances at IAH are only getting worse with the moving sidewalks being taken out and no train station at the new C-North.
In any case, UA seats at IAH are up 2.8% 3Q and flat for the 4Q--flights are slightly down so increase in seats is from upgauging, but the 4Q schedules haven't been fleeted yet. Rebanking should also raise load factors, so UA should start growing again, absent need to shift capacity for some market share battle at DEN, EWR, or SFO. They pulled down too much to begin with, as IAH bore the brunt of 50-seat retirements.
If true, they would certainly be shooting themselves in the foot re advance ticket sales.
NichCage
Sun May 28, 2017 3:27 pm
I think Air India has also expressed interested in flying to IAH. Otherwise, Cathay Pacific, China Airlines, and China Eastern are the airlines that have also expressed interest into flying to IAH.
Why doesn't Etihad Airways serve IAH?
COflyerBOS
Sun May 28, 2017 3:28 pm
Sorry, I typed that wrong. Is supposed to read "sometime after the third quarter."
Orient Aviation says sometime after September for China Eastern to enter the market.
LAXdude1023
Sun May 28, 2017 4:07 pm
Because they fly to Dallas and can feed AA connections there. By that same token AI appears to be choosing DFW over IAH (though it's my opinion either city will be a disaster for them).
To my knowledge CX has no interest in Houston. Neither does CI. MU on the other hand does.
GamingPolaris
Sun May 28, 2017 4:41 pm
UA has been operating the Boeing 777-300ER on the IAH-LHR route for the past week. Hopefully it lasts longer.
AVENSAB727
Sun May 28, 2017 4:47 pm
I have noticed that too in the past days of that week, hopefully it stays, and maybe NRT/AMS go to the 77W as well.
iahcsr
Mon May 29, 2017 5:28 am
UA doesn't have the staffing above or below the wing to operate both old and new C north at the same time.
jetero
Mon May 29, 2017 6:04 am
Thanks. In this age of conspiracy theories, it's very comforting to have such a rational explanation!
AMERICAN757
Mon May 29, 2017 6:51 pm
I am excited to see how the rebanking of the hub will play out.
GamingPolaris
Tue May 30, 2017 3:02 am
I wonder what date will China Eastern commence flights to IAH. It's been rumored for quite a while and it's getting old.
LAXdude1023
Tue May 30, 2017 1:32 pm
Thats why its called a rumor. MU has expressed interest, but until they apply to move slots around with the DOT, it means nothing.
GamingPolaris
Tue May 30, 2017 1:58 pm
There are no slots to move around. IAH has no slots, with the exception of PVG, but they obviously are not controlled by the US DOT.
IAHWorldflyer
Tue May 30, 2017 2:22 pm
I flew into IAH last week and for the first time arrived at the new C North. Very nice facility, but the walk down to the center of C is really long. As a person with a slight mobility impairment, it is upsetting to me that they have also removed the moving walkways in E, in favor of more retail. IAH is my home airport, but the number 1 complaint I hear from traveler's not based here is the long walks between connections. Second complaint is a lack of clear signage, which, in some cases is valid.
LAXdude1023
Not slots, I meant frequencies. There are no China-US frequencies left.
slider
Tue May 30, 2017 3:01 pm
So on that topic, and perhaps someone can clarify because I don't know--is UA beholden to the Terminal D completion before the next phase of B North??
Also, TWA, I'd add that whilst you say HOU and IAH will coexist just fine, your own comment betrays that when you mention CBP staffing---it's a finite pool and now that HOU has FIS and international service, some of that resource was diverted from IAH and the Port of Houston.
As for international bag claim and customs, I don't agree with you there. I've had nothing but great experiences arriving into Houston. Now, if you're at the back of the bus and have a lot of activity coming in, congestion is a major issue, I get that. But the flow is generally OK!!
TWA772LR
Tue May 30, 2017 3:06 pm
I've worked as an employee in FIS for various airlines in IAH and I've seen the Customs line go all the way back to the last carousels, and arc back around toward the front. I don't even like being in there as an employee, much less as a pax after a 15 hour flight from DXB.
As far as CBP staffing goes, hire more agents. I'd love to get into that topic, but that's a political issue and this isn't the thread for that.
D is not UAs project, it's the City of Houston's.
AMERICAN757
Tue May 30, 2017 4:00 pm
I hope perhaps B renovation could be moved up and those banjos removed to create a nicer space to mimic new C North.
iahcsr
Tue May 30, 2017 4:11 pm
I believe that's on the back burner for now unfortunately. On an ever so slight plus side I'm informed (correctly I hope) there is now a walkway open between C north and B north which is quite beneficial if one has the right connecting gates.
jplatts
Tue May 30, 2017 5:20 pm
Delta might possibly add IAH to LAX nonstop service since IAH is a major Texas market and since Delta already does nonstop flights from LAX to 3 other Texas markets (DFW, AUS, and SAT).
jplatts
Tue May 30, 2017 5:26 pm
Virgin America had previously announced plans to do nonstops to Houston from SFO and LAX, but has not yet added service to Houston from SFO and LAX. Alaska might end up adding nonstop service from IAH to both SFO to LAX, but might operate the IAH-SFO and IAH-LAX nonstop service under the Alaska brand.
AMERICAN757
Tue May 30, 2017 6:51 pm
I wish I would've saw that before I took the airport train over from C to B to catch my connection to DTW the other day. I've only checked out the new C one time but have yet to arrive or depart from it.
jetero
Tue May 30, 2017 8:07 pm
No, they're separate agreements.
KTPAFlyer
Tue May 30, 2017 8:52 pm
They removed the moving walkways is E?! I was there two months ago and only made my connection because I was running like crazy from E East to C South on those walkways. It really is a shame if they did, because otherwise it is indeed a very long walk.
